[postgis-users] Identifying field names in select out of order
Don Drake
don at drakeconsult.com
Mon Feb 20 16:54:49 PST 2006
Are you using PHP?
You really want to use pg_fetch_assoc() which returns the row in an
associative array. Similar methods exist in the Perl libraries as well.
-Don
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sean M.
Montague
Sent: Monday, February 20, 2006 5:54 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Identifying field names in select out of order
This is PostgreSQL specific question. I'm iterating through my selection
and need to get the field name of my data[$i] where
$data=pg_fetch_row($result, $i). I've tried pg_fieldname($result, $i),
but the problem is that the field names in the select statement are not
in the same order as the db, so pg_fieldname(result, $i) is not the
filed from which data[$i] is drawn from. Is there another way of
determining which field data[$i] comes from regardless of the field
order? Thank you.
Sean
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
