[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
alex bodnaru
alexbodn at 012.net.il
Fri Jan 13 18:10:09 PST 2006
assad,
your ./configure output seems a little wird for a clean postgresql sarge
installation.
the procedure below will possibly help. if still in problem, you might
need to have a better backported postgresql for sarge, or upgrade debian.
please apply this diff to the *clean* postgis source:
cd postgis_source_root
zcat the_attached_file | patch -p1
# you should have ./debian subdirectory in postgis_source_root
chmod ug+x debian/rules
dpkg-buildpackage -rfakeroot
good luck,
alex
Assad Jarrahian wrote:
> Alex,
> I am running sarge. How do I get a hold of that package.
> I looked at http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl/PackageList
> and it says postgis (now uninstallable)
> thanks for your help alex.
> -assad
> On 1/13/06, alex bodnaru <alexbodn at 012.net.il> wrote:
>>what debian version do you have?
>>>I took a closer look. The directory /usr/include/postgresql/ exists
>>>and postgres.h is in that directory.
>>>There is no 8.1 directory.
>>>How do I mend the problem (tell pg-config that the directory is somewhere else)
>>>much thanks and sorry for the initial lookover of the file existing.
>>>-assad
>>>On 1/13/06, strk at refractions.net <strk at refractions.net> wrote:
>>>>This is your problem:
>>>>gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.0"'
>>>>-DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
>>>>-DPOSTGIS_SCRIPTS_VERSION='"1.1.0"' -DPOSTGIS_BUILD_DATE='"2006-01-12
>>>>16:30:40"' -I/usr/local/include -DUSE_PROJ
>>>>-I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1 -DUSE_STATS
>>>>-Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/local/include -c
>>>>-o liblwgeom.o liblwgeom.c
>>>>In file included from liblwgeom.c:26:
>>>>lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
>>>>Do you stil confirm that this file exist:
>>>> /usr/include/postgresql/8.1/server/postgres.h
>>>>--strk;
>>>>On Fri, Jan 13, 2006 at 01:15:45AM -0700, Assad Jarrahian wrote:
>>>>>strk, stefano, david .... please help. Am stuck.
>>>>>Thanks.
>>>>>-assad
>>>>>On 1/12/06, Assad Jarrahian <jarraa at gmail.com> wrote:
>>>>>>I pasted the complete output below. Thanks for your help.
>>>>>>make -C lwgeom
>>>>>>make[1]: Entering directory `/packages/postgis-1.1.0/lwgeom'
>>>>>>cpp -P -traditional-cpp -DUSE_VERSION=81 lwpostgis.sql.in | sed -e
>>>>>>'s:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1
>>>>>>USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:1.1.0:g;s/@POSTGIS_BUILD_DATE@/2006-01-12
>>>>>>16:30:40/g' | grep -v '^#' > ../lwpostgis.sql
>>>>>>/usr/bin/perl ../utils/postgis_proc_upgrade.pl ../lwpostgis.sql >
>>>>>>../lwpostgis_upgrade.sql
>>>>>>-o measures.o measures.c
>>>>>>-o box2d.o box2d.c
>>>>>>-o ptarray.o ptarray.c
>>>>>>ptarray.c: In function 'ptarray_segmentize2d':
>>>>>>ptarray.c:223: warning: dereferencing type-punned pointer will break
>>>>>>strict-aliasing rules
>>>>>>-o lwgeom_api.o lwgeom_api.c
>>>>>>lwgeom_api.c: In function 'lwgeom_getpoint_inspected':
>>>>>>lwgeom_api.c:974: warning: pointer targets in assignment differ in signedness
>>>>>>lwgeom_api.c:981: warning: pointer targets in passing argument 1 of
>>>>>>'lwpoint_deserialize' differ in signedness
>>>>>>lwgeom_api.c: In function 'lwgeom_getpoly':
>>>>>>lwgeom_api.c:1051: warning: pointer targets in assignment differ in signedness
>>>>>>lwgeom_api.c:1057: warning: pointer targets in passing argument 1 of
>>>>>>'lwpoly_deserialize' differ in signedness
>>>>>>lwgeom_api.c: In function 'lwgeom_getpoly_inspected':
>>>>>>lwgeom_api.c:1069: warning: pointer targets in assignment differ in signedness
>>>>>>lwgeom_api.c:1076: warning: pointer targets in passing argument 1 of
>>>>>>lwgeom_api.c: In function 'lwgeom_getsubgeometry':
>>>>>>lwgeom_api.c:1097: warning: pointer targets in assignment differ in signedness
>>>>>>lwgeom_api.c:1099: warning: pointer targets in return differ in signedness
>>>>>>lwgeom_api.c: In function 'printPA':
>>>>>>lwgeom_api.c:1636: warning: pointer targets in assignment differ in signedness
>>>>>>lwgeom_api.c:1637: warning: pointer targets in assignment differ in signedness
>>>>>>lwgeom_api.c: In function 'printBYTES':
>>>>>>lwgeom_api.c:1674: warning: pointer targets in passing argument 2 of
>>>>>>'deparse_hex' differ in signedness
>>>>>>lwgeom_api.c: In function 'pglwgeom_from_ewkb':
>>>>>>lwgeom_api.c:1775: warning: pointer targets in passing argument 2 of
>>>>>>lwgeom_api.c: In function 'lwgeom_typeflags':
>>>>>>lwgeom_api.c:2000: warning: pointer targets in return differ in signedness
>>>>>>lwgeom_api.c: In function 'parse_lwgeom_wkt':
>>>>>>lwgeom_api.c:2242: warning: pointer targets in passing argument 1 of
>>>>>>'parse_lwg' differ in signedness
>>>>>>lwgeom_api.c: In function 'box2df_to_box3d':
>>>>>>lwgeom_api.c:220: warning: 'result.zmin' is used uninitialized in this function
>>>>>>lwgeom_api.c:220: warning: 'result.zmax' is used uninitialized in this function
>>>>>>lwgeom_api.c:220: warning: 'result.ymax' is used uninitialized in this function
>>>>>>lwgeom_api.c:220: warning: 'result.xmax' is used uninitialized in this function
>>>>>>lwgeom_api.c:220: warning: 'result.ymin' is used uninitialized in this function
>>>>>>lwgeom_api.c:220: warning: 'result.xmin' is used uninitialized in this function
>>>>>>-o lwgeom.o lwgeom.c
>>>>>>lwgeom.c: In function 'lwgeom_to_ewkb':
>>>>>>lwgeom.c:409: warning: pointer targets in return differ in signedness
>>>>>>-o lwpoint.o lwpoint.c
>>>>>>-o lwline.o lwline.c
>>>>>>-o lwpoly.o lwpoly.c
>>>>>>lwpoly.c: In function 'lwpoly_deserialize':
>>>>>>lwpoly.c:80: warning: pointer targets in assignment differ in signedness
>>>>>>lwpoly.c:90: warning: pointer targets in assignment differ in signedness
>>>>>>lwpoly.c:105: warning: pointer targets in passing argument 1 of
>>>>>>'get_int32' differ in signedness
>>>>>>lwpoly.c:113: warning: pointer targets in passing argument 1 of
>>>>>>'get_uint32' differ in signedness
>>>>>>lwpoly.c:121: warning: pointer targets in passing argument 1 of
>>>>>>lwpoly.c:124: warning: pointer targets in passing argument 1 of
>>>>>>'pointArray_construct' differ in signedness
>>>>>>-o lwmpoint.o lwmpoint.c
>>>>>>-o lwmline.o lwmline.c
>>>>>>-o lwmpoly.o lwmpoly.c
>>>>>>-o lwcollection.o lwcollection.c
>>>>>>-o wktunparse.o wktunparse.c
>>>>>>-o lwgparse.o lwgparse.c
>>>>>>-o wktparse.tab.o wktparse.tab.c
>>>>>>wktparse.y: In function 'lwg_parse_yyparse':
>>>>>>wktparse.y:43: warning: pointer targets in passing argument 1 of
>>>>>>'alloc_wkb' differ in signedness
>>>>>>-o lex.yy.o lex.yy.c
>>>>>>lex.yy.c:3044: warning: 'yyunput' defined but not used
>>>>>>-o vsprintf.o vsprintf.c
>>>>>>lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
>>>>>>lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
>>>>>>lwgeom_pg.h:28: error: syntax error before 'getGeometryOID'
>>>>>>lwgeom_pg.h:28: warning: type defaults to 'int' in declaration of
>>>>>>'getGeometryOID'
>>>>>>lwgeom_pg.h:28: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:35: error: syntax error before '*' token
>>>>>>lwgeom_pg.h:36: error: syntax error before 'box2df_to_box'
>>>>>>lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
>>>>>>'box2df_to_box'
>>>>>>lwgeom_pg.h:36: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:37: error: syntax error before 'BOX'
>>>>>>lwgeom_pg.h:40: error: syntax error before 'BOX2D_same'
>>>>>>lwgeom_pg.h:40: warning: type defaults to 'int' in declaration of 'BOX2D_same'
>>>>>>lwgeom_pg.h:40: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:40: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:41: error: syntax error before 'BOX2D_overlap'
>>>>>>lwgeom_pg.h:41: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2D_overlap'
>>>>>>lwgeom_pg.h:41: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:41: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:42: error: syntax error before 'BOX2D_overleft'
>>>>>>lwgeom_pg.h:42: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2D_overleft'
>>>>>>lwgeom_pg.h:42: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:42: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:43: error: syntax error before 'BOX2D_left'
>>>>>>lwgeom_pg.h:43: warning: type defaults to 'int' in declaration of 'BOX2D_left'
>>>>>>lwgeom_pg.h:43: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:43: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:44: warning: type defaults to 'int' in declaration of 'BOX2D_right'
>>>>>>lwgeom_pg.h:44: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:44: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:45: error: syntax error before 'BOX2D_overright'
>>>>>>lwgeom_pg.h:45: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2D_overright'
>>>>>>lwgeom_pg.h:45: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:45: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:46: error: syntax error before 'BOX2D_overbelow'
>>>>>>lwgeom_pg.h:46: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2D_overbelow'
>>>>>>lwgeom_pg.h:46: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:46: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:47: error: syntax error before 'BOX2D_below'
>>>>>>lwgeom_pg.h:47: warning: type defaults to 'int' in declaration of 'BOX2D_below'
>>>>>>lwgeom_pg.h:47: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:47: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:48: error: syntax error before 'BOX2D_above'
>>>>>>lwgeom_pg.h:48: warning: type defaults to 'int' in declaration of 'BOX2D_above'
>>>>>>lwgeom_pg.h:48: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:48: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:49: error: syntax error before 'BOX2D_overabove'
>>>>>>lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2D_overabove'
>>>>>>lwgeom_pg.h:49: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:49: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:50: error: syntax error before 'BOX2D_contained'
>>>>>>lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2D_contained'
>>>>>>lwgeom_pg.h:50: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:50: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:51: error: syntax error before 'BOX2D_contain'
>>>>>>lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2D_contain'
>>>>>>lwgeom_pg.h:51: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:51: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:52: error: syntax error before 'BOX2D_intersects'
>>>>>>lwgeom_pg.h:52: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2D_intersects'
>>>>>>lwgeom_pg.h:52: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:52: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:53: error: syntax error before 'BOX2D_union'
>>>>>>lwgeom_pg.h:53: warning: type defaults to 'int' in declaration of 'BOX2D_union'
>>>>>>lwgeom_pg.h:53: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:53: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:55: error: syntax error before 'LWGEOM_same'
>>>>>>lwgeom_pg.h:55: warning: type defaults to 'int' in declaration of 'LWGEOM_same'
>>>>>>lwgeom_pg.h:55: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:55: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:56: error: syntax error before 'BOX3D_construct'
>>>>>>lwgeom_pg.h:56: warning: type defaults to 'int' in declaration of
>>>>>>'BOX3D_construct'
>>>>>>lwgeom_pg.h:56: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:56: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:57: error: syntax error before 'BOX2DFLOAT4_ymin'
>>>>>>lwgeom_pg.h:57: warning: type defaults to 'int' in declaration of
>>>>>>'BOX2DFLOAT4_ymin'
>>>>>>lwgeom_pg.h:57: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:57: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:59: error: syntax error before 'LWGEOM_force_2d'
>>>>>>lwgeom_pg.h:59: warning: type defaults to 'int' in declaration of
>>>>>>'LWGEOM_force_2d'
>>>>>>lwgeom_pg.h:59: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:59: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:60: error: syntax error before 'LWGEOM_force_3dm'
>>>>>>lwgeom_pg.h:60: warning: type defaults to 'int' in declaration of
>>>>>>'LWGEOM_force_3dm'
>>>>>>lwgeom_pg.h:60: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:60: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:61: error: syntax error before 'LWGEOM_force_3dz'
>>>>>>lwgeom_pg.h:61: warning: type defaults to 'int' in declaration of
>>>>>>'LWGEOM_force_3dz'
>>>>>>lwgeom_pg.h:61: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:61: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:62: error: syntax error before 'LWGEOM_force_4d'
>>>>>>lwgeom_pg.h:62: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:63: error: syntax error before 'LWGEOM_force_collection'
>>>>>>lwgeom_pg.h:63: warning: type defaults to 'int' in declaration of
>>>>>>lwgeom_pg.h:63: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:63: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:64: error: syntax error before 'LWGEOM_force_multi'
>>>>>>lwgeom_pg.h:64: warning: type defaults to 'int' in declaration of
>>>>>>lwgeom_pg.h:64: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:64: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:66: error: syntax error before 'LWGEOMFromWKB'
>>>>>>lwgeom_pg.h:66: warning: type defaults to 'int' in declaration of
>>>>>>'LWGEOMFromWKB'
>>>>>>lwgeom_pg.h:66: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:66: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:67: error: syntax error before 'WKBFromLWGEOM'
>>>>>>lwgeom_pg.h:67: warning: type defaults to 'int' in declaration of
>>>>>>'WKBFromLWGEOM'
>>>>>>lwgeom_pg.h:67: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:67: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:69: error: syntax error before 'LWGEOM_getBBOX'
>>>>>>lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
>>>>>>'LWGEOM_getBBOX'
>>>>>>lwgeom_pg.h:69: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:69: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:70: error: syntax error before 'LWGEOM_addBBOX'
>>>>>>lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
>>>>>>'LWGEOM_addBBOX'
>>>>>>lwgeom_pg.h:70: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:70: warning: data definition has no type or storage class
>>>>>>lwgeom_pg.h:71: error: syntax error before 'LWGEOM_dropBBOX'
>>>>>>lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
>>>>>>'LWGEOM_dropBBOX'
>>>>>>lwgeom_pg.h:71: warning: parameter names (without types) in function declaration
>>>>>>lwgeom_pg.h:71: warning: data definition has no type or storage class
>>>>>>liblwgeom.c: In function 'trim_trailing_zeros':
>>>>>>liblwgeom.c:158: warning: implicit declaration of function 'strchr'
>>>>>>liblwgeom.c:158: warning: incompatible implicit declaration of
>>>>>>built-in function 'strchr'
>>>>>>liblwgeom.c:163: warning: implicit declaration of function 'strlen'
>>>>>>liblwgeom.c:163: warning: incompatible implicit declaration of
>>>>>>built-in function 'strlen'
>>>>>>make[1]: *** [liblwgeom.o] Error 1
>>>>>>On 1/12/06, strk at refractions.net <strk at refractions.net> wrote:
>>>>>>>Please show some more lines - starting right before the *first*
>>>>>>>warning during make - after a make clean.
>>>>>>>--strk;
>>>>>>>On Thu, Jan 12, 2006 at 08:39:25AM -0700, Assad Jarrahian wrote:
>>>>>>>>I am talking about the latest release 1.10
>>>>>>>>Yes it seems that I can find postgres.h
>>>>>>>>pg_config --includedir-server
>>>>>>>>What should I do with it?
>>>>>>>>thanks.
>>>>>>>>-assad
>>>>>>>>>You're talking about postgis version ?
>>>>>>>>>Can you find postgres.h under `/usr/bin/pg_config --includedir-server` ?
>>>>>>>>>--strk;
>>>>>>>>>On Thu, Jan 12, 2006 at 01:46:17AM -0700, Assad Jarrahian wrote:
>>>>>>>>>>David and all,
>>>>>>>>>> Thanks. I got everything installed, but when installing postgis I
>>>>>>>>>>got errors (see below).
>>>>>>>>>>The configure summary:
>>>>>>>>>>SUMMARY
>>>>>>>>>>HOST_OS: linux-gnu
>>>>>>>>>> PGSQL: /usr/bin/pg_config
>>>>>>>>>> GEOS: /usr/local/bin/geos-config (with C-API)
>>>>>>>>>> PROJ: dir=/usr/local
>>>>>>>>>> ICONV: 1
>>>>>>>>>>PORTNAME: linux
>>>>>>>>>> PREFIX: /usr
>>>>>>>>>> EPREFIX: ${prefix}
>>>>>>>>>> DOC: /usr/share/doc/postgresql-doc-8.1
>>>>>>>>>> DATA: /usr/share/postgresql/8.1/postgresql/contrib
>>>>>>>>>> MAN: /usr/share/postgresql/8.1/man
>>>>>>>>>> BIN: /usr/lib/postgresql/8.1/bin
>>>>>>>>>> EXT: /usr/lib/postgresql/8.1/lib (\$$libdir)
>>>>>>>>>>and the errors:
>>>>>>>>>>'getGeometryOID'
>>>>>>>>>>'box2df_to_box'
>>>>>>>>>>'BOX2D_overlap'
>>>>>>>>>>'BOX2D_overleft'
>>>>>>>>>>lwgeom_pg.h:44: error: syntax error before 'BOX2D_right'
>>>>>>>>>>'BOX2D_overright'
>>>>>>>>>>'BOX2D_overbelow'
>>>>>>>>>>'BOX2D_overabove'
>>>>>>>>>>'BOX2D_contained'
>>>>>>>>>>'BOX2D_contain'
>>>>>>>>>>'LWGEOM_getBBOX'
>>>>>>>>>>'LWGEOM_addBBOX'
>>>>>>>>>>'LWGEOM_dropBBOX'
>>>>>>>>>>make: *** [liblwgeom] Error 2
>>>>>>>>>>On 1/12/06, Stefano Costa <steko at iosa.it> wrote:
>>>>>>>>>>>Il giorno gio, 12/01/2006 alle 00.28 -0700, Assad Jarrahian ha scritto:
>>>>>>>>>>>>hey david and all,
>>>>>>>>>>>> thanks for replying.
>>>>>>>>>>>>I tried the first step and it raised an exception
>>>>>>>>>>>>sudo apt-get postgresql-dev
>>>>>>>>>>>>E: Invalid operation postgresql-dev
>>>>>>>>>>>You should add an "install" just like this:
>>>>>>>>>>>sudo apt-get install postgresql-dev
>>>>>>>>>>>Regards,
>>>>>>>>>>>Stefano
>>>>>>>>>>>Stefano Costa
>>>>>>>>>>>http://www.iosa.it Software Open Source per l'Archeologia
>>>>>>>>>>>Jabber: steko at jabber.linux.it
>>>>>>>>>>>GnuPG Key ID 1024D/0xD0D30245
>>>>>>>>>>>Linux Registered User #385969 counter.li.org
>>>>>>>>>>>_______________________________________________
>>>>>>>>>>>postgis-users mailing list
>>>>>>>>>>>postgis-users at postgis.refractions.net
>>>>>>>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>>>>>/"\ ASCII Ribbon Campaign
>>>>>>>>>\ / Respect for low technology.
>>>>>>>>> X Keep e-mail messages readable by any computer system.
>>>>>>>>>/ \ Keep it ASCII.
>>>>>>>/ \ Keep it ASCII.
>>>>/ \ Keep it ASCII.
Type: application/x-tar
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060114/f580cc69/attachment.tar>
