[postgis-users] typecast from point to geometry for distance_sphere
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jan 14 08:31:48 PST 2006
Assad Jarrahian wrote:
> I am using postgis 1.1.0 and am trying to test out the
> distance_sphere() function.
> SELECT distance_sphere((point(12,23)), point(12,24));
> ERROR: function distance_sphere(point, point) does not exist
> HINT: No function matches the given name and argument types. You may
> need to add explicit type casts.
> So I guess I need a type cast (how do I do that?) or maybe I am doing
> something wrong (I noticed all the methods that take any spatial
> argument are of type geometry).
> I thought that point was of geometry type, I guess I maybe wrong.
point() is not a postgis geometry function. You need to use
makepoint(x,y) to get a geometry object.
select distance_sphere(makepoint(12, 33), makepoint(12,24));
should work and will return approximate 69 miles in meters because it
expects points in decimal degrees makepoint(longitude,latitude). On
degree is a little more the 69 miles at the equator.
-Steve
