[postgis-users] (no subject)
Blair Zajac blair at orcaware.com
Sat Jan 14 10:23:12 PST 2006
Peter König wrote:
> Hi all,
> I am trying to install PostGIS on an Ubuntu-Linux for two days now -
> unfortunatly without success. Since I saw some postings here about
> successful installations on Ubuntu and the AMD64-architecture, maybe there
> is someone who could give me a hint.
> The first attemt was to install Postgres via the source-distribution:
> apt-get -b source postgresql-8.0 postgresql-server-dev-8.0
> I also installed proj and geos.
> Then I copied PostGIS-archive (tried 1.1 and 1.06) to the pg-contrib-dir
> in the "build-tree"-path and extracted them there. After configuring
> (1.1)/ modifiying the Makefile.config (1.0.6), proj and geos were
> correctly found, "make" and "make install" proceeded without errors (but
> many warnings [*] ) and I got liblwgeom.so.xx in
> /usr/lib/postgresql/8.0/lib (liblwgeom.so.1 and liblwgeom.so in the same
> dir were link to it)
> Then I chowned the regess-dir to postgres:postgres and started "make" in
> that dir (as user "postgres") to perform the tests. V 1.0.6 produced a lot
> of errors complaining about an uninstalled "geos" and with V 1.1.0 I
> received the message, that 8 of 9 tests have failed. Although I see the
> PostGIS-Funtions in a new db they do not work.
> Another approach was to try to install the ubuntu deb-package of postgis
> 1.0.6 from arocaware, but it also failed.
What was the problem with these packages?
You could try to rebuild using these sources, as they do successfully build on Ubuntu.
Regards,
Blair
Blair Zajac, Ph.D.
<blair at orcaware.com>
Subversion training and consulting
http://www.orcaware.com/svn/
