[postgis-users] Problem on ./configure
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Tue Jan 17 05:05:10 PST 2006
Thank you strk,
But now the problem is with proj4 (I did install it but the postgis does
not find it out).
I use:
[root at dc postgis-1.1.0]# ./configure --with-pgsql=/usr/local/pgsql/bin
--with-proj=/usr/bin
And the error at the end was:
checking for proj... /usr/bin/proj
configure: error: Can't find proj dir.
Sincerely
Ezequias
strk at refractions.net escreveu:
> /configure looks for pg_config.
> Is pg_config in your PATH ?
> If it is not you can provide full path to it using
> the --with-pgsql=<path> switch .
> --strk;
> On Mon, Jan 16, 2006 at 04:12:12PM -0300, Ezequias Rodrigues da Rocha wrote:
>>>> Command: ./configure
>>>> Error: configure: error: PostgreSQL is required by PostGIS
> postgis-users mailing list
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
