[postgis-users] Problem on ./configure
strk at refractions.net
Tue Jan 17 05:38:46 PST 2006
On Tue, Jan 17, 2006 at 10:05:10AM -0300, Ezequias Rodrigues da Rocha wrote:
> Thank you strk,
> But now the problem is with proj4 (I did install it but the postgis does
> not find it out).
> I use:
> [root at dc postgis-1.1.0]# ./configure --with-pgsql=/usr/local/pgsql/bin
> --with-proj=/usr/bin
> And the error at the end was:
> checking for proj... /usr/bin/proj
> configure: error: Can't find proj dir.
That message comes out if PROJ_DIR/include/projects.h
is not found, where PROJ_DIR in your case should be
set to "/usr". So, can you find projects.h ?
Where is it ?
--strk;
