[postgis-users] Problem on ./configure
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Tue Jan 17 06:16:57 PST 2006
The file project.h does not exist on my system archive.
Could you tell me what I did wrong to do not install the complete proj4 ?
I used this file:
proj-4.4.8-1.i386.rpm
Sincerely
Ezequias
strk at refractions.net escreveu:
> On Tue, Jan 17, 2006 at 10:05:10AM -0300, Ezequias Rodrigues da Rocha wrote:
>> Thank you strk,
>> But now the problem is with proj4 (I did install it but the postgis does
>> not find it out).
>> I use:
>> [root at dc postgis-1.1.0]# ./configure --with-pgsql=/usr/local/pgsql/bin
>> --with-proj=/usr/bin
>> And the error at the end was:
>> checking for proj... /usr/bin/proj
>> configure: error: Can't find proj dir.
> That message comes out if PROJ_DIR/include/projects.h
> is not found, where PROJ_DIR in your case should be
> set to "/usr". So, can you find projects.h ?
> Where is it ?
> --strk;
> postgis-users mailing list
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
