[postgis-users] Interpolate Point
Chris Matheson chris at centralfrontenac.com
Tue Jan 17 11:49:52 PST 2006
You can extract a linestring from a multilinestring using the
geometryN(geometry, n) where n denotes the index of the linestring you
wish to extract.  I have this problem often when importing shapefiles
from ESRIs software, single lines suddenly become multilinestrings.  use
geometryN(the_geom, 1) to get them back as lines.
Hope this is helpful.
Chris M
sergio at labtrans.ufsc.br wrote:
>Hello again,
>   My problem is the following one:  I need to interpolate a point with a
>line, being that for this I possess two tables, I was trying to use the
>following command:
>  - SELECT line_interpolate_point(f.geom, line_locate_point(f.geom,
>c.geom)) from railroad f, city c;
>  Where geom of the railroad is a field MULTILINESTRING and geom of the city
>is a field POINT, this command does not function, therefore the first
>argument of line_locate_point must be LINE and not MULTILINESTRING, would
>like to know if somebody possue some suggestion of as I can tranformar
>this MULTILINESTRING in LINE or if exists some function that finds the
>line next to a point and that it returns as resulted the point where the
>original point is interpolated with the line.
>grateful,
>Sérgio Zarth Jr.
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
