[postgis-users] postgis installation with suse linux
Aaron Koning aaronkoning at gmail.com
Wed Jan 25 00:26:08 PST 2006
1. Check what version of postgresql you have with the command 'psql
--version'.
2. Then download the source code for that version of postgresql and
configure and make it.
3. Then you will have a contrib directory to untar postgis into.
Aaron
On 1/25/06, mailingliste_gis at gmx.de <mailingliste_gis at gmx.de> wrote:
> Dear List,
> I use the German SUSE Linux 9.3. I installed Postgresql with the help of
> rpm. Now I want to compile and install Postgis, but the Path on SUSE Linux
> for Postgres are a little bit different to other Linux-systems.
> In your installation you wrote:
> Un-tar the PostGIS tar-ball in the 'contrib' directory of your PostgreSQL
> source tree. You must untar the PostGIS source there or the Makefile will
> not work. You must have the PL/pgSQL prodedural language installed before
> installing PostGIS.
> But there is no 'contrib' directory because I installed Postgres with rpm.
> What can I do?
> Where must I place the sourcecode to compile?
> Thank you for your help.
> samoth
> DSL-Aktion wegen großer Nachfrage bis 28.2.2006 verlängert:
> GMX DSL-Flatrate 1 Jahr kostenlos* http://www.gmx.net/de/go/dsl
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060125/b94b5244/attachment.html>
