[postgis-users] postgis installation with suse linux
Frank Koormann
frank.koormann at intevation.de
Wed Jan 25 01:44:00 PST 2006
Samoth,
* mailingliste_gis at gmx.de <mailingliste_gis at gmx.de> [060125 09:21]:
> I use the German SUSE Linux 9.3. I installed Postgresql with the help of
> rpm. Now I want to compile and install Postgis, but the Path on SUSE Linux
> for Postgres are a little bit different to other Linux-systems.
> But there is no 'contrib' directory because I installed Postgres with rpm.
> What can I do?
> Where must I place the sourcecode to compile?
AFAIK SuSE 9.3 comes with PostgreSQL 8.0.1. With the current
PostGIS-package (version 1.1.1) installing the corresponding
-devel package from rpm should be sufficient, you shouldn't need to
configure and build the entire postgresql:
- Unpack your postgis-package and run
./configure --with-pgsql=<path to pg_config>
- Proceed as usual with make, make install, etc.
HTH,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
