[postgis-users] Topology
Paul Ramsey pramsey at refractions.net
Wed Jul 12 14:45:20 PDT 2006
See http://postgis.refractions.net/support/wiki/index.php?PostgisTopology
This is based on a draft ISO SQL/MM document which had some topology
ideas in it that seemed worth following. We also aren't above copying
aspects of the Oracle implementation if that makes sense too.
The draft topology information is in the CVS code base, in the aptly
named "topology" directory.
Paul
Brent Wood wrote:
> --- Paul Ramsey <pramsey at refractions.net> wrote:
>> I don't know why one of these was never started, but here it is:
>> http://postgis.refractions.net/support/wiki/index.php?WishList
> Thanks for the facility!
> Before I start adding stuff here, is there anywhere I can read up on any
> projects looking at adding/creating a topological spatial data storage system?
> I've seen occasional mentions of such work from Refractions, and would like to
> see more topological support in PostGIS (though this may not be straightforward
> under the SFS model).
> Cheers,
>    Brent Wood
> postgis-users mailing list
