[postgis-users] ERROR: Operation on two GEOMETRIES withdifferentSRIDs
Johan V
aragorn_jv at yahoo.com
Fri Jul 14 06:30:58 PDT 2006
Hi Mark,
Here are the descriptions of the tables (in the same database running
POSTGIS 0.8.2):
[database_x]=# \d reflijst
Table "public.reflijst"
Column | Type | Modifiers
artid | integer |
titre | text |
annee | integer |
volume | character varying |
firstpage | character varying |
auteurs | text |
publica | text |
strat | character varying |
domg_ol | character varying |
xlambert | bigint |
ylambert | bigint |
numcarte | integer |
the_geom | geometry |
Check constraints: "$1" (srid(the_geom) = 103300)
"$2" ((geometrytype(the_geom) =
'MULTIPOLYGON'::text) OR (the_geom IS NULL))
[database_x]=# \d gnosbgm
Table "public.gnosbgm"
id | numeric(28,6) |
gemeente | character varying(254) |
x | numeric(28,6) |
y | numeric(28,6) |
z | numeric(28,6) |
kaart | character varying(254) |
logdiepte | numeric(28,6) |
bgdnr | character varying(254) |
bgdcode | character varying(254) |
refer | character varying(254) |
hotlink | character varying(254) |
imagepath1 | character varying(254) |
logcomp | character varying(254) |
date | character varying(10) |
tert_plio | character varying(1) |
tert_mio | character varying(1) |
tert_paleo | character varying(1) |
tert_eoc | character varying(1) |
tert_oligo | character varying(1) |
primair | character varying(1) |
secundair | character varying(1) |
tertiair | character varying(1) |
quartair | character varying(1) |
Indexes: sidx_gnosbgm gist (the_geom)
"$2" ((geometrytype(the_geom) = 'POINT'::text) OR
(the_geom IS NULL))
And the two sql statements:
SELECT the_geom FROM gnosbgm WHERE ((the_geom && 'POLYGON
((33595.443392445566 15067.465440617714,281187.7093687274
254932.5345593823,33595.443392445566
254932.5345593823,33595.443392445566 15067.465440617714))'))
SELECT the_geom FROM reflijst WHERE ((the_geom && 'POLYGON
They are just the same, only the first give me the required answer!
Grz,
Johan
2006/7/14, Mark Cave-Ayland <m.cave-ayland at webbased.co.uk>:
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> > bounces at postgis.refractions.net] On Behalf Of Johan V
> > Sent: 14 July 2006 12:46
> > To: postgis-users at postgis.refractions.net
> > Subject: Re: [postgis-users] ERROR: Operation on two GEOMETRIES
> > withdifferentSRIDs
> > Hi Mark and others,
> > Yes the geometry created on the fly is -1, but this same sql statement
> > (with the on the fly created geometry) does work on another table with
> > SRID=103300, but not on this one.
> > I need this specific sql statement because it is a statement that is
> > issued by a software product that makes a WFS/WMS service (GIS Service
> > over the internet) of this table.
> > So do I have to change or check some thing in the table to be able to
> > use this kind of sql statement:
> > SELECT the_geom FROM table_x WHERE ((the_geom && 'POLYGON((...))')).
> > Greetz,
> > Johan.
> Hi Johan,
> Hmmm that makes it a bit more tricky. Unfortunately the SQL being issued is
> relying on the implicit cast in PostgreSQL rather than using
> GeomFromText()/setSRID() as documented and so its behaviour may change
> across PostgreSQL/PostGIS versions - if you do get a chance to update the
> SQL in your client software, I would highly recommend it.
> As for the symptoms you are seeing, I am slightly baffled - can you post the
> output of \d <table> for one of your tables that works and your new one that
> doesn't, the exact SELECT queries being executed on each table, and can you
> confirm that both tables are in the same database running the same version
> of PostGIS?
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it or
> use it for any purpose nor disclose or distribute its contents to any other
> person.
> postgis-users mailing list
