[postgis-users] PostGIS kills all connections to the PostgreSQL server
Michael de Armas (Micotan)
michael.dearmas at micotan.com
Wed Jul 19 14:50:45 PDT 2006
Here is the SQL statement including the geometry, I could send the geometry
in a Shape file if you prefer it. The connections to PostgreSQL are killed
in our server if we try a buffer of 33000 feet (or more) instead the 20000
in this statement. This SQL takes about 10 minutes to execute if the server
doesn't have a significant workload.
SELECT astext(buffer(transform(GeomFromText('POLYGON((-95.2735521252333
31.5921192418925, -95.2738493841262 31.5916690928855, -95.2739103986093
31.5913295700205, -95.2737579942557 31.5910472689181, -95.2737240199256
31.5909818889333, -95.2736816781815 31.5909004066093, -95.2731703057053
31.5904407382818, -95.2728883794865 31.5903320286177, -95.272499179001
31.5901794264737, -95.2721479981567 31.590150823275, -95.2717286082265
31.5903091340987, -95.2708512959093 31.590990088193, -95.2705002361323
31.591150304539, -95.2701720640804 31.5912399098586, -95.2698796667682
31.5911564158898, -95.2698287281112 31.591032038469, -95.2697906542424
31.590120314661, -95.2697066879102 31.5897903569298, -95.2695465643176
31.5894699168305, -95.2691114582764 31.5889911478332, -95.2688599509455
31.5887107768726, -95.2688216743547 31.5885601167547, -95.268867409026
31.5882205918316, -95.2690430562802 31.587835332062, -95.269203248939
31.5874691156336, -95.2691801954093 31.5872402257266, -95.2691204149226
31.5871372712009, -95.269058364418 31.5870304069582, -95.2686079366951
31.5867595466644, -95.2680968305595 31.586669909849, -95.2679899284669
31.5866107933612, -95.2684479909532 31.5861091486923, -95.2683564186029
31.5859298800191, -95.2676696635009 31.5854530124918, -95.2674255287337
31.5851783591339, -95.2674865693348 31.5850696715542, -95.2674179571837
31.5848503065999, -95.2671280501624 31.5845813938153, -95.2670900221173
31.5844497957102, -95.2668610753555 31.5841693912005, -95.2665328312381
31.5839900870983, -95.266105565804 31.5839462237353, -95.2655714706698
31.5838737545162, -95.2654268215301 31.5838527708591, -95.2648619540521
31.5836963434624, -95.2646788974744 31.5835991046938, -95.2643204374066
31.5829906621632, -95.2642976110129 31.5823993730684, -95.2636795991499
31.5816783863293, -95.2631137260921 31.5813107203226, -95.2624129330493
31.5811290819338, -95.2619095805036 31.5808391686437, -95.2616043249673
31.5805320848214, -95.2613828759644 31.5803108231121, -95.2610930456063
31.5799694168984, -95.2606885853849 31.5791492490472, -95.26064311118
31.5789184581218, -95.2605209897441 31.5783252704962, -95.2606123061198
31.5778808705014, -95.2605515682793 31.5775699553133, -95.260292208586
31.5772152067405, -95.2600098008491 31.5769500710742, -95.2597425961493
31.5768298995335, -95.2589111883632 31.5766525129946, -95.2580185716973
31.5764599060113, -95.2573014923849 31.5764808629741, -95.2572096941377
31.5764179160804, -95.2569731140498 31.5763607058798, -95.2563629702373
31.5759391651818, -95.2554170102196 31.5750598828415, -95.2548523584842
31.5746860578578, -95.2546921576433 31.5746307578475, -95.2544172339518
31.5747108267951, -95.2540360905872 31.5750999497224, -95.2534788131226
31.5756607121319, -95.2532120489112 31.5760402753327, -95.2527236319757
31.5763301696614, -95.2524796262915 31.5763797903721, -95.2521978154632
31.5763846703643, -95.2519301558268 31.5763893047351, -95.2518308888817
31.5763625981183, -95.2516404681 31.576292060889, -95.2510298509544
31.5760707988705, -95.2505112913792 31.575399416042, -95.2500917067447
31.5753002076094, -95.2491988448707 31.5751209184307, -95.2483596756415
31.5751209257467, -95.2474365461017 31.5751495409422, -95.2468566957618
31.5750598960371, -95.2464522654907 31.5750904064063, -95.2462311206455
31.5751495282099, -95.2460097558087 31.5751495488871, -95.2457198148502
31.5751209015406, -95.2449417030218 31.5749092152837, -95.2428819184059
31.5745506428691, -95.2424469899447 31.5744209308474, -95.242141711108
31.5743694359619, -95.241782948658 31.5743408104345, -95.2412263221208
31.5743408305636, -95.2408980336563 31.5744094998184, -95.2407378846565
31.5744800511955, -95.2406236167335 31.5745506252862, -95.240531962072
31.574659327854, -95.2404405414982 31.5748901297333, -95.2404175636746
31.5758094877842, -95.2403564745766 31.5762195477556, -95.2402799915724
31.5763702233442, -95.2402116032432 31.5764408200683, -95.2400894622215
31.5764999449494, -95.2398680941936 31.5764999550705, -95.2393495028814
31.5764007405171, -95.2388306529885 31.5762195482364, -95.2381516747532
31.575910553593, -95.2373884173186 31.575620623366, -95.2369537170908
31.5753994081094, -95.2365266048234 31.5752506108911, -95.2361679608399
31.5751800469937, -95.235481115039 31.5751209363181, -95.2344514739549
31.5749092300422, -95.2341078390511 31.5748996821754, -95.2338027846415
31.5748596338301, -95.233222994423 31.5745792611661, -95.2324904894259
31.5743103091008, -95.2322312340296 31.574169173644, -95.231956352874
31.5740108509548, -95.2314073526861 31.5735607255611, -95.2310182133711
31.5733699728115, -95.230407824978 31.5732402838717, -95.2301786784138
31.5732193041015, -95.2297972455619 31.5732803110557, -95.2294922370342
31.5734291198973, -95.2290726611334 31.5737095052682, -95.2286911131943
31.573820113755, -95.2283170699202 31.5740203899478, -95.2281112073855
31.574190122843, -95.2279662001621 31.5743503531625, -95.2278596640146
31.5745296475049, -95.2278212300261 31.5746994078511, -95.2278517870333
31.5748500973037, -95.2279510569502 31.5750503684462, -95.2282181626764
31.5752506392459, -95.2283476518826 31.575300199425, -95.2287367955092
31.5753803271089, -95.2291794708227 31.5753498306117, -95.2298506204529
31.5755195413333, -95.2303773602825 31.5755691444091, -95.2304918048042
31.5755901218326, -95.2307279809812 31.5757102787417, -95.2311095816289
31.5761203879622, -95.2312317195503 31.5763301721793, -95.2312087236242
31.5765209324567, -95.2309874290848 31.5767803039668, -95.2307662130086
31.5769195609556, -95.2304915769729 31.5770092032658, -95.2301712498533
31.5770397325001, -95.2298887307758 31.5769996519061, -95.2296216984557
31.576900493766, -95.228119053971 31.5760898454449, -95.2275618351704
31.5759906528069, -95.2272569554669 31.5760498134495, -95.2271421886665
31.5761299274107, -95.2266235548866 31.5767898573854, -95.2262802318099
31.5771293658405, -95.2261430073714 31.5771999344611, -95.2259523091203
31.57719041546, -95.2256622028745 31.5770702234069, -95.2250366859802
31.5765895955228, -95.2242888914739 31.5765495356045, -95.2231596913035
31.5763091972772, -95.2230683563495 31.5762691586874, -95.2228163798025
31.5759697053321, -95.2225036216847 31.5757808603202, -95.2220991531305
31.5757408276904, -95.2216720859057 31.5757808485593, -95.2212983874867
31.5757293817739, -95.2208405575875 31.5752601505248, -95.2202606623787
31.5740204039979, -95.2200928936278 31.5739402749353, -95.2199935027825
31.5740108258808, -95.219619576205 31.5743503393869, -95.2195282634325
31.5743808933128, -95.2194364987881 31.5743808752726, -95.2193375215295
31.5743408075327, -95.2189101258949 31.573890680296, -95.2186203683371
31.5736694208796, -95.2183303958779 31.5734996931068, -95.2171097816165
31.5730800826503, -95.2161710776096 31.5729408282263, -95.2151183404047
31.5727805908999, -95.2141417249917 31.5724697127551, -95.213760335806
31.5723800438576, -95.2130431621548 31.5723400259326, -95.2127914115164
31.5723991541832, -95.2122194195881 31.5726604708251, -95.2113496196511
31.5729999677531, -95.2111511145522 31.5730094905045, -95.2108002635718
31.5728893209573, -95.2107011292765 31.572750107681, -95.211021576358
31.5722999692574, -95.2110900907467 31.5721092309501, -95.2111283213228
31.5719204127677, -95.2110978417255 31.5718002334434, -95.2108915310718
31.5717105899033, -95.2107468240242 31.5716991543775, -95.2100828951021
31.5717907032907, -95.2097473581007 31.5719299189693, -95.2095414621457
31.5720997079017, -95.2092818697968 31.5725402635743, -95.2091370629974
31.5727195783293, -95.2089385820227 31.5728702449508, -95.2088011302327
31.5729293716251, -95.2086717034156 31.572910305935, -95.2084732216979
31.5728092342725, -95.2081224516742 31.5724201138625, -95.2080534221058
31.5722904304732, -95.2079772498696 31.5719699827247, -95.208000144789
31.5717506397897, -95.2080686772439 31.5716304553103, -95.2081527326563
31.5715293878861, -95.2087095702678 31.571100243455, -95.2089919097838
31.5707893226493, -95.2090681704689 31.5706596408235, -95.2091218451503
31.5704994212543, -95.2091216377927 31.570369725322, -95.2090224489251
31.5701294014417, -95.2088165837633 31.5699996885924, -95.2085115517373
31.5699596659796, -95.2077867390811 31.5701007770509, -95.2075193425955
31.5701904255296, -95.2068101019156 31.5706405821845, -95.2061691053728
31.5711097562893, -95.204918095586 31.5719299468266, -95.2045365126709
31.5722293940607, -95.2043382639324 31.5724697114377, -95.2041932566417
31.5725898769662, -95.2040174688186 31.5726509175323, -95.2036436759396
31.5727195565212, -95.2028885273331 31.5729808735628, -95.2024763770713
31.5731697001287, -95.2022783169205 31.5732097811703, -95.2021330227116
31.5732097723798, -95.2020188459977 31.5731601552168, -95.2015989776247
31.5728397217354, -95.2013701732904 31.572710042882, -95.201011526479
31.572349532903, -95.2004471586605 31.5719509238806, -95.2003020903884
31.5718994235724, -95.199607992828 31.5718097660771, -95.198890548426
31.571649540151, -95.1979215837341 31.5713004989133, -95.197570670239
31.5712604551023, -95.1971130424932 31.5715904314359, -95.1970291577311
31.571680083106, -95.1969223806129 31.571870803305, -95.196861117814
31.5724296722392, -95.1969071121149 31.5727806300432, -95.1971281747637
31.5728492606817, -95.1976089094949 31.5729007583663, -95.1980131430473
31.5729999537783, -95.1982575933074 31.5730991520818, -95.1983718205895
31.5732497961278, -95.1983795167155 31.5733508902494, -95.1983184495965
31.5735606972966, -95.1982116253951 31.5737209471828, -95.1979522184738
31.5738506137068, -95.197166402045 31.5739402959968, -95.1967315507698
31.5740299396416, -95.1948622678886 31.5744800380545, -95.1946718032788
31.5744896211848, -95.1942672637622 31.5744590678701, -95.1941679795226
31.5744094847296, -95.1940383671487 31.5742607084621, -95.1939086221678
31.573879242329, -95.1937712773769 31.573669409452, -95.1936036570297
31.5734691745489, -95.1928405326066 31.5728893462639, -95.1927108388015
31.5728206447441, -95.1925126865965 31.5728702774967, -95.1923522401169
31.5729694260655, -95.1922838181701 31.5730399973712, -95.1922378905872
31.573150633181, -95.1922838253852 31.5732593789473, -95.1926423586001
31.5736999464535, -95.1927415528257 31.5739707969719, -95.1927719759524
31.5744209523949, -95.1925888740964 31.5752906942836, -95.1924820061152
31.5755691688572, -95.1921386462171 31.5759697003168, -95.1918333899572
31.5764198049226, -95.191680982131 31.5765895907536, -95.191482462696
31.5767402732132, -95.1897736486046 31.5778102799022, -95.1894380112601
31.5779895662271, -95.1890716001081 31.5781097233542, -95.187576429909
31.5784206247872, -95.1863176153551 31.578580876368, -95.1858672199812
31.578659045637, -95.1855619352736 31.5786705009277, -95.1853790683254
31.5786495418398, -95.185279878548 31.5785198330053, -95.1853712662136
31.5781593317968, -95.1852796840749 31.5779990944913, -95.1850661840373
31.5778694009842, -95.1847916767388 31.5778694315597, -95.1843339267584
31.5780906565916, -95.1835785355247 31.5785503369888, -95.1826706431861
31.5788993783707, -95.1820604206688 31.5791893039129, -95.1814423432986
31.5797100305035, -95.1812895196048 31.5798091939321, -95.1808317496764
31.5800304492835, -95.1805115678824 31.5801200842919, -95.1801300263419
31.5801506012739, -95.1797790457383 31.5800800377391, -95.1794890224568
31.5799903843802, -95.179237354864 31.5800704800609, -95.1790998620789
31.5802001699439, -95.1787874170521 31.5806007532769, -95.1786499612357
31.5808391481783, -95.178191955949 31.5814399702522, -95.1776731643779
31.5820407880985, -95.1774061563412 31.5824107984503, -95.1771163504121
31.5830592889059, -95.1767729044744 31.5837097171069, -95.1763536519167
31.5843391507078, -95.1760178280685 31.584489815226, -95.1749877066643
31.5847797224067, -95.174552867714 31.584859852816, -95.1740494777633
31.5848407667423, -95.1718522598633 31.5846805671715, -95.1715699218438
31.5846290787141, -95.1710892346023 31.584489811566, -95.1705476578704
31.5844306983389, -95.1702803945192 31.5843601173784, -95.1701507963789
31.5842895514711, -95.1699522129102 31.5840892818661, -95.1698913306604
31.5839195419544, -95.1698912498745 31.5838508744769, -95.1699678181918
31.5836696839393, -95.170227000757 31.5834598544406, -95.1703186228058
31.5833301689842, -95.1703108024691 31.5830993776142, -95.1700973115311
31.5829696593971, -95.1699525813847 31.5829505816488, -95.16922740854
31.5833606754893, -95.1691132597737 31.5834198203679, -95.1689377946998
31.5834503139033, -95.168510622931 31.583459858482, -95.1683805723978
31.5834293136892, -95.1681213711976 31.583280581494, -95.1680831699066
31.5831394152427, -95.1681290314479 31.583030715676, -95.1683500482956
31.5827102806327, -95.1685409838057 31.5823097090733, -95.1687394362132
31.5820598804822, -95.1688920655909 31.5819492227474, -95.169448949195
31.5818595727271, -95.1697312746992 31.5817394474777, -95.1698303843018
31.5817299057644, -95.1704101911164 31.5815391451397, -95.1705094414106
31.5814800410402, -95.1707077459454 31.5812797712501, -95.1707307073457
31.581209178775, -95.1706770178853 31.5810794914705, -95.1700668881287
31.5806407925367, -95.1693800177007 31.5802307103303, -95.1688080633644
31.5801601490636, -95.168670457719 31.5801200940151, -95.1683120882663
31.579919831842, -95.1681596791858 31.5798702512362, -95.1674574054086
31.5797901139946, -95.1669996360813 31.5796909153878, -95.166572664364
31.5795097445424, -95.1661376225467 31.5792198219962, -95.1658326503368
31.5790691510275, -95.1651000632062 31.5789603962854, -95.1644134035733
31.5788898408267, -95.1642379101771 31.5787105561341, -95.1637191346386
31.5780391796448, -95.1634217423798 31.5778198223623, -95.1620863419373
31.5774593143376, -95.1617814439531 31.5770892951363, -95.1617204667117
31.5769996700554, -95.1616899157709 31.576850892443, -95.1617202378194
31.575960162978, -95.16178885744 31.5757694081941, -95.1620484100225
31.575349795209, -95.1618880179176 31.5752601669482, -95.1615067439276
31.5748806238181, -95.1612929530973 31.5745391763059, -95.161247444947
31.5743293682435, -95.1613464921868 31.5739002462139, -95.1613768803958
31.57353021253, -95.1612776110227 31.573200236956, -95.1609268984662
31.5729694269587, -95.159972963562 31.5728301741655, -95.1597139352603
31.5727100543628, -95.1594316239039 31.5725498335526, -95.1581727498068
31.5714893312271, -95.1580734856017 31.5714397630736, -95.1578215941545
31.5713996877391, -95.1576691766415 31.5714206897233, -95.1574937098127
31.5715294020464, -95.1573564115125 31.5716705353249, -95.1573102892763
31.5717296542084, -95.1570282271888 31.5718994151198, -95.1565703123208
31.5720996798662, -95.156303530939 31.5721607083057, -95.1561737777608
31.572109218776, -95.1560212223052 31.5718994135963, -95.1560212101885
31.5717907079319, -95.1560593518633 31.5716991453394, -95.1563798163056
31.5713005037339, -95.1565627016762 31.570970541777, -95.1566160327803
31.5707798148151, -95.1565932393201 31.570629095788, -95.1564027638608
31.5705299594756, -95.156082245729 31.5705795235417, -95.1553114927579
31.5708598915772, -95.1550598857168 31.570899944904, -95.1548233504301
31.570920952699, -95.1546783378132 31.5708999580132, -95.1543732210864
31.5707607110366, -95.153763016591 31.5703105962245, -95.1533508144115
31.5701408354286, -95.1529466387355 31.5700493103828, -95.1522217802528
31.5699405555098, -95.1517182871046 31.5698394919151, -95.1512830870641
31.5698108659529, -95.1509933388188 31.5697402968273, -95.1497498566045
31.5693798129116, -95.1494905400445 31.5692501334744, -95.1491393430566
31.5688896228903, -95.1490938011874 31.5687198912485, -95.1491090062012
31.5685195757755, -95.1492387535997 31.5682601909646, -95.1497499147886
31.5675601882203, -95.1499328202233 31.567129126167, -95.1500626825061
31.5666809157252, -95.1504669627826 31.566070567703, -95.1505203963996
31.5658702764105, -95.1504592812455 31.5656204355248, -95.1504136168001
31.5655307804389, -95.1500322138178 31.5652408456512, -95.1496123956272
31.5649700184535, -95.149009558692 31.5644798152802, -95.1485365578262
31.5641403314204, -95.1472778798725 31.5631504020203, -95.1471328787502
31.5631294416449, -95.1467435905163 31.5632095194968, -95.1465074107416
31.5633793139353, -95.1463088737716 31.5636691899269, -95.1462478493968
31.5637207048047, -95.1460419230049 31.563749330607, -95.1457367490082
31.5636196297202, -95.1448821664817 31.5630798265608, -95.1446074887259
31.5629596848653, -95.1440277006688 31.5627708232478, -95.1436234636787
31.5627899021006, -95.1433105439334 31.562879546368, -95.1432111940185
31.5629405999537, -95.1431732339709 31.56347085216, -95.1430815743583
31.5639190825164, -95.1429671406184 31.5641002461258, -95.1428376654479
31.564229986639, -95.1426390641919 31.5643501227036, -95.142486378042
31.5643997211918, -95.1423874669917 31.5643901941455, -95.142219346641
31.5642795626558, -95.1420210857474 31.5639896493102, -95.1417084924184
31.5637703077316, -95.1410063797702 31.5637207116172, -95.1406096460353
31.5635795589435, -95.140358096965 31.5634403254662, -95.139678784588
31.5629901901938, -95.1389999299183 31.5623607654876, -95.1389695176286
31.562210097539, -95.1389236588932 31.5615196070642, -95.1389463769963
31.5612602228045, -95.1391373101091 31.5607605115223, -95.1392669169006
31.5605506984295, -95.1394576933142 31.5603408781433, -95.1404191315149
31.5594406332168, -95.1408613881315 31.5589599374857, -95.1410522011144
31.5585708565169, -95.141113343756 31.557849902673, -95.1412275594858
31.557649591938, -95.141502277702 31.5573806672635, -95.1418610685941
31.5571899330989, -95.1425477671482 31.556930550721, -95.1429673088761
31.5568408992319, -95.1437532150237 31.556600576067, -95.1439971801208
31.5564899613686, -95.1448134548623 31.5561294546798, -95.1456525974725
31.5557002819557, -95.146041863127 31.5554103918523, -95.1463926245825
31.5550403406314, -95.1466216701717 31.5545806815505, -95.1467894637372
31.5540294469575, -95.146881078191 31.5532398167458, -95.1470718414615
31.5522995143944, -95.147079348162 31.5517196605333, -95.1468733489619
31.5506706228883, -95.1466905269466 31.550199506071, -95.1464920987983
31.5498199407, -95.1461715647814 31.5493507524672, -95.1451491595719
31.5482006152292, -95.1447984038031 31.5477790781409, -95.1438523403823
31.5463600227675, -95.1436005718284 31.5459308878831, -95.1433792691703
31.5454807147708, -95.1428529479968 31.5440998090806, -95.1427917792579
31.5437507814266, -95.14279158724 31.5434207928936, -95.1429902759013
31.542770390808, -95.1432570762736 31.5422496767924, -95.1433334343742
31.542150504815, -95.1435012918901 31.5420093384921, -95.1438673804088
31.5418396045238, -95.1440277021151 31.5418205066843, -95.1441420969004
31.541849114571, -95.144622923925 31.5420894796101, -95.145050088173
31.5423793599701, -95.1453324031268 31.5426693096767, -95.1455611544061
31.5427894362909, -95.1457214751723 31.5427703791777, -95.145828445248
31.5427093543177, -95.145858776972 31.5426597719733, -95.1458281084341
31.5425605519248, -95.1450500524776 31.5417899932987, -95.1446305824735
31.5412197324977, -95.144111702719 31.5407200058552, -95.1432876294625
31.5398597634772, -95.1429977366958 31.5396308924705, -95.14254777337
31.5394706943312, -95.1421204972829 31.5393695882753, -95.1418534333818
31.5393600621767, -95.1411211032882 31.5394001290049, -95.1395033723573
31.5397396033118, -95.1389313736447 31.5398998286701, -95.1379470109547
31.5402297808533, -95.1377716121444 31.5402603178052, -95.1359483470518
31.5403499766501, -95.1355513237055 31.5403404167727, -95.1348571002839
31.5402507801693, -95.1340714029235 31.5401096570301, -95.1332625744024
31.5398407078813, -95.1323394893355 31.5395794043854, -95.1317366002952
31.5393505096073, -95.1310118083514 31.5391292726631, -95.1301728668359
31.5387897681813, -95.1296082579499 31.5384902984267, -95.128990262753
31.5382194470645, -95.128219708461 31.5377102093762, -95.1280822528833
31.5376300724358, -95.1277313912222 31.5375995761825, -95.1274186333645
31.5376796582972, -95.1270064458586 31.5378303477184, -95.1259385568072
31.5382804727278, -95.1258162451903 31.5382804739668, -95.1256408740677
31.5382099274445, -95.1253279098926 31.537860876092, -95.125076332162
31.5371208213364, -95.1250306005155 31.536739364403, -95.1250916642873
31.5366096674319, -95.1251678721337 31.5365600683038, -95.1252214341907
31.5364894832963, -95.1252135157048 31.5361004038003, -95.1254424468251
31.5352497204024, -95.1257478748787 31.5347690845438, -95.1258008934823
31.5345001192349, -95.1257017702075 31.5340003790947, -95.1256790344911
31.5337104758241, -95.1254195837359 31.5329208545872, -95.125251663693
31.5326995665862, -95.1250608731515 31.5325698965473, -95.1248919691074
31.5325036811625, -95.1248293007852 31.5324942475451, -95.1242673954558
31.5324096610977, -95.1239624956972 31.5321998741943, -95.1237793588625
31.5319309279901, -95.1236328507633 31.5313289316022, -95.1236113221514
31.5312404706575, -95.1235531802524 31.531173097449, -95.1235013299307
31.5310937212105, -95.1233293238583 31.530830400702, -95.1231767336558
31.5308094238752, -95.1230393993439 31.5308895355489, -95.1229477145651
31.5309505632036, -95.1227874223309 31.5311393699904, -95.1227111864843
31.53129003483, -95.1226499693832 31.5316390709748, -95.122657855051
31.53185081931, -95.1227418205537 31.5322704209275, -95.1230925509055
31.5330295619663, -95.1232375973645 31.5334892449815, -95.1232183509735
31.5337486747774, -95.1232146743962 31.5337982326672, -95.1231765907929
31.5338497049786, -95.1231196080777 31.5339295378108, -95.12307721155
31.5339889352765, -95.1229975421982 31.5340517248179, -95.12288244278
31.5341424375028, -95.1228254905241 31.5341873228743, -95.1223680563879
31.5343494572711, -95.1220706387106 31.5344756710452, -95.1214121979866
31.5345776934109, -95.1210372611616 31.5346575654656, -95.1205290733041
31.5347194439108, -95.1203918783795 31.5347194761604, -95.1201783187243
31.5346794031554, -95.1199265675389 31.5345306328111, -95.1198808514463
31.5344505331818, -95.1198426224565 31.5342807645905, -95.119888458688
31.5340804954039, -95.119926398524 31.533800102005, -95.1200029442527
31.5336513387111, -95.1203412297245 31.5331699112717, -95.1203688181049
31.5331306488971, -95.1203918147954 31.5329208441282, -95.120361274551
31.5328197332524, -95.1199749972132 31.5324960861668, -95.1199071799914
31.5324269765316, -95.1196911038709 31.5323355755416, -95.1195498904372
31.5322470417378, -95.1194515821871 31.5322128962521, -95.1191175488741
31.5320968754373, -95.1187887872511 31.5319872739179, -95.1169663317441
31.5313796895014, -95.1163026660566 31.5311298289275, -95.1158369589831
31.5309104838809, -95.1150892295849 31.5303440053183, -95.1150513931145
31.5303135140568, -95.1146468134054 31.5300407368665, -95.1143305486653
31.5296513881108, -95.1141890244534 31.5294771584788, -95.1140923914825
31.5294319125759, -95.1139892887798 31.5293730619426, -95.1136017531996
31.5292282034103, -95.1131821450953 31.5292205902131, -95.1128236579057
31.5291595489191, -95.1125934351096 31.5290307717397, -95.112513103164
31.5289705556642, -95.1124726239165 31.5289402127503, -95.1120299958953
31.5284099403843, -95.1118621800363 31.5283107780367, -95.1116408632397
31.5282192387061, -95.1111677133598 31.5281352954158, -95.1110306116675
31.5281028758542, -95.1104202945719 31.5280494663491, -95.1099166242269
31.5278797265839, -95.1093293350065 31.5274391342405, -95.1088789445793
31.5270194945906, -95.107917895922 31.5263099729228, -95.1077806166333
31.526119223089, -95.1077859165189 31.5259793039301, -95.1077880577028
31.5259227756739, -95.1077577426202 31.5258407676049, -95.1077803204297
31.5257396560412, -95.1078187776446 31.5256194924995, -95.1078874207172
31.5255298748939, -95.1082075434098 31.5253391383181, -95.1084364099349
31.5252704624282, -95.1090838153 31.5249735334009, -95.1092257236028
31.5249159645813, -95.1097106618181 31.5247192349752, -95.1100083614079
31.5245494863139, -95.1100617326796 31.5244903588115, -95.1100617941155
31.5244198060488, -95.1099642623532 31.5243249772173, -95.1098558174691
31.5242195373892, -95.1097412096308 31.5241108070139, -95.1093675462123
31.5238399591554, -95.1087494376794 31.5234508499328, -95.1081922581911
31.5230197644708, -95.107772808044 31.5228786673895, -95.1077116554548
31.5228633807614, -95.1076431633606 31.5228576858205, -95.1074980377741
31.522848132018, -95.1071930619161 31.5229492316864, -95.1068441825132
31.5231083507414, -95.1067121491912 31.523168568919, -95.1055998810825
31.5238132141274, -95.1055373280377 31.5238494678935, -95.1054688472854
31.5238666469108, -95.1054287815325 31.5238387577326, -95.1048660252109
31.5234470282947, -95.1047287003865 31.5233497458348, -95.1045608652617
31.5231742663862, -95.1041870639844 31.5227909124494, -95.1041029744839
31.5227603739635, -95.1040422302786 31.5227603795057, -95.1039426896727
31.5228099794131, -95.1036528951401 31.5231208682971, -95.1035614946367
31.5231609498137, -95.103298270823 31.5232307168746, -95.1030406785491
31.5231814270158, -95.1030580220013 31.5231189955298, -95.1029890446378
31.5229301533942, -95.1031036833121 31.5224762083798, -95.1030959206105
31.5224323093342, -95.1031417436085 31.5221405023954, -95.1031265454778
31.5219001902214, -95.103103720374 31.5216903590783, -95.1028899794609
31.5214004298784, -95.1023636738967 31.5211105307303, -95.1021806495822
31.5209102643383, -95.1014787679142 31.5199699652676, -95.1009981225783
31.5194301769224, -95.1007309485589 31.5192699634761, -95.1002424389456
31.519126896999, -95.0999372858765 31.5190391380833, -95.0997618561193
31.5189399690477, -95.0996781171135 31.5187797457985, -95.0997087019754
31.5185795017304, -95.0997543952569 31.5184288014667, -95.0998762091243
31.5180301514681, -95.0998993303888 31.517780311447, -95.0998380757869
31.5175209053654, -95.0997104709916 31.5173693703248, -95.099624469043
31.5172672397317, -95.0994492105765 31.5168495039873, -95.0992203971492
31.5165405390501, -95.0991285903167 31.5163192803449, -95.0987700827744
31.5141601567392, -95.0987779535089 31.513986599892, -95.0987994638657
31.5139150077872, -95.0989303896825 31.5134792499017, -95.0991713360256
31.5130265771733, -95.099243081639 31.5128917857162, -95.0992900976607
31.5128420678194, -95.0995100466097 31.5126094781051, -95.0997770602983
31.5122108238682, -95.0997922928715 31.51208874743, -95.0997866432915
31.5120431580982, -95.0997391131411 31.5116596113774, -95.0995100372238
31.5114097329483, -95.0993652044731 31.5113410836859, -95.0992678089065
31.5113249350309, -95.0987013479552 31.5111599130384, -95.0981825577072
31.5111198425329, -95.0975265392839 31.5111579700687, -95.0971229054608
31.5111472959344, -95.0970228411357 31.5111446495277, -95.0969773802452
31.511121758426, -95.0966644880294 31.5109748991256, -95.0965487467146
31.5108209072391, -95.0964508925567 31.5106907134369, -95.0963667407548
31.5104694434982, -95.0962217243194 31.5099201123174, -95.0962068330684
31.5093899049015, -95.0963136375231 31.5091705507287, -95.0964508298132
31.5090007655047, -95.0966111665294 31.5088806163201, -95.0967407597448
31.5088253013617, -95.096893172552 31.5087566506662, -95.0969772468495
31.5087795117692, -95.0971527107869 31.5087699779835, -95.0972823487049
31.5088291240144, -95.097732659812 31.5091400131067, -95.0991684026459
31.5102733543654, -95.0993631849548 31.5104143325294, -95.0994357264068
31.5104333560149, -95.0997925670313 31.5106296656327, -95.100036538589
31.5106792595466, -95.1000822811185 31.510650616959, -95.100184518708
31.5103696128757, -95.1002044110292 31.5103149378327, -95.100305997895
31.5100290417393, -95.1004083630511 31.509806993968, -95.1004472465627
31.5096654039737, -95.1005017671184 31.5094668726721, -95.1005171454489
31.5094108738195, -95.1006011534176 31.5090503523726, -95.1005934650696
31.5087204139674, -95.1005399962621 31.5085506574638, -95.1002730216593
31.508079515359, -95.1001280412755 31.5078906934544, -95.09976206788
31.5075206676417, -95.0992681524036 31.5072723995058, -95.0990906196638
31.50715445075, -95.0980070500358 31.5066394800702, -95.0974578771168
31.5062503617688, -95.0971908738879 31.5059108807782, -95.0971680050492
31.505802158342, -95.097145229752 31.505676272627, -95.0971513651401
31.5055713442073, -95.097157186593 31.5054717845396, -95.0971605083562
31.5054149749771, -95.0971634728428 31.5053583086741, -95.0971680932222
31.5052699897637, -95.0972825833639 31.5051803658368, -95.0978318737574
31.5048904556226, -95.0980684336027 31.5048046255273, -95.0981391172493
31.5047505045086, -95.0982054402969 31.5046997222185, -95.0982591472937
31.5044879992116, -95.0980778698815 31.5042942811293, -95.0980378389217
31.5042515027896, -95.0979385577944 31.504204246434, -95.0975875399231
31.5039100571298, -95.0974731908308 31.5038509359902, -95.0967637343363
31.5036506761574, -95.0964735426148 31.5036315866245, -95.0961378939771
31.5035896050087, -95.0958480175837 31.5036106106758, -95.0955888204726
31.5036602096906, -95.095405111973 31.5036960327107, -95.0945814926603
31.5038566342979, -95.0944214277529 31.5038871801862, -95.0941274711167
31.503885803208, -95.0940629556272 31.5038509318296, -95.0937653562467
31.5036506577671, -95.0936091550308 31.5034163708683, -95.0934830601369
31.5032272395765, -95.0934676050925 31.5030307759613, -95.0935288878737
31.5028896418556, -95.0936565591154 31.5026933837623, -95.0937098490969
31.5026114653437, -95.094192315211 31.5023708467248, -95.094611976302
31.5020293974086, -95.0948486023782 31.5018653808121, -95.0948944408273
31.5018348554309, -95.0951234238666 31.5016708472687, -95.0952252568545
31.5015008074927, -95.0952848089115 31.5013879703337, -95.0953368393478
31.5012893846323, -95.0954131932353 31.5011291684547, -95.0954209799423
31.5009803712149, -95.0953904248583 31.5007495991327, -95.0947493690677
31.500019076, -95.0947951034102 31.499982838722, -95.0951995782891
31.4996700351887, -95.0954132454066 31.499429693726, -95.0955198457354
31.4992294305427, -95.0955582235259 31.499149308614, -95.0954969447253
31.4990291639934, -95.0953904536861 31.4989890951639, -95.0952223423143
31.4989891211792, -95.0948715820012 31.4990902030259, -95.0943376249424
31.4991798324213, -95.0940780632385 31.4990291624579, -95.0940476542066
31.4989109242892, -95.0941008810158 31.498739225995, -95.0941618779582
31.4986495813557, -95.0947188433702 31.4979896455302, -95.0950163513512
31.497730271636, -95.0952301722697 31.4976406186528, -95.0955580158025
31.4975700344985, -95.0957718862854 31.497610078246, -95.0960386607272
31.4976997342044, -95.0964737885196 31.4979000119128, -95.0967103295996
31.4980602281823, -95.0969084952636 31.4983005663685, -95.0970076519561
31.4983501394344, -95.0971221861189 31.4983902131548, -95.0972291643809
31.4983902145146, -95.0973435397801 31.4982795569715, -95.0974121326712
31.4980907614731, -95.0974198783404 31.497850420326, -95.0973817526781
31.4968109297387, -95.0974122597329 31.4964199158023, -95.0974885658502
31.496160515168, -95.0977477252946 31.4955806701935, -95.0978928764416
31.4950199115505, -95.097877320169 31.4948406114836, -95.0977171545258
31.4940891204385, -95.0977019898409 31.4936409162268, -95.0977401287795
31.4934807011734, -95.0979613311806 31.493280427479, -95.0985718775876
31.4937095679096, -95.0986479767786 31.4939308309357, -95.0986710928801
31.494150160312, -95.0986402782974 31.4942703126146, -95.098762545816
31.4945392565582, -95.0990220873209 31.4946594454396, -95.0994187391236
31.4947109126852, -95.0995636420168 31.4947700381364, -95.0996475399182
31.4948806568144, -95.0998306759379 31.4952392553957, -95.0999221181234
31.4953594314307, -95.100151158176 31.4956092670048, -95.1004484512921
31.4958305447543, -95.1005936622474 31.4958992082776, -95.1006927039961
31.4959201913775, -95.1008225883058 31.4958896901308, -95.1009294378499
31.4958305438554, -95.1012193511875 31.4946002968656, -95.1013794590035
31.4942607845664, -95.1014862508984 31.4940795794563, -95.1015929555465
31.4939308162743, -95.1017532599133 31.4938106603619, -95.1021269987266
31.4936694929909, -95.1023636560841 31.4936504387662, -95.1025314669647
31.4936790609578, -95.1028291631715 31.4939003057373, -95.1029130267862
31.4941501868033, -95.1029280893312 31.4945392457887, -95.102859481753
31.4948902268912, -95.1030577859208 31.4951896574768, -95.1033476469011
31.4951991929532, -95.103622275754 31.4950999968153, -95.1043317991859
31.4949207081531, -95.1044694028811 31.4948501551727, -95.1045684295256
31.494840620709, -95.1048736047837 31.4947109120568, -95.1050110975257
31.4946193678663, -95.1050797879937 31.4944591553089, -95.1050796595128
31.4944000107387, -95.1050031561792 31.4942092936774, -95.1047135786915
31.4937400881003, -95.1044921598339 31.4934596936237, -95.1043016298361
31.4930191065233, -95.1042784350812 31.4928703312655, -95.1043165955112
31.4925708925368, -95.1044771281861 31.492099766349, -95.1047821688448
31.4917106623246, -95.1055223111258 31.4910907883952, -95.1059187153381
31.4906692378275, -95.1064299449466 31.4902896942124, -95.1069869353624
31.4899501719763, -95.1076429935413 31.489700293669, -95.1082231578863
31.4894790690093, -95.1083602348876 31.4893798665247, -95.1091002018867
31.4887008699581, -95.1091919725137 31.48829076922, -95.1091691329012
31.4878807296726, -95.1091307001018 31.4876308212298, -95.1090469240865
31.4873790593131, -95.1086198443053 31.4865703508966, -95.1085816067084
31.4863090336469, -95.108589046426 31.486120224173, -95.108619783092
31.4860706225514, -95.1088408639721 31.4859104113277, -95.1090087861041
31.4857902364282, -95.1091386373336 31.4857292120977, -95.109466530237
31.4854793746947, -95.1097031516266 31.4850597617799, -95.1097565894571
31.4847908160024, -95.1098481534505 31.4845695418467, -95.1102371095361
31.4842204832795, -95.1106797522533 31.4838905460613, -95.1107177241332
31.4838409616072, -95.1107023168156 31.4837894332357, -95.1103363178004
31.4834594745219, -95.1094819115603 31.4832191329221, -95.1090089005859
31.4831600265833, -95.1081770210297 31.4831199685982, -95.106773570708
31.4831295258865, -95.1062010993087 31.4829807039813, -95.1060792281674
31.4829197152746, -95.1059113427041 31.4825000762811, -95.1058808007812
31.4821300411193, -95.1059493209848 31.4818496537183, -95.106247132618
31.4815597537191, -95.106376640675 31.4812202300415, -95.1063385862346
31.4809093492433, -95.1062391879525 31.4807491331533, -95.1059493396665
31.480470641296, -95.1055985201528 31.4802894813665, -95.1051329279594
31.4801502157597, -95.1046295870525 31.48011015191, -95.1043088928423
31.480060560557, -95.1039430374415 31.4799595076883, -95.1036833342817
31.4798507798323, -95.1034927962332 31.4797496638518, -95.1028517474241
31.4792899830205, -95.1027373964952 31.4791698369523, -95.1025011074714
31.4788208036885, -95.1024474329633 31.478609065681, -95.1024703966712
31.4782695640154, -95.1025467695013 31.4780006355408, -95.1026610515682
31.4777603175983, -95.1030122620793 31.4760093682264, -95.1028823665893
31.4757404368314, -95.1026383889403 31.4757003719888, -95.1020432155636
31.4754791216127, -95.1019897073883 31.4754104755939, -95.1019897180686
31.4752101812296, -95.1020889708319 31.475080489756, -95.1022491609668
31.475000371497, -95.1027679388252 31.4747905688162, -95.1029585206665
31.4747905750518, -95.1033096316593 31.4745807785333, -95.1034086247796
31.4745406873971, -95.1032408711142 31.4743499687652, -95.1027986018068
31.4741496949474, -95.1025926461934 31.474159231273, -95.1022262322961
31.4741001242594, -95.1013795673874 31.4738598047234, -95.1010973029892
31.4738292647517, -95.1006469312315 31.473930340061, -95.1002274484996
31.4741096704775, -95.1001127646513 31.4741191620237, -95.099662762799
31.4743900288773, -95.0991591198433 31.4745101839983, -95.0988082354067
31.4745693384376, -95.0983732777222 31.4745292806487, -95.0981522607415
31.4745807667582, -95.0980071661711 31.4747104671659, -95.0980072196968
31.4748401653366, -95.0983507045058 31.4755992927124, -95.0985108595244
31.4761505340084, -95.0984880502282 31.4764099149242, -95.0983430620175
31.4765606063696, -95.0981065006209 31.476709351385, -95.0980377449353
31.4767093479305, -95.0977478155531 31.4766406985241, -95.0975798172635
31.4765701314301, -95.0970611731114 31.47616959184, -95.0968703489231
31.4758205211172, -95.0968626446793 31.4756603173403, -95.0968934227608
31.4752102153687, -95.0970610657756 31.4746494130803, -95.0974196460526
31.4739894996021, -95.0976029800071 31.4737205749618, -95.0981214514722
31.4732398849996, -95.0984725674782 31.4730301016219, -95.0987092456911
31.4729404578091, -95.0991667009279 31.4729499568746, -95.0994032379839
31.4727706950977, -95.1001664343727 31.4720306632317, -95.1005173637764
31.4716396277163, -95.1005630279972 31.4712505201126, -95.1010512560318
31.4706401722714, -95.1011125577665 31.4703903261728, -95.1011808584733
31.4698295534044, -95.1011582380489 31.4693699054828, -95.1010971260174
31.4691390850267, -95.1009901614304 31.4688701662649, -95.1008912955705
31.468730951707, -95.1004331683965 31.4682808002126, -95.1000978358654
31.4682197806533, -95.0998307961702 31.468259815661, -95.099639741619
31.4682998710633, -95.0995179489189 31.468360892079, -95.0990293968637
31.4684390897507, -95.0984192966839 31.4684505499543, -95.0979689929297
31.4684200330603, -95.0969619020963 31.4682502579294, -95.0964203335768
31.4682197740415, -95.0955810124154 31.4683398994372, -95.0945204874091
31.4685306329379, -95.093757508337 31.4688205655449, -95.0935823476193
31.4689102303667, -95.0933305303781 31.4690894992768, -95.0931089360203
31.4691906098403, -95.0929564727594 31.4692306692526, -95.092399441241
31.4692497059866, -95.0922088792543 31.4692802416702, -95.0921097903846
31.4693298482201, -95.091827289493 31.469150526274, -95.091598411487
31.4688301212171, -95.091400112394 31.467979436032, -95.0912628719358
31.4675598274725, -95.091171152804 31.4673995906152, -95.0908202372788
31.4669990319697, -95.0903625761172 31.4665794173658, -95.0897901526944
31.4662094078656, -95.0894395443104 31.4661102236424, -95.0889891341692
31.4660205732399, -95.0885621712288 31.4660205705252, -95.0877991242904
31.466089268139, -95.0865937845856 31.4663200238306, -95.0861968336494
31.4665374650283, -95.0849914334699 31.4669609038019, -95.084159670278
31.4671897824551, -95.0835419859286 31.4673995904759, -95.0812990048028
31.4679203039127, -95.0809936758989 31.4680309367982, -95.0807188332685
31.468280801697, -95.0806199691396 31.4689006981894, -95.080673281629
31.4690799881715, -95.0807418577139 31.4691905930655, -95.0810621707106
31.469530096418, -95.0814207554308 31.4697608935084, -95.081466605873
31.4698295563015, -95.0814972971105 31.4699802555731, -95.0814820437408
31.4700794126062, -95.0814284866947 31.4701499802405, -95.0812988478293
31.4702606404838, -95.079780608927 31.4694499826205, -95.0787504879871
31.468669880132, -95.0785828864296 31.4684390904254, -95.0785063633381
31.4682807988663, -95.078323480385 31.4675293039415, -95.0782698898774
31.467439657202, -95.077751332383 31.4673309208109, -95.0771103693326
31.467309939801, -95.0763015425663 31.4672393941857, -95.0759429074173
31.4671707232454, -95.0752717535324 31.4669208549016, -95.0746689825621
31.4668693509061, -95.0742492492466 31.4668693632321, -95.0741502411539
31.4668407631059, -95.0737991201861 31.4665908745897, -95.0734636202719
31.4659595722005, -95.0733031466787 31.4655399091363, -95.0732804694563
31.4651298615138, -95.0734482948621 31.4643001681051, -95.073417603611
31.4640502830755, -95.0733489267767 31.4638500144771, -95.0729979038128
31.4634990553559, -95.0727309368905 31.4633693826024, -95.0723190487132
31.4632892606641, -95.0719605433919 31.4633102382753, -95.0715181342428
31.4634895410138, -95.0710982487246 31.4637603913631, -95.0702285467216
31.4645194782575, -95.0699310759622 31.4648399544266, -95.0695878884751
31.4652805204871, -95.0693665847962 31.4654598413262, -95.0691224593329
31.4655609054836, -95.0689392320183 31.4655895421588, -95.06764237054
31.4657402173186, -95.0675430692024 31.4657707416234, -95.0672988447941
31.4659194804387, -95.067176834261 31.4660301192309, -95.0670469914791
31.4662208426509, -95.0668869093927 31.4666195017064, -95.0667039437153
31.4674301099513, -95.0665281365845 31.4685706880951, -95.0664519630815
31.4687805089922, -95.0661925734366 31.4692707198192, -95.0660933857609
31.4695205580678, -95.0660629434826 31.4697093873523, -95.0661162333166
31.4699497127916, -95.0662231887257 31.4700794382208, -95.0664367929344
31.4701995654837, -95.0668333205097 31.4701900611198, -95.0670089126786
31.4701004053081, -95.0676270287967 31.4695701804556, -95.0678711654662
31.4694309222614, -95.0679778077165 31.4693908510102, -95.0683822703738
31.4693603591604, -95.0684965548714 31.4693507948371, -95.068832491055
31.4695606309596, -95.0688324053668 31.4696998532362, -95.0687865840455
31.4698295530841, -95.0686798589135 31.470039361997, -95.068580457613
31.4701099257765, -95.0683976317804 31.4702301212224, -95.0676878045781
31.4702796701979, -95.0672606228756 31.4703598026693, -95.0668028976151
31.4706001330076, -95.0664216721677 31.4709606063143, -95.0661927094704
31.4711399287567, -95.0659790226871 31.4712505246728, -95.0657807070195
31.4712905952247, -95.0650026169319 31.4713306429077, -95.0644910830118
31.4711494200125, -95.0642088252303 31.4709892293185, -95.0630112458901
31.4700699079512, -95.0628279060264 31.4699706793523, -95.0622483285535
31.4696998820637, -95.0617981177953 31.4693698889197, -95.0617066464237
31.4691905831764, -95.0617292555297 31.4689903379198, -95.0619734824241
31.4682006718428, -95.0620572988958 31.4678001187577, -95.0620500532107
31.4675407444634, -95.0619506419052 31.4673595458357, -95.0616835823992
31.4673309184482, -95.0609513620119 31.4677905952705, -95.0604094014146
31.4678897712076, -95.0603410507045 31.4678592911172, -95.0602035496575
31.4677906177679, -95.0582274986236 31.4661807805566, -95.0577924947324
31.4657306708777, -95.0574187066157 31.4653091361188, -95.0570069265255
31.4649906019678, -95.0567397743071 31.4649105015984, -95.0564802631628
31.4647693644968, -95.0579069045958 31.4638195057725, -95.0580900335191
31.4636707103309, -95.0581129486426 31.4636097033545, -95.0580824955641
31.4635391340627, -95.0575866005355 31.4630393863111, -95.0574110168203
31.4629306619849, -95.0569383313886 31.4628601267713, -95.055991968441
31.4625701727492, -95.0550918469247 31.4621505748767, -95.0547334504998
31.4619407805317, -95.0546493354902 31.4617900777217, -95.0546266311691
31.4615802785561, -95.0546800156184 31.4612693729149, -95.0547638494359
31.4610290373522, -95.0553588603741 31.4605407707333, -95.0554276140527
31.4603500260748, -95.0554123420358 31.4602203407463, -95.0552596856625
31.4600200492701, -95.0551605892837 31.4599704865203, -95.0540770693303
31.4597206052664, -95.0536269329361 31.4593906257369, -95.0535126625491
31.4593391472937, -95.0526734689446 31.4591903716641, -95.0523910597627
31.4591102750516, -95.051887466826 31.4587497767152, -95.0515290113946
31.4582901001325, -95.0514601795643 31.4581394252219, -95.0513229261178
31.4577693788913, -95.0510713142257 31.4572505953569, -95.0509490428196
31.456810009675, -95.0508574458539 31.4561691034641, -95.0508803303204
31.4553699446199, -95.0509490117001 31.454929328832, -95.0513685960429
31.4537200799305, -95.0513993632484 31.4535407929871, -95.0513916536303
31.453199381467, -95.0513001285204 31.4528694210586, -95.051010021125
31.4525699690513, -95.0499267359991 31.4519290717055, -95.0489198397875
31.4512805921014, -95.0483016498777 31.4507999547642, -95.0482405663732
31.4506702197498, -95.0487518258897 31.4502601735108, -95.0488431922229
31.4501209036137, -95.0488586794872 31.4500102986778, -95.0483472782788
31.4490604277126, -95.047973589639 31.4486999366996, -95.0471725360415
31.448150616395, -95.0464018575201 31.4474601867331, -95.0453187811448
31.4466800699105, -95.04501341713 31.4465103148982, -95.0446167982835
31.4464092296623, -95.044403170123 31.4463291044881, -95.0443574643459
31.4462203893199, -95.0443495411801 31.4461193112058, -95.0443725598307
31.4460792545085, -95.0447312574547 31.4457493074121, -95.0451813969058
31.4454307816403, -95.0452882395778 31.4452800935758, -95.0453110700525
31.4451599006678, -95.0451583562216 31.4449691634561, -95.0449065391721
31.4449195839231, -95.0445099084682 31.4449405578153, -95.0434494352081
31.4450492788217, -95.0427778440401 31.4451999438959, -95.0425110291432
31.4452896097516, -95.0422973687903 31.4454002525366, -95.0416487253852
31.4458694371848, -95.0412597194567 31.445920952963, -95.0411071679535
31.4459705179262, -95.0408096857076 31.4461307569667, -95.0402983220585
31.4464893090625, -95.0401001350476 31.4465808887763, -95.0398634690167
31.4466399960027, -95.0395889225203 31.4466705162961, -95.0391616416071
31.4466400334308, -95.0388106500476 31.4465503478613, -95.0383682479481
31.4462890633009, -95.0376969769425 31.4458408285649, -95.0375595201657
31.4457798129804, -95.0370787004283 31.4456901311378, -95.0364302235467
31.4453506240566, -95.0353089302642 31.4450893313068, -95.0351333780152
31.4450798030692, -95.0348663066979 31.4449691849297, -95.0345611797286
31.4447498421875, -95.0345002192267 31.4446106193349, -95.0344773435607
31.4444808936585, -95.0345382836008 31.4443092557547, -95.0347670470666
31.4441108824238, -95.0352403288061 31.4437809238253, -95.0353394383265
31.443670288255, -95.0353927259346 31.4435596422566, -95.0354002764961
31.4435005344832, -95.0353395045346 31.4434108903615, -95.0351868827676
31.4433403162029, -95.0347520094803 31.4432105971644, -95.0336074484819
31.4432601937792, -95.0331115563735 31.4432201288754, -95.0325164932494
31.4431400485302, -95.0315932285418 31.4431095102645, -95.0312270444692
31.4431400321051, -95.0309296752029 31.4432296946259, -95.0308607090487
31.4433402907292, -95.0308609892482 31.4434108599913, -95.0310134360846
31.4437198462831, -95.0322722261664 31.4448299309919, -95.0323182272072
31.4449100356818, -95.0323411739309 31.4451294217779, -95.0322038195075
31.4454307669338, -95.0319136714927 31.4455509258295, -95.0316772169975
31.4455604551588, -95.0315933206805 31.4455203877211, -95.0308229421926
31.4449405581255, -95.0299987438475 31.4445800601425, -95.0280684335579
31.4437408448812, -95.0276566809236 31.4435997212069, -95.0267868358704
31.4433803552763, -95.0259400505411 31.4430294282178, -95.0254134660228
31.4428405905679, -95.0247803644367 31.4426593870433, -95.0240098916339
31.4424991709581, -95.0236511619215 31.4424800881033, -95.023246688049
31.4425201347827, -95.0229796679967 31.4425906966569, -95.0227586605805
31.4426803791817, -95.0216217610787 31.4434108598807, -95.0211488567193
31.4436797969993, -95.020851060346 31.4437999783751, -95.0203935090403
31.4438705354876, -95.0193480283983 31.4438705393143, -95.0188829383619
31.4439392109558, -95.0179901760758 31.4442195894272, -95.0169373838001
31.444599166362, -95.0164335407965 31.4447994186222, -95.0162278871101
31.4449100722043, -95.0161208939972 31.4450702601099, -95.0161284578864
31.4452304696095, -95.0162430143131 31.4454498501404, -95.0164413771462
31.4456806347906, -95.0165024179901 31.4458102993655, -95.0165177830944
31.4460506405914, -95.0165025530625 31.446170824073, -95.0163727326573
31.4463596553279, -95.0161973310624 31.4464607093331, -95.0158921788638
31.4465904229628, -95.0156783196268 31.4466209282722, -95.0151671661557
31.4465198586281, -95.0142824025414 31.4461803429942, -95.0135574721615
31.4459495558405, -95.0130995395432 31.4457397255916, -95.011840655698
31.4450206488604, -95.0112227643832 31.4447803539463, -95.0110015978754
31.4447593652702, -95.0107496588397 31.4447803582351, -95.0097123978385
31.4449806492044, -95.0075073829867 31.4452800845527, -95.007339468394
31.4452705574516, -95.0071410230844 31.445230487376, -95.006400930843
31.4450206582087, -95.0063094060808 31.4449806207956, -95.0060728825325
31.4447498388496, -95.0059511121789 31.4445305113126, -95.0059661111832
31.4443092448696, -95.0063475177971 31.4435100595873, -95.0063780520995
31.4433593549908, -95.0063629387445 31.4432506543337, -95.0062101997062
31.4430694376192, -95.0059432172399 31.443040865708, -95.0056227563108
31.443050387411, -95.0053785605973 31.4430694388413, -95.0050963235881
31.4430103147206, -95.005111870713 31.4427108707378, -95.0049896635855
31.4420394998119, -95.0049515374209 31.4419402909225, -95.0047074797342
31.4420699921082, -95.0044631552413 31.4423103282567, -95.0041502960054
31.4423809153144, -95.003997974936 31.4423504014116, -95.0038988188609
31.4423103229794, -95.0038301496016 31.442029965991, -95.0038910148294
31.4417400520729, -95.0040435054176 31.441480653254, -95.0043028428771
31.4411697413847, -95.0043793164722 31.4408206904045, -95.004371790721
31.4406299651829, -95.0041428551783 31.4403400306744, -95.0041505684492
31.4402103281013, -95.0042800864648 31.4400501237186, -95.0043561943267
31.4399795615153, -95.0046615539717 31.4398307843042, -95.0049362367798
31.4397296990921, -95.0051497902864 31.439689629206, -95.0060729189069
31.4397296671511, -95.0065537411692 31.4397201523875, -95.0074463418447
31.4395408789121, -95.0080185770415 31.439399714438, -95.0090104472403
31.4390392187872, -95.0098417633858 31.4386291332451, -95.0105133343649
31.4383506969626, -95.0108413557289 31.4380702940269, -95.0110780647986
31.4377308081896, -95.0114670996013 31.4368095430568, -95.0115201964401
31.4365291532121, -95.0114365691679 31.4361896354038, -95.0111619509627
31.4356098238722, -95.0109023910198 31.4352607716986, -95.0103836769127
31.4347591223633, -95.0101930278382 31.4346409025242, -95.0098493876254
31.4344596590872, -95.0095062202981 31.4343299790056, -95.0090181365326
31.4342499068246, -95.0072708818562 31.4337692378185, -95.0067823584328
31.433410636784, -95.0067060683842 31.4332809318686, -95.0068132223285
31.433019639783, -95.0069578102234 31.4328403186459, -95.0072938749525
31.4325294642011, -95.0074005918489 31.4323291858936, -95.0071716041072
31.4316101040744, -95.0068434010799 31.4307994824125, -95.0065002253315
31.4301796119559, -95.0060577635063 31.4297790622178, -95.0054094340877
31.4293804236247, -95.0044935160778 31.4290409085136, -95.0042038644551
31.4288501591602, -95.0036393023801 31.4283504307156, -95.0033721290176
31.4280395636181, -95.0031508353918 31.427629447771, -95.0029603742788
31.4270706130457, -95.0029221572971 31.4267997647794, -95.0029220837313
31.4262504795595, -95.0029680316017 31.4260292143238, -95.0031202450289
31.4256916067725, -95.0034715605313 31.4252300216672, -95.0045928566406
31.4240894297825, -95.0046919163613 31.423919671964, -95.0047987219016
31.4235591810296, -95.0047608800003 31.4229793711845, -95.0047990660782
31.4227905511268, -95.0050278834569 31.4218292106288, -95.0051573665277
31.4215106748212, -95.0053178747057 31.4212207704095, -95.0053403994188
31.4210090662349, -95.0053178856182 31.4208507627276, -95.004768195422
31.4204196850907, -95.0037538357918 31.4198703630995, -95.0022199880408
31.4186706404495, -95.0011520139426 31.4179592070521, -95.000579652401
31.417690279009, -95.0002593376977 31.4176006456602, -94.9999999504566
31.4175968180579, -94.9998322594014 31.4176292631384, -94.9996565523416
31.4177894679002, -94.9995878416408 31.4179401452723, -94.999557368877
31.4181499516987, -94.9995804680356 31.4183196960777, -94.9997099584178
31.4188003696248, -95.0000000848027 31.4194488860496, -95.0000230607158
31.4195003393169, -95.0000992245305 31.4196395725664, -95.0000610817848
31.4199028157633, -95.000044835551 31.4200068792073, -94.9999941571557
31.4203314925239, -94.999976956224 31.4204406711188, -94.9995423416194
31.4206104146139, -94.9994203658492 31.4206294878854, -94.9992980115049
31.420610433788, -94.9985885204833 31.4203204947314, -94.9981916755651
31.4200305765052, -94.9980086407312 31.4198608290232, -94.9977265996008
31.4194603111445, -94.9975203442366 31.4190101667313, -94.9973983317477
31.4186305997673, -94.9973526296422 31.4180106928348, -94.9973831472736
31.4177398568609, -94.9974595620457 31.4174899929349, -94.9974672397835
31.4172706724458, -94.9973982493004 31.4169292221071, -94.9973219833292
31.416799554027, -94.9971235824087 31.4167899833061, -94.9966508880033
31.4168300760595, -94.9958799612859 31.4171199752623, -94.9952926123428
31.4172001051745, -94.9940186932273 31.4176006180882, -94.993812732873
31.4176197185328, -94.9936064008063 31.4176006056934, -94.9934309444803
31.4175300332463, -94.9933625067494 31.4174194235603, -94.9933623246131
31.4172496692864, -94.9935530007524 31.4165305984872, -94.9938736959824
31.4157695964982, -94.9941482602658 31.4151801918199, -94.9941864001863
31.4149398685352, -94.9941483198559 31.4146594929824, -94.9940109269839
31.414320010295, -94.9937669824321 31.4140796832463, -94.9934236598595
31.4138793899642, -94.9931106840235 31.4138107112288, -94.9921492574318
31.4137401492355, -94.9906770474759 31.4133396137262, -94.9901810507744
31.4132594996652, -94.9898986498877 31.4132805056525, -94.9896773013866
31.4133396011535, -94.9888612293182 31.413820278567, -94.9881363562643
31.4141807710336, -94.9877319088782 31.4143199765302, -94.9869919479438
31.4143009354925, -94.9864808660757 31.414239875917, -94.9851914545018
31.4139003602715, -94.9845428646574 31.4136905733098, -94.9838180897452
31.4134101668012, -94.983032079069 31.4130801958908, -94.9826125896132
31.4128093854051, -94.982559144285 31.4126892256353, -94.9825287923206
31.4124603503527, -94.9828720480599 31.4118499578312, -94.982940568481
31.4115905648577, -94.9829177698233 31.4114608719999, -94.9828795114517
31.4113197166814, -94.9827803907513 31.4111595316374, -94.9821471741632
31.4106101916947, -94.9815519460289 31.4102897648216, -94.9806671484272
31.4099292657541, -94.9788285964536 31.4094009251029, -94.9784925518401
31.4092006596953, -94.9783171542233 31.4088592426558, -94.9780197457606
31.4085903118926, -94.9779205261075 31.4085597800066, -94.9778136433976
31.4085598079533, -94.9776230237846 31.4086303846682, -94.9772721451882
31.4090900318333, -94.9771118170923 31.4092102058744, -94.9770507408348
31.4092102214706, -94.9768829738187 31.4091091092911, -94.9763869288339
31.4085502517632, -94.9758682838953 31.4078808045942, -94.9757767120745
31.4076099603455, -94.9757918797352 31.4074993047831, -94.9758527774351
31.4073600502374, -94.9759520559635 31.4072093777012, -94.9760818446881
31.4070892126214, -94.9764710448185 31.4067993136194, -94.9768830106899
31.4065494467273, -94.9779890759273 31.4061908720623, -94.9786604283559
31.4060192104328, -94.9789888084362 31.4058895079187, -94.9791031868072
31.4058094258361, -94.9793013873261 31.4055595232537, -94.979362412296
31.4053802278615, -94.9793088910376 31.4052391183034, -94.9790802478675
31.4050293167169, -94.9788514945901 31.4049492146365, -94.9786836550457
31.4049396500457, -94.9779203779859 31.405019774862, -94.9772873635183
31.4051208686234, -94.9765778389671 31.405300129372, -94.9764328993739
31.4052905989127, -94.9761427879795 31.4050807916987, -94.9760283357005
31.4048996139426, -94.9758987719981 31.4044304094078, -94.9756468740859
31.4030494759455, -94.9756470092256 31.4025592909499, -94.9757005207268
31.4022502990609, -94.9757764912922 31.4020996164203, -94.9759523202552
31.4019298769242, -94.9771577420582 31.4013805542868, -94.9773405839465
31.4012298432932, -94.9776917521071 31.4007492197654, -94.9779891674176
31.400169365853, -94.9780501651177 31.4000205860233, -94.9780272680092
31.3999004160211, -94.9779891034285 31.3997802500196, -94.9774933339155
31.3992996051732, -94.9772874204518 31.3991909065152, -94.9768369866739
31.3990192535095, -94.9765931744276 31.3989505754298, -94.9763336601141
31.3989200396593, -94.9760972023558 31.3989391194156, -94.9758910408823
31.3990001577717, -94.9749376214448 31.3993606487642, -94.973777656753
31.3996391430831, -94.973396376869 31.3996391173816, -94.972999489631
31.3995704513293, -94.9728165270254 31.3995208861409, -94.9723893290865
31.3993205975544, -94.9715730064015 31.3988094416315, -94.9711305138221
31.398429873088, -94.9706267347497 31.397859569435, -94.9700392558267
31.3973293354967, -94.9695967613866 31.3970699376511, -94.9691926337096
31.3969192555722, -94.9689864587837 31.3968906219415, -94.9686506597624
31.3969192310951, -94.9677506372645 31.3971004654075, -94.9671097477783
31.3970794771152, -94.9662018046809 31.3968391276332, -94.9657822340088
31.3966693736629, -94.9653395335446 31.3964290520147, -94.9646529373238
31.3959198006769, -94.9641798233228 31.3953704577468, -94.9641188875355
31.395240767033, -94.9642791492919 31.3949794843968, -94.9652709438151
31.3942108158791, -94.9655836840751 31.3939304427254, -94.9656904888998
31.3937893004605, -94.9658507844719 31.3934898182742, -94.9658736122982
31.3932590289181, -94.965728945678 31.3926906733404, -94.9656981813566
31.3923206100662, -94.9657974571717 31.3918704894478, -94.9659806763159
31.3915405307774, -94.9659803554701 31.3913593084475, -94.9658967588316
31.3910903980156, -94.9656679187444 31.3908405170091, -94.9645081692802
31.3904800635439, -94.962867849211 31.3901290814006, -94.9618682362693
31.3898391780202, -94.961662431237 31.3897590847899, -94.9604264754058
31.3891200974386, -94.9587480483949 31.3885593585069, -94.9584272419383
31.3883991201407, -94.9581832757454 31.3882293644157, -94.9580918988796
31.3881206651282, -94.9580613231109 31.3880691620277, -94.9580917805636
31.3879509097824, -94.9582365783855 31.3878803238845, -94.9587708211293
31.3877391828033, -94.9588930171043 31.3876705418407, -94.9590911618779
31.3874892965872, -94.959228538911 31.3873100440733, -94.9592666985533
31.3872203784988, -94.9592591305594 31.3871593489547, -94.9590911248971
31.3869590550223, -94.958099237582 31.3868102887854, -94.957740944989
31.3867721451077, -95.0000000958749 31.3577719189238, -95.4343871868842
31.0578098271571, -95.5161288404316 31.0009756192787, -95.6179187983234
30.9300206805543, -95.6182325432126 30.9299392638765, -95.6188584140918
30.9298191097711, -95.6194536240061 30.9295501775834, -95.6198425393843
30.9294891360055, -95.6200714976831 30.929430010812, -95.6203308670654
30.9293098470667, -95.6208495247335 30.92914008821, -95.621101384581
30.9290008545208, -95.6214674624468 30.928880687258, -95.6219404143675
30.9286708765042, -95.6221695356646 30.9285392776441, -95.6224364216747
30.9282398188928, -95.6227875564119 30.9280109433445, -95.6230317118006
30.9277706179196, -95.6234586853312 30.9275093018606, -95.6237489264081
30.9272403766911, -95.624236889858 30.9271202028234, -95.6246187158317
30.9269790712969, -95.6249238225272 30.9269237557873, -95.6249923837505
30.9269104008587, -95.6250535737802 30.9269008693389, -95.625259355012
30.9269103989278, -95.6258086352746 30.926769253878, -95.6265488794636
30.9265003242846, -95.6270600751231 30.9262409257408, -95.6275330570215
30.926090243861, -95.628036337487 30.9260101263399, -95.6296921302582
30.9259490984839, -95.6306532786077 30.925880428614, -95.6309280541314
30.9258499150691, -95.6316910436532 30.9257106803197, -95.6320571245285
30.925710675859, -95.6324690001198 30.9259300171509, -95.6331098824317
30.9263305607656, -95.6333083148582 30.9264297453036, -95.6338272011597
30.9265995023203, -95.6341019499681 30.9266300229925, -95.63588707536
30.9263305639988, -95.6369170492192 30.926259992285, -95.6373366434137
30.9262695282811, -95.6380079908803 30.9264697985152, -95.6385725918684
30.926679607783, -95.6389466419183 30.9268703498115, -95.6393967965581
30.9272995039052, -95.6396026192418 30.9274291977954, -95.6399764865219
30.9275894159372, -95.6401520595736 30.927690508747, -95.6405791903744
30.9281597125698, -95.6409378963172 30.9288902315058, -95.6411436399663
30.9294109289403, -95.6411817989945 30.9297008463558, -95.6411284376196
30.9303798642277, -95.6412963052195 30.9315299961236, -95.6414183990366
30.9319496132687, -95.6417770847507 30.9326896685997, -95.6425477290545
30.9338302657091, -95.6425935479197 30.9339199123125, -95.6427231001745
30.9344291693822, -95.6428373706083 30.934680933234, -95.6430204939398
30.9347400616797, -95.6432191792131 30.9347305360302, -95.6439133149558
30.9347591417958, -95.6444932005421 30.9348297152468, -95.6457596429145
30.9348506948848, -95.6464693070525 30.9349498815376, -95.646858023269
30.935049050164, -95.6481935036309 30.9350204515683, -95.6486205512076
30.9351291639409, -95.6491469301832 30.9355106320749, -95.6493073162919
30.9355602289348, -95.6496429842127 30.9358997358929, -95.6496889166948
30.9362297127451, -95.649528392088 30.9371795613574, -95.6495436462118
30.9374294236784, -95.6494369740573 30.9386501319403, -95.6492918347829
30.9397602022691, -95.6492462588548 30.940349580161, -95.6492693031116
30.941860205318, -95.6493223749369 30.9422607375999, -95.6494216231476
30.9426307654667, -95.6495590347086 30.9434299472248, -95.6495209358677
30.9445590997103, -95.6495437410472 30.9450092309202, -95.649673340943
30.9457092245854, -95.6497572230131 30.945970529858, -95.650199817066
30.9472599000842, -95.6505204473939 30.9478397407925, -95.6506803822957
30.9480209300811, -95.6511611262216 30.9483795147602, -95.6514511479463
30.9485397346897, -95.6525193005374 30.9487991354236, -95.6527709177357
30.9488906844996, -95.6532820218292 30.9491805990935, -95.6535184833333
30.9493408142996, -95.6542205763287 30.9499797822297, -95.6544800788339
30.9502906829762, -95.6546326900541 30.9506397297845, -95.654746872503
30.951059337976, -95.6548006097086 30.9519405434166, -95.6548692751334
30.9522895877871, -95.6551588760959 30.9531707724136, -95.6552886871387
30.9533901212388, -95.6558608413686 30.9538307178249, -95.6567382532772
30.9543704972118, -95.6572800103048 30.9547595981841, -95.6582032310055
30.955459597039, -95.6588210500871 30.9560203520229, -95.6596832342453
30.9572391505647, -95.66023274216 30.9582595898794, -95.6605301449735
30.9589900976078, -95.6609420346506 30.960290906693, -95.6616669487027
30.9615402244108, -95.6621473951655 30.9624290422373, -95.6622086242929
30.9626102469141, -95.6623916635097 30.9634895317597, -95.6622771021383
30.9645805316466, -95.6623078035119 30.9651298554513, -95.662406952178
30.9656600950069, -95.6625978338149 30.966030126888, -95.6628800715561
30.9664306680536, -95.6638107934268 30.96730995439, -95.6639707879639
30.9675693455085, -95.6640776631907 30.9681491822511, -95.664070163902
30.9696598059858, -95.6641311060855 30.9700908640928, -95.6641236212852
30.9702796959509, -95.6642533768297 30.9707794234602, -95.6643218597912
30.9708900432565, -95.6650239721901 30.9716205632438, -95.6651609900951
30.9718494368225, -95.6655502599846 30.9720706924797, -95.666412550639
30.9723701533129, -95.6670075918268 30.9726295537704, -95.6682814876628
30.9730300882363, -95.6694335989546 30.9734706866449, -95.669700502287
30.973579401814, -95.6701202612234 30.9738597854701, -95.6706084809802
30.9741992920247, -95.6714019081746 30.9749107323329, -95.6717530301767
30.9753799450401, -95.6718825449289 30.9756507833077, -95.6727600958718
30.9764900249631, -95.6729585542698 30.9767398872522, -95.6730118232664
30.9770603217315, -95.6730575118973 30.9779205328264, -95.6730498033203
30.9782104471369, -95.6732405653591 30.9788894612272, -95.6733169510582
30.9792900080926, -95.6733322420215 30.9797496825089, -95.6732864656963
30.9801807436691, -95.6733169271828 30.9809894574356, -95.6733701622396
30.9813194221715, -95.6734999395471 30.9819507549468, -95.6737974442697
30.9826393051876, -95.6740723237723 30.9836902645845, -95.6743774344842
30.9844398513281, -95.6746369816124 30.9848404004521, -95.6751099148521
30.9852008848084, -95.6755219432239 30.9854507482067, -95.6769179517857
30.9860706283288, -95.6772993076374 30.9861698105029, -95.6776807763994
30.9862403829352, -95.6785432148145 30.9863395751764, -95.6791990539294
30.9863395620295, -95.6804809566761 30.9865093252655, -95.6810303351658
30.9867992441041, -95.6811829929081 30.986949922687, -95.6812361995003
30.9870891539813, -95.6813124983894 30.9874401045379, -95.6810227583307
30.9880905186186, -95.6809005694431 30.9882698034458, -95.6806794031657
30.988479615022, -95.679969602948 30.9892902294034, -95.6796415452413
30.9895896846701, -95.6794126482104 30.9897499043846, -95.6778564488703
30.9907207487017, -95.6767424708735 30.9912395464735, -95.6755064164274
30.991699214491, -95.6747512414009 30.9919109319386, -95.6744081138873
30.9920501741221, -95.6738664666509 30.9923496337555, -95.6728362547506
30.9926109308785, -95.6724701678248 30.9926490816922, -95.671539251651
30.9927597016093, -95.6707916263053 30.9930591571244, -95.6705473480381
30.9931793179303, -95.6702573964435 30.9933795854634, -95.6696321337844
30.9939403606157, -95.6693495346318 30.9945201851836, -95.6692274321401
30.9949493354574, -95.6695939276705 30.9955902125715, -95.6697923728458
30.9961109233667, -95.6698683654362 30.9965896553004, -95.6700135783425
30.9971809419619, -95.6699599052405 30.9976005540686, -95.6698378036489
30.997829434127, -95.6695326350303 30.9982299759114, -95.6693571335378
30.9983501403328, -95.6684494690214 30.9988498696594, -95.6680832237913
30.99909973168, -95.6676330996269 30.9994602198247, -95.6674424702628
30.9997005520141, -95.6671598880635 30.999931332486, -95.6670304140381
31.0000419651338, -95.6662996712472 31.000868593331, -95.6658326264722
31.0015792907461, -95.6654205058545 31.0021305100732, -95.664428678405
31.0031890834096, -95.664077699931 31.0037498430291, -95.663848711189
31.0043106008601, -95.6632614590157 31.0064506541903, -95.6628876068513
31.0072994246575, -95.6627425533096 31.007930753542, -95.6626512585398
31.0081501094372, -95.662147628518 31.009019855579, -95.6621475711233
31.0092296613373, -95.662078713618 31.0094394623399, -95.6613922279007
31.0107097629057, -95.6609800792858 31.0113296446809, -95.6607131126869
31.0116805992536, -95.6597366034108 31.0127506219894, -95.6595079228182
31.01306915936, -95.6583632284451 31.0152797669008, -95.658050709948
31.0160198245663, -95.6579971544525 31.0162792191768, -95.6579971271896
31.0164794883405, -95.6580733242391 31.0168399801246, -95.6581879008691
31.0170707712624, -95.658279300387 31.0171794819378, -95.6587294687763
31.0174198146875, -95.6609879877791 31.0182991041695, -95.6618270468869
31.01852989057, -95.6626662272531 31.0188102721228, -95.6639022158139
31.0191001909653, -95.6641313541339 31.019180307306, -95.6645432688684
31.0194091841281, -95.6647872107359 31.0194892858882, -95.6653212234339
31.0195598607093, -95.6661299838196 31.0197105352724, -95.6663435238785
31.0197906448717, -95.6667710858267 31.0200100025493, -95.667137201698
31.0202693969832, -95.6675569187433 31.0207290666442, -95.6678390931056
31.021230702799, -95.6682280407925 31.0222206108568, -95.6684417477321
31.0226192429797, -95.6686402429467 31.0231399617134, -95.6689301067362
31.02424049964, -95.6690214750564 31.0249595604426, -95.6689988188295
31.0257396780061, -95.668952889791 31.0259990654824, -95.6688538268866
31.0262393928097, -95.6685791648172 31.0268096975868, -95.6681824380563
31.0273895266447, -95.6678467218155 31.0277996079548, -95.6674119796867
31.0282402045526, -95.667190491699 31.028419493854, -95.6659927700621
31.0291995981059, -95.6656724483108 31.0294399281318, -95.6651077785201
31.0299301114433, -95.6648637524258 31.0301990614288, -95.6635207165801
31.032049175793, -95.6627577920477 31.0332298244104, -95.6625594408332
31.0334796879465, -95.6623686124767 31.0336704148702, -95.6621705896835
31.0338001331293, -95.6619034273398 31.0339107498899, -95.6610182548057
31.0341396331985, -95.6598587713241 31.0342693373579, -95.6582717777319
31.0342903123494, -95.6577226353087 31.0342598040249, -95.6563874667061
31.0340690606429, -95.6554490477455 31.0340900416193, -95.6545563533635
31.0341606201253, -95.6531904203214 31.0344200065113, -95.652091792405
31.0344791313596, -95.6513212194526 31.0346603358472, -95.65065782389
31.0349292771304, -95.6499708239804 31.0353107351466, -95.6495972809336
31.0354805030794, -95.6489106379306 31.0356807784334, -95.6476518546756
31.0359497148491, -95.6466291550802 31.0362701305277, -95.6462934641082
31.0363998300555, -95.6452332974012 31.036890032975, -95.6447679476703
31.0372104741729, -95.6438905490814 31.0379791264832, -95.6435775757335
31.0383701281469, -95.6426008501098 31.039789192253, -95.641998175786
31.04107093101, -95.6415784786946 31.0417098928081, -95.6413116682493
31.0419502273901, -95.64106732953 31.0421199732002, -95.6407927898367
31.0422592193727, -95.640533390813 31.0423393208944, -95.639808704477
31.0424003631902, -95.6391829191613 31.0423908214872, -95.6384813018269
31.0422992711156, -95.6381071447393 31.0422306038448, -95.6375427575234
31.0420703868574, -95.637336563375 31.0419692927529, -95.6371995311648
31.0418090830271, -95.6367186630433 31.0408306102234, -95.6364136197939
31.0397796634487, -95.6358794730233 31.0383796683376, -95.6356734881038
31.038049700945, -95.635528732115 31.037900930103, -95.6346969968793
31.0372505246838, -95.6336211992556 31.0366001114614, -95.6331865332047
31.0364303634677, -95.632659943372 31.0363101957741, -95.6322786283201
31.0363102062091, -95.6312025243048 31.0366592320745, -95.6307296075672
31.0369606017218, -95.6306001387377 31.0371208287358, -95.6305314634079
31.037359237969, -95.6305388656867 31.0376396176086, -95.6306302950389
31.0379199909428, -95.6311265018149 31.0386695890374, -95.6314697477466
31.039300919406, -95.631530901131 31.0395698626007, -95.6315077829983
31.0397491372373, -95.6314009470467 31.0399303389568, -95.631080656173
31.0402793933233, -95.6308364287582 31.0404205330637, -95.6295090799844
31.0410003704394, -95.6288070695994 31.0414695750262, -95.6285627767415
31.0417499510147, -95.6283722859044 31.04206085185, -95.628196829581
31.0424099008752, -95.6279295415372 31.0430908145273, -95.6278379718222
31.0433998047957, -95.627777188654 31.0440197014758, -95.6278305267846
31.0443706546199, -95.6279831502152 31.0447292370404, -95.6284333397529
31.0454101553039, -95.628791671626 31.0460700932314, -95.6293104975641
31.0472297627073, -95.6295395563849 31.0479507470748, -95.6295625757282
31.0486793609067, -95.6295166771863 31.0494098696492, -95.6295167952407
31.0505199494374, -95.6296005129858 31.0512599903095, -95.6297835506079
31.051929472173, -95.6298904559081 31.0521697984959, -95.6300275912692
31.0523796049825, -95.6308517664399 31.0529708887276, -95.6318513369255
31.0534305627139, -95.6326370381542 31.0537300108804, -95.6340713489015
31.0541095762293, -95.6345902916808 31.0541896821548, -95.6351929861015
31.0541896912316, -95.6367417485088 31.0540599868881, -95.6381987535878
31.0540103881824, -95.6394730124638 31.0541305546042, -95.6415099625667
31.0541400894345, -95.6420975137885 31.0541992206827, -95.6444473848076
31.0545902253444, -95.6449432950624 31.0546493576091, -95.6465531554999
31.0546608011685, -95.6468581333701 31.0547294598277, -95.647033868917
31.0548496271553, -95.6471708958277 31.055019372396, -95.6473386690396
31.0554504287698, -95.6473924235554 31.0557594367742, -95.6474532144702
31.0567302694414, -95.6475599998241 31.0578403403638, -95.6477204550067
31.0586204561146, -95.6478881344989 31.0590190872663, -95.6481780833154
31.0593700364518, -95.6486131618652 31.0596809459598, -95.6492308962921
31.0602397891567, -95.6495590303832 31.0604400682632, -95.6501083910066
31.060720440256, -95.6510924799999 31.0613803798731, -95.6516798456356
31.0619907355413, -95.6517867371615 31.0622501361768, -95.6520461080907
31.0631599384737, -95.6525879873359 31.0644092566987, -95.6527403436298
31.064689628821, -95.6532135588736 31.0652503974304, -95.6542665196148
31.0663795572736, -95.6544265826008 31.0665798242119, -95.6546401312957
31.0669307698078, -95.6546782879562 31.0671100551857, -95.6546326440056
31.0674400368714, -95.6544801138096 31.0676403135173, -95.6541139079602
31.0679607435248, -95.6538466717519 31.0681400248061, -95.6535416570335
31.0682792729476, -95.6531601211322 31.0683593742336, -95.6522063415656
31.0684108684607, -95.6505509085936 31.0683498400286, -95.64933764158
31.0684299377229, -95.6486435013635 31.0685100546021, -95.6483915613079
31.0686092335737, -95.6480865180465 31.0688095111626, -95.6480407489586
31.0688991551621, -95.6480331864414 31.0692100569575, -95.6481172533833
31.0696601921656, -95.6482696237092 31.0698795267172, -95.6489412363804
31.0703392149101, -95.6500626654502 31.070800784576, -95.6505812440645
31.0710296620072, -95.6510390482448 31.0713005009206, -95.6523893644252
31.0722408206864, -95.6536712962841 31.0729808807188, -95.6541519861397
31.0734500855218, -95.6542203977863 31.0736503518874, -95.6542968129704
31.074119564313, -95.6543503583994 31.0746593528838, -95.6544038664959
31.0749397347791, -95.6545104055029 31.075250624961, -95.6546708129297
31.0763893203132, -95.6548997345623 31.0771102928084, -95.6550215568281
31.0772895738353, -95.6555633384807 31.0778408013691, -95.6557007737392
31.0780200964735, -95.6557692316198 31.0782108258174, -95.6558302215028
31.0788497889047, -95.6559068737804 31.0791492569566, -95.6560821599884
31.0794105537566, -95.6565932950069 31.0797500583752, -95.6568910659608
31.0798206443783, -95.6581879762483 31.0800304437185, -95.6598435468924
31.0800495206261, -95.6602326296305 31.0801105563655, -95.6605833332582
31.0801792051619, -95.661033768876 31.0803508856748, -95.6612471207608
31.0804901029189, -95.661506526053 31.080820080139, -95.661651650748
31.0811195360801, -95.6616975679078 31.0815391637865, -95.6617432613919
31.0825805703414, -95.6619722017631 31.083059320246, -95.6623384347354
31.0836601283918, -95.6624373823942 31.0837802872675, -95.662719754309
31.0839595809351, -95.6631470114726 31.0840091768219, -95.663612259744
31.0839900897313, -95.6637726686625 31.0839405089231, -95.6640318853078
31.0837707514867, -95.6657029685637 31.0822105421206, -95.6669081430668
31.0812396917401, -95.6676406795564 31.0807094555874, -95.6682968597353
31.0803508767018, -95.6689986803464 31.0800094584542, -95.6708069910919
31.0789699633625, -95.6713716005712 31.0784606984555, -95.6718214844492
31.0779304417147, -95.67231739549 31.0774002051767, -95.6725463950992
31.0771904028484, -95.6732710250892 31.0766391744038, -95.6740493957469
31.0761203756384, -95.6743088577997 31.0759792397163, -95.6748731999572
31.0757102907756, -95.6752699939399 31.0755596098623, -95.6759491076314
31.0755195638847, -95.6765213579345 31.0757408122848, -95.6767427253433
31.0758800596132, -95.6772077676062 31.0763091978538, -95.6776962677016
31.0768203799924, -95.6780089720279 31.0772895796973, -95.6784286999649
31.0781307257867, -95.6790315352478 31.0785408092735, -95.6792604281182
31.0785598841267, -95.6795272974361 31.0785102828977, -95.6798706943364
31.0783805827871, -95.6801606500161 31.078220370603, -95.6811903167697
31.0775108323814, -95.6815337045416 31.0773200961844, -95.6823271534625
31.0769691458158, -95.683807566582 31.0763893192531, -95.6841583204059
31.0762996675539, -95.6843108279708 31.0762996697171, -95.684700031693
31.0763492636258, -95.6849289252915 31.0764293706811, -95.6851808013095
31.0765495376778, -95.6856079355063 31.0770206429872, -95.6858062943319
31.0773391783135, -95.6860276178203 31.0776195552637, -95.6866606305896
31.0787696784248, -95.6874998395346 31.080059050605, -95.6876982991051
31.0802707675002, -95.688530122804 31.0809002001305, -95.6892011706095
31.081220624022, -95.6894988590534 31.0813198062132, -95.6897811406393
31.081449504956, -95.6905211117571 31.0816898298154, -95.6914063627576
31.0817909308604, -95.691726534929 31.0818099971997, -95.6921233093597
31.0817909168502, -95.6924973886812 31.0817604082072, -95.6930695208967
31.0816707663561, -95.6933595250225 31.0815792173824, -95.6940383534239
31.0812397021884, -95.6944425705626 31.0809001860971, -95.694801293694
31.0803298941648, -95.6949614778288 31.0798206297115, -95.6952669063913
31.0786209181583, -95.6955489030402 31.0778198186035, -95.6956865129957
31.0776291001729, -95.6959762040324 31.0773601489045, -95.6962892439692
31.0771408153883, -95.6966706607075 31.0769405364195, -95.697280901406
31.0766906702115, -95.6976165531806 31.0765895856907, -95.6983337219136
31.0765399934614, -95.6986312675579 31.0765895869687, -95.6988984414312
31.076690683342, -95.6991502645193 31.0768299161482, -95.6996308276519
31.0772895824318, -95.6998517910215 31.0775699542092, -95.7000886408077
31.0779495236401, -95.7002792001263 31.0782909343606, -95.7007521298341
31.0794792145064, -95.7013319939053 31.0803508761051, -95.7024688598337
31.0813503230932, -95.7028274035615 31.0818004622999, -95.7036283925631
31.0823097213414, -95.7037885843118 31.0822906476492, -95.7039794425775
31.0821609469341, -95.7041168158981 31.0820102700189, -95.7042998572292
31.08163070102, -95.7044219811334 31.0812702219698, -95.7045365319555
31.080680845398, -95.7045822306913 31.0801792193855, -95.7045365605636
31.079969405359, -95.7045594284812 31.0798893057597, -95.7050016556158
31.0789699462759, -95.7055589619401 31.077949526554, -95.705680784983
31.0777797672337, -95.7059096241097 31.0776595982318, -95.7062300772532
31.0776195489515, -95.7066269000687 31.0776691487909, -95.7070311390991
31.0777492486795, -95.707359309403 31.0778999288504, -95.7077482503642
31.0783596022086, -95.7083280758393 31.0797691246489, -95.7087175092155
31.0804290787082, -95.7089689628642 31.0806999204793, -95.7098311600736
31.0813598580819, -95.7103806109443 31.0815391529743, -95.7113800256756
31.0817794757343, -95.7117311239446 31.0817699511129, -95.7124406610917
31.0815105513467, -95.7127305680796 31.0813503298678, -95.7134397631804
31.0808696728988, -95.7141569714249 31.0805206214172, -95.715332051962
31.0801200870049, -95.7159424306157 31.0799808490382, -95.7170564621278
31.0798397153627, -95.7174683972499 31.079830172022, -95.7182464998274
31.0798492438134, -95.7192381247894 31.0798206307342, -95.7199020343966
31.0797100049088, -95.7203064334467 31.0796108270399, -95.7209394849009
31.0795097313687, -95.721893447437 31.0794200959403, -95.722389189322
31.0794601425553, -95.7232284617187 31.0796394308626, -95.7235336306593
31.0797595948017, -95.7238081277633 31.0799293474138, -95.7249299196279
31.0809307122537, -95.7253419902793 31.0813503351166, -95.72563160595
31.0817604081433, -95.7257692086924 31.0820007343013, -95.7260664532849
31.0826396915393, -95.7262114470093 31.0829906420335, -95.7264099723268
31.0836792017114, -95.7264631473555 31.083980549969, -95.7264100441518
31.0843391454078, -95.7263795731973 31.0849399678935, -95.7264022273339
31.0852699275061, -95.7266004889009 31.0859908967576, -95.7268980649228
31.0864200586059, -95.7277679134309 31.0874004335447, -95.727928314638
31.0875797359454, -95.728172482159 31.0877304110529, -95.7284089782681
31.0878295939322, -95.7286224163858 31.0878105166987, -95.7291411466524
31.0876007017594, -95.7304229464402 31.0871601087887, -95.731109768065
31.0866508576569, -95.7313994078367 31.0864696452145, -95.7315901125521
31.0862808216213, -95.7320480233206 31.0856990854435, -95.7327802858053
31.0846195185892, -95.7332611035033 31.0841503142475, -95.7342374859051
31.0835399531497, -95.7347565844428 31.0834007280468, -95.7355270776028
31.0834293419925, -95.7358015133528 31.0835304187035, -95.7361297078379
31.0836200684176, -95.7364731532823 31.0837707510575, -95.7368317095455
31.0838794754199, -95.7371824183049 31.0839404993919, -95.7375564543722
31.0839195236546, -95.7378386790581 31.0839900987115, -95.7381134868513
31.084100730391, -95.7385176312188 31.0845909116754, -95.7388306121983
31.0852203396626, -95.7390517361869 31.0858097099956, -95.7391129430097
31.0865802814825, -95.739127967593 31.087469091075, -95.7392808282589
31.0883197797985, -95.7394638136993 31.0889205918599, -95.739578369193
31.0892200486226, -95.7399291190172 31.0897407483542, -95.7404172834103
31.0903301161158, -95.7410202319626 31.0907096892761, -95.7414017625279
31.090780265011, -95.7425308579802 31.0907592796332, -95.7428131872573
31.0907306686406, -95.743858486571 31.0904998840083, -95.744628717348
31.0904292977566, -95.7452162295768 31.0904598162546, -95.7463987841757
31.0906200367527, -95.7470704987808 31.0908603773027, -95.7476500494238
31.0911293003454, -95.7484815523865 31.091430658894, -95.7487106940525
31.0915603688835, -95.7490995450711 31.091850277196, -95.7492676737537
31.0919303941935, -95.7496489610552 31.0919799750239, -95.7498474861225
31.0920696286394, -95.7498997725411 31.0920556617755, -95.7499772263123
31.0920600959785, -95.7501221622988 31.0919799859539, -95.7502136039018
31.0920295680584, -95.7503508905755 31.0920391018043, -95.7508161581195
31.0919399163058, -95.7515336073802 31.0918502868235, -95.7521669469407
31.0916194978685, -95.7526322312779 31.0913600995161, -95.7534638499987
31.0908603730092, -95.7546616394129 31.0896797210302, -95.7549820056454
31.0892600982728, -95.7550889604155 31.0891609265299, -95.7557908113004
31.0886707331473, -95.756072851988 31.0885505660228, -95.756393519209
31.0884704588883, -95.7565992859325 31.0884704551079, -95.7568132255881
31.088520058322, -95.757393019847 31.0887394047979, -95.7580339342218
31.0888195115861, -95.7581712750512 31.0888099758468, -95.7585526225998
31.0886802734473, -95.7590790017258 31.0885391209808, -95.7594605391946
31.0885295933476, -95.7598723243541 31.0886306705384, -95.7603303683416
31.0888691006812, -95.7606736413892 31.0889892655298, -95.7610167682667
31.0892105111363, -95.7614898549786 31.0895595540665, -95.7620164055692
31.0902595597241, -95.7623062599271 31.0907306657318, -95.7626723262445
31.0911006853941, -95.7630235495352 31.0916404816142, -95.763473453529
31.0926208528394, -95.7639082661254 31.0937499974229, -95.7639953628138
31.0939519116358, -95.7640456664782 31.0940685290159, -95.7643510904395
31.0954399223146, -95.7644501736963 31.0960407271528, -95.764953446713
31.0971794036939, -95.7650605421461 31.09737968948, -95.765197894373
31.0975303736155, -95.766120851041 31.0984001103667, -95.7662889230447
31.0988292778925, -95.766372580224 31.0994796679685, -95.7663267737459
31.1000709493357, -95.7661971164959 31.1006393443631, -95.7661132117987
31.1008491482995, -95.7658081573817 31.1013202700894, -95.7657698662917
31.1016197196917, -95.7658081041725 31.1019001048577, -95.7658689642321
31.1021404194609, -95.7661514085785 31.1025905640457, -95.7663421934126
31.1027908363587, -95.7670896643496 31.1033706632932, -95.7676467600937
31.1039905588658, -95.7678070388719 31.1042995421329, -95.7681577618911
31.1055202457308, -95.7682571946155 31.1061496773462, -95.768348725972
31.1065006284868, -95.7686995443216 31.1075591962364, -95.7689972998818
31.1082305901874, -95.7695009104267 31.1091594748166, -95.7698973010425
31.1099796215248, -95.770172023242 31.1107005953432, -95.7703018842105
31.1109294970283, -95.7707674006721 31.1114502003272, -95.7707899708616
31.111509324814, -95.7713396086005 31.1120205096117, -95.7717207553429
31.1124496424366, -95.7723770711411 31.1131000470134, -95.772468386904
31.1133403751939, -95.7726363026048 31.1139793342902, -95.7726591959101
31.1141204701465, -95.772552646777 31.1147899764526, -95.7725525003783
31.1154708898284, -95.7724761059427 31.1158790605441, -95.7723768281004
31.1170196368327, -95.7723924074997 31.1172790487098, -95.7724761255767
31.1175994747185, -95.7729492938988 31.1181202055802, -95.7739179543009
31.118789660225, -95.7755127483886 31.1195793092976, -95.7759934974599
31.1198692291609, -95.7768477570709 31.1205901984218, -95.7770463857221
31.120840088972, -95.7770614186736 31.1209602388638, -95.7769928784314
31.1211490571218, -95.7767869212559 31.121330255392, -95.7761079262257
31.1217098264369, -95.7757797057552 31.121849059193, -95.7754209547662
31.1219100892989, -95.7752304831607 31.1219692236772, -95.7748186071693
31.1222591408858, -95.7744902574805 31.1225795748316, -95.7742994976906
31.1229305288266, -95.7741012004699 31.1234493335395, -95.7740174996999
31.124029160338, -95.7740172007018 31.124799740176, -95.7740171540795
31.1249198944306, -95.7740039921447 31.1249630993773, -95.7738039074329
31.1256198859457, -95.7733383603394 31.1263999901671, -95.7727278639694
31.127250659508, -95.7724915517192 31.127670286834, -95.7722395850937
31.1280193252512, -95.7721022684276 31.1283302240921, -95.7720720119734
31.1284599290751, -95.7721483206049 31.1286601977377, -95.7726365368963
31.1292305118282, -95.7730485817915 31.1298294201505, -95.7732999744105
31.1300907111895, -95.7737503060885 31.1307201445452, -95.7739409745206
31.1310405773688, -95.7742615321847 31.1317596356136, -95.7747724621864
31.1326007850854, -95.7750930774422 31.1332206779154, -95.7752988822345
31.1337394643469, -95.7753600453968 31.134000785062, -95.7754286603183
31.1348991324241, -95.775421110717 31.1354599071681, -95.7754133142783
31.1355800548654, -95.7753218167812 31.1357803227094, -95.7749864045679
31.1363105899989, -95.774673520917 31.1369991426053, -95.7741011929684
31.1375694169306, -95.7738418615305 31.1380195680938, -95.7735595220273
31.1384201070142, -95.7731171759633 31.1389408132548, -95.7729490498406
31.139099117315, -95.7726363267093 31.1392307233758, -95.7717895170988
31.139419560166, -95.7701493434729 31.1394901385572, -95.7689971450633
31.1397094672245, -95.7684631104333 31.1397209233579, -95.7671967194462
31.1398696968187, -95.7667388741769 31.1399593343708, -95.7663725794677
31.1399993880546, -95.7660978655517 31.14006042487, -95.7659682340187
31.1401195403144, -95.7656021957794 31.1403408085904, -95.7651671768914
31.1406707821962, -95.7648162128374 31.1410198171886, -95.7646789672746
31.1412391625397, -95.7642212448627 31.1422691433316, -95.7636794858551
31.1431102654695, -95.7635194595786 31.1433105553755, -95.7632828695706
31.143529897064, -95.763160755537 31.143590931889, -95.7628631105565
31.1436805756403, -95.7625198325587 31.1436805726922, -95.7620087518176
31.143590936735, -95.7615508924159 31.1434402392368, -95.7611921437072
31.143259048894, -95.7609022067841 31.1430797479845, -95.7592621817017
31.1418209094481, -95.7584611389588 31.1414108215755, -95.7580183598076
31.1410503298434, -95.7578965401328 31.1409893120836, -95.7569810213715
31.1407909394474, -95.7566375267871 31.1407604256871, -95.756553638036
31.1407909454476, -95.7563017946479 31.1409397190008, -95.7559889661282
31.1412506026744, -95.7555467174214 31.1422195567375, -95.7555009920879
31.1425495215144, -95.75537118411 31.1431007336858, -95.7552718094056
31.1439895611047, -95.7553331138529 31.1451702210994, -95.7552415005978
31.1457004493845, -95.7551194382589 31.1459999075575, -95.7548598255156
31.1464004527119, -95.7544096058702 31.1469593057697, -95.7542115096863
31.1473102673482, -95.7536698421044 31.1485195201253, -95.7534332351396
31.1488094307738, -95.7531129346474 31.1490898087822, -95.7526475907221
31.1493797316475, -95.7523270723074 31.1495494787545, -95.7515714939585
31.1498794445139, -95.7510376408538 31.1501693644964, -95.7500077472282
31.1509494900333, -95.7492980000485 31.1515502873559, -95.7477570460607
31.1533203235408, -95.7465973416826 31.1540107673922, -95.7438888709618
31.1519203278571, -95.7425764814942 31.1520805312994, -95.7411193822194
31.1540393788313, -95.7399979336189 31.1562194785696, -95.7387771396736
31.1577701650817, -95.736778230734 31.1594104705721, -95.7355804884467
31.1596107433249, -95.7315521273951 31.158569335403, -95.7295074598061
31.1601200204992, -95.7280119950523 31.1621208100648, -95.728393751873
31.1637191937909, -95.7312316420447 31.165500635164, -95.7342606795383
31.1677608536242, -95.7363969811721 31.1697597567069, -95.7388611468234
31.1718997954126, -95.7410203475607 31.1738395792934, -95.7426070706702
31.1757698129412, -95.7440873048605 31.1783103972981, -95.7450866397047
31.1816596998133, -95.7451780311109 31.184219354555, -95.7448579411256
31.186679851473, -95.7447126537428 31.1908302211335, -95.746101565533
31.1955204144065, -95.7472764938807 31.1990604416414, -95.7476426014885
31.2022209127439, -95.7478715792483 31.2031402670539, -95.7477186943482
31.2066898287289, -95.7465363003521 31.2100296113584, -95.7445068240056
31.2115001627039, -95.7430876009054 31.2127800025938, -95.7420729275513
31.2154293040593, -95.7401963620348 31.2174491950125, -95.7371980265517
31.2192306580612, -95.7345275986754 31.2200202982472, -95.7308426029437
31.2214603449044, -95.7290269725336 31.2234192046748, -95.727538949157
31.2248191824042, -95.7264402329052 31.2262001074167, -95.7250136758358
31.2283802041588, -95.7250977969366 31.2312297905692, -95.7261581649401
31.2343101517711, -95.7269286611313 31.2379207699975, -95.7269210697116
31.2402401072445, -95.7253724929238 31.2427005872626, -95.7240831186684
31.2440891281229, -95.7233199980078 31.2446803998875, -95.7237702406021
31.2464008397547, -95.725723413751 31.2480697787106, -95.7265699349877
31.2492694688855, -95.7268980691356 31.2499904612181, -95.7271499615129
31.2503509431798, -95.7275466453451 31.2507991691123, -95.7279508986833
31.2513809215117, -95.7280120933981 31.251499178884, -95.7279893561093
31.2516994509509, -95.7276384201046 31.2521591200725, -95.7273863600749
31.2523403188193, -95.7266617592063 31.2526302341229, -95.726509151765
31.2526702906273, -95.7261581876579 31.252689363897, -95.7256698862122
31.2528095238919, -95.7254027692369 31.2528190525571, -95.7249832589742
31.2528991723959, -95.7243421937234 31.25308035935, -95.7240904294232
31.2532195965599, -95.7238618717002 31.2532806539956, -95.723503100297
31.2533302257255, -95.7228699168818 31.2535495785281, -95.7224122635332
31.2537803598042, -95.7221528703401 31.2539901820379, -95.7219924665324
31.2542190526799, -95.7218704737469 31.2544498477782, -95.7218093396337
31.2547092332215, -95.7218017574407 31.2549991537638, -95.7218626366314
31.2552299544158, -95.7220535732921 31.255449301661, -95.7225799565416
31.2558498402254, -95.7235718477508 31.2564907178867, -95.7251663280181
31.2572593707696, -95.7261734913461 31.2578296784669, -95.7272871310539
31.2583694328745, -95.7277069347241 31.2586097809789, -95.7280577603935
31.25885010486, -95.7285383704878 31.2592792365179, -95.7286682818968
31.2594299247181, -95.7287522573996 31.2596206622289, -95.7287063784675
31.259880064554, -95.7285384819591 31.2603092287375, -95.7284623154002
31.2604408263313, -95.7283020122562 31.26057052347, -95.7277833028223
31.2611293903752, -95.7276075411673 31.2613697063052, -95.7273711200134
31.2617797881192, -95.7270889100421 31.262420653974, -95.7270277521802
31.2626895875463, -95.7270203695599 31.2630901334162, -95.7271271078564
31.2645797778053, -95.7271272268664 31.2648506234096, -95.7270201488024
31.2655296320735, -95.7268675411475 31.2660102791481, -95.7267530687869
31.2662696701887, -95.7264329219345 31.2668094645812, -95.72612017487
31.2674598666543, -95.7258375879672 31.2683906531765, -95.7255937217672
31.2690696733343, -95.725288228337 31.2700805574422, -95.7251129731755
31.270820626429, -95.724853688378 31.2711506033298, -95.7244569424325
31.2714691122442, -95.7238768978082 31.2717609363188, -95.7234420269002
31.2718505823667, -95.7224120605207 31.2719192512292, -95.7218703391372
31.2720298736169, -95.7207412754535 31.2723808273473, -95.7200699990428
31.2726497679596, -95.7190169868915 31.2731800075714, -95.7179031869103
31.2736091546242, -95.7164001977443 31.2742691089966, -95.7146532016824
31.2747993571017, -95.7140426723723 31.2749404960367, -95.7136994546803
31.274990090575, -95.713439917415 31.2750606518447, -95.7131576598459
31.2751808073493, -95.7128678890995 31.2753601188828, -95.7125091025997
31.2756805473436, -95.7121198699225 31.2760791676338, -95.7114714332499
31.2766990522252, -95.7109528453495 31.2772598330809, -95.7093428149273
31.279409410345, -95.7090072803909 31.2796592707087, -95.7086182496069
31.2798595403574, -95.7084272901589 31.2799301112968, -95.7082671636093
31.279949192445, -95.708068997304 31.2799491937483, -95.7066268698905
31.2797298487552, -95.7057495648148 31.2797298413859, -95.7049713621616
31.2800102313099, -95.7043608696797 31.2801494603215, -95.7039871051506
31.2803401866283, -95.703712300108 31.2806301058837, -95.7033233900025
31.2812309213356, -95.7032317336298 31.2814807804526, -95.7032014526389
31.2817306565217, -95.7032394380785 31.2820491775616, -95.7034531115162
31.2825698907933, -95.7035597146033 31.2827301001142, -95.7046583395449
31.2837600552211, -95.705169791609 31.2841205546309, -95.7059937026971
31.284429547195, -95.7066878861518 31.2847595103746, -95.7069090549382
31.284879675001, -95.7073823956196 31.2853107412416, -95.7074278202267
31.2854404302061, -95.7074509880281 31.2856006768133, -95.7073898510248
31.2859992952776, -95.7072524372058 31.2863902988121, -95.7064132012593
31.2878208088199, -95.7056504893351 31.288919462615, -95.7052992349195
31.2895298036658, -95.7041929371261 31.2909298004724, -95.7038191640929
31.2913303309124, -95.7036131415442 31.2915191420118, -95.7028733635091
31.2920799104716, -95.7024232802363 31.2924995509599, -95.7021333138863
31.2926902687054, -95.7015609819576 31.2930107256229, -95.7010269753463
31.2932300399024, -95.69995112985 31.2938308534937, -95.6987074785128
31.2943897332563, -95.6982499287624 31.2946300498252, -95.6974105789564
31.2951297807885, -95.6962510624809 31.2956905572235, -95.6954881430159
31.296089170669, -95.6950224557357 31.2964191408643, -95.6945570672458
31.2966899906451, -95.694053718755 31.2969398698976, -95.6933592180262
31.2971496492515, -95.6927795598081 31.2972698230269, -95.6918565152781
31.2973098988797, -95.6910780032293 31.2971992319844, -95.6905822633652
31.2970905465336, -95.6902314553266 31.2969799036198, -95.6901015232329
31.2968998054866, -95.6896665582263 31.2964897031746, -95.6890409476956
31.2955303074561, -95.6881637535852 31.2943706510197, -95.6878127622163
31.2938709362229, -95.6870423739691 31.292509066315, -95.6867293182188
31.2921009040704, -95.6864928121217 31.2918605578361, -95.6850204035694
31.290489192407, -95.6849366278235 31.2904701128344, -95.6846389128979
31.290269841659, -95.6834489151854 31.2892494256035, -95.6823274047806
31.2883892084871, -95.6820678168905 31.2882499865179, -95.6815567222488
31.2880401676255, -95.6812285504881 31.2879791340158, -95.6808168096937
31.2879905929379, -95.6804961917804 31.2880706834802, -95.6803588031653
31.288179382778, -95.6801988225614 31.2883606108158, -95.6797715744296
31.2897300583548, -95.6793137136275 31.2907790986438, -95.6791993896196
31.2909793697822, -95.6789475428217 31.2912998339578, -95.6784517301488
31.291690821225, -95.6779938623204 31.2919807455214, -95.6773909578677
31.2922401232007, -95.6769792584925 31.2924595111948, -95.6750717860737
31.2935695459497, -95.6742781305493 31.2939891844058, -95.6731413889641
31.2945403974841, -95.6727598403532 31.2946796471322, -95.6721268029931
31.294860833629, -95.6715776243699 31.2951202374979, -95.67111213622
31.2953395954521, -95.6707304137898 31.2955608335328, -95.6706465994682
31.2956905537187, -95.6706315941302 31.295850743767, -95.6707612690609
31.2963104313378, -95.6709975494786 31.2967205068495, -95.6713486620488
31.2970504810403, -95.6715773269744 31.2971992369215, -95.6721267623781
31.2975006257776, -95.6724012841886 31.297620761103, -95.672630390285
31.2977600039544, -95.6729886957801 31.2980995271437, -95.6732787223383
31.2987193920725, -95.6740876249447 31.2992591704186, -95.6745835075849
31.2993907952983, -95.6751478151365 31.29950906206, -95.6756666224828
31.29970929497, -95.6762238612344 31.299850446885, -95.6765822885017
31.2999000673041, -95.67739119379 31.3001003246657, -95.6781920533515
31.3004493730663, -95.6783523629751 31.3006801741557, -95.6786194122286
31.301399230302, -95.6787108677215 31.302019131632, -95.6785888102346
31.3025703548806, -95.6785127146747 31.3027591684414, -95.6784364789187
31.3028201931878, -95.6781006855309 31.3030109464041, -95.6777190358835
31.3031692597716, -95.6774216355323 31.3032493536928, -95.6771164842744
31.303279883018, -95.6768112083415 31.3032608041898, -95.6765135187577
31.3031902314745, -95.6762922952497 31.302879324015, -95.6758421114447
31.3025302795647, -95.6756363473763 31.302450186403, -95.675292956206
31.3023700897463, -95.6744536662718 31.3022193859596, -95.6738509471555
31.3021507125923, -95.6733169730785 31.3022098639694, -95.6729813746951
31.3023700591549, -95.6725767646277 31.3026695278281, -95.6712418950812
31.3039302911097, -95.6710282699744 31.3042297599232, -95.6707000454935
31.3045692593083, -95.6704101367892 31.3049392717519, -95.6701582189264
31.3053207347407, -95.6698835931288 31.3058204620082, -95.6693802400785
31.3065204537214, -95.6684036942179 31.3075008509721, -95.6682280197446
31.3076992142139, -95.6677778540137 31.3083591583544, -95.6677702595229
31.3086891332206, -95.6678697253702 31.3089599449881, -95.668067871728
31.3091792917366, -95.6689912327847 31.3099098322246, -95.6695634529898
31.310449587137, -95.6696931037069 31.3107795577425, -95.6697082271433
31.3109302508701, -95.6696776041125 31.311080945419, -95.6694183228248
31.3121700350258, -95.6692429462761 31.3127708569333, -95.6692125312698
31.3129692307051, -95.6692733603701 31.3133297051466, -95.6692808553783
31.3136806564263, -95.6693190191225 31.3138103288786, -95.6695710689726
31.3141403093602, -95.671096811658 31.3155593793465, -95.6712266730575
31.3157196053751, -95.6713182467 31.3159008100697, -95.6714172563346
31.3163299380556, -95.6714172553611 31.3165302387445, -95.6713865203084
31.3167095073032, -95.6710967790554 31.3172492763354, -95.6706618726354
31.3177604630308, -95.6701814591099 31.3183098045422, -95.6700362248918
31.3184394693945, -95.6694108822837 31.3187809155097, -95.668586813394
31.3190803390794, -95.6682969780032 31.3191604542397, -95.6674195320841
31.3192596564986, -95.6664885488422 31.3192405465729, -95.6655425078687
31.3194694526111, -95.6651917861953 31.3195991679214, -95.664039782495
31.3202991616034, -95.6634367712213 31.3205299411002, -95.6630632158594
31.32058906583, -95.6621626883908 31.3204402946949, -95.661949026151
31.3204002488422, -95.6617965337398 31.320339184562, -95.6610718225172
31.3198509260609, -95.6607970376959 31.3195095188065, -95.6604232819898
31.3187999917649, -95.6602934212036 31.3183707978859, -95.6602173733243
31.3180103189671, -95.6602174731486 31.3178691930588, -95.6602401941146
31.3177509302948, -95.660553054789 31.317050925926, -95.6606672668906
31.3166809165047, -95.6607206963898 31.3162193430897, -95.6606902596126
31.3160095166053, -95.6606294397139 31.3158492962022, -95.6605302500213
31.3157291433924, -95.6602706576786 31.3155803536601, -95.6601332163198
31.3155498325355, -95.6597670580759 31.3155708361342, -95.6592331918515
31.3156604868622, -95.658737279804 31.3158492956431, -95.6584702272723
31.3160095417714, -95.6583023785525 31.3161506581995, -95.6579972871699
31.3165607662709, -95.6573789844971 31.31720923921, -95.6567535985357
31.3181495549002, -95.6563261960039 31.3189392179282, -95.6561812961754
31.3193301981304, -95.6560823114459 31.3197002473184, -95.6559601123134
31.3204593867835, -95.6557615934817 31.3213500784945, -95.6556930735924
31.3219203871571, -95.6556778658837 31.3234291284916, -95.6555099803281
31.3259391872757, -95.6555634745447 31.3276805901958, -95.6555481029257
31.3284206442629, -95.6555403113272 31.3287105342811, -95.6553876923706
31.3295802931306, -95.6553880456874 31.3303794933402, -95.6556169432326
31.3323898217621, -95.655967782687 31.3339595615614, -95.6561888077217
31.3353595777589, -95.6563568545973 31.3359699418878, -95.6567762805548
31.3366908907625, -95.6570586536217 31.337320310777, -95.6573183140134
31.3381805433895, -95.6573563702195 31.338720342555, -95.6573104108352
31.3390197540677, -95.6573486769372 31.3400497561822, -95.6573179564563
31.3404102280644, -95.6572187402117 31.3411407501501, -95.6570511932454
31.3416995979387, -95.6569900147082 31.3419895264107, -95.6569823188958
31.3421993071009, -95.6570204550065 31.3427200139562, -95.6571884183972
31.3432197524081, -95.6573485039174 31.3434906034818, -95.657493636584
31.3436508005175, -95.6583709602766 31.3445491658455, -95.6592179758945
31.3451309454001, -95.6594999641386 31.3453006579384, -95.6596222815587
31.3453292937531, -95.6614303820532 31.3451805297709, -95.6621629749046
31.3449897906632, -95.6624679447991 31.3449401917129, -95.6631620978347
31.3449992959042, -95.6641770707549 31.3450393649796, -95.6674575236992
31.3447704333752, -95.6688691949851 31.3446693342658, -95.669700715085
31.344509136872, -95.6702728255465 31.3444900686636, -95.671356236368
31.3445606229282, -95.6722868244554 31.3444805128723, -95.6737976034834
31.3445892212579, -95.6748505138897 31.3448600902084, -95.67532340752
31.344999295598, -95.67578907417 31.3451995727426, -95.6759718108909
31.3453197356149, -95.6764829791473 31.345769856515, -95.6772002742323
31.3465995786964, -95.6773298894934 31.3470191718412, -95.6773835442719
31.347440713187, -95.6772919658433 31.347799309709, -95.677238537891
31.3478698555768, -95.6771316418582 31.347959498097, -95.6766434239054
31.348239905469, -95.6756895022389 31.3486690560784, -95.6750487651851
31.3490009182631, -95.6746977943764 31.3492298161282, -95.6744386662472
31.3494606053936, -95.6742172828613 31.3497696014262, -95.6736374690819
31.3510093601638, -95.6734008309415 31.3517799274302, -95.6732102806851
31.3528309123448, -95.6732026202084 31.3530406934957, -95.6731186052191
31.3535308864063, -95.6730119244465 31.3547306299334, -95.6726379298188
31.3555107274251, -95.6724166504505 31.355869283932, -95.6722411684004
31.3560791164023, -95.6715774870907 31.3563499454858, -95.6707609195086
31.3565406554489, -95.670349287189 31.3565693009416, -95.6686018859289
31.3565902729751, -95.6680067731969 31.3565406782491, -95.6672820266633
31.3565597382954, -95.6665113378233 31.3566608307277, -95.6655119307755
31.3567504660076, -95.6645737416791 31.3568706518662, -95.6637421959986
31.3568897338143, -95.6632078153272 31.3569507703143, -95.6621320898542
31.3569107055517, -95.6616819909906 31.3569202168102, -95.6611329974424
31.3570194121689, -95.6608276137695 31.3571205290028, -95.6606291029718
31.3572807378569, -95.6605531711449 31.3574295124755, -95.6604692144905
31.3578300638831, -95.6601790913732 31.3586692592744, -95.6602323487285
31.3588199535058, -95.6604538970092 31.359090815893, -95.6608580580924
31.359319703995, -95.6632231082024 31.3600006177306, -95.6633070123466
31.3601398588233, -95.6640318941945 31.3609008676968, -95.6641769699793
31.3612804470682, -95.6641999589687 31.3615303099255, -95.6640471171426
31.3625793379887, -95.6640397401786 31.3629302989973, -95.6640776651724
31.3637695488875, -95.6641921052052 31.3641605371676, -95.6643370303229
31.3645000338343, -95.6645584391227 31.3648700887623, -95.6649932015307
31.3654804261207, -95.6652373015109 31.3659591615053, -95.6659773151359
31.3664893880064, -95.6661531346625 31.3665599846275, -95.6663282798383
31.3666191015634, -95.6667173503441 31.3665409188453, -95.6671293578353
31.3664703312865, -95.6677170254693 31.3664302974985, -95.6692200069524
31.3661499013095, -95.6704178594441 31.3660602730701, -95.6707991477283
31.36595915996, -95.6711808687711 31.3659095938568, -95.6721572400723
31.3658599845395, -95.6731872886518 31.3657608143208, -95.673911984462
31.3655700817105, -95.6744003453742 31.3654804169291, -95.6748506454495
31.3654499270816, -95.6752470675932 31.3654994914179, -95.6754835317506
31.3657703128565, -95.6753311237713 31.3666992193862, -95.6753007180753
31.3674202215059, -95.6753233562525 31.3680095633358, -95.6753692144496
31.3681907664298, -95.6754913736663 31.3684501867123, -95.6756209539968
31.3686008255577, -95.6761169780091 31.3688506913006, -95.6763381067301
31.3688793323118, -95.6772538597287 31.3686905064386, -95.6779633993037
31.3686199427432, -95.67893986497 31.3684292004474, -95.6791763662874
31.3684291758451, -95.6799698255972 31.3684806675684, -95.6807098966828
31.3686103836495, -95.6811292572459 31.3686504454793, -95.6817094863629
31.3687896700771, -95.6819915282186 31.3688907623774, -95.6827391845912
31.3692398130849, -95.6829527328405 31.369380951702, -95.6832197939366
31.3696594368382, -95.6834335684755 31.3699703287033, -95.6837614880077
31.3707504428205, -95.6839293241392 31.371519083571, -95.6839906571485
31.3716697799177, -95.684257368739 31.3719997410016, -95.684760992297
31.372329722941, -95.6857910155796 31.3727302479796, -95.6864393710696
31.3728294304048, -95.6878892561548 31.373189929988, -95.6891328145326
31.3736190930645, -95.6899031658928 31.3739299861699, -95.6904984778448
31.3743801183142, -95.6908034575441 31.3745594096335, -95.6911085903716
31.3749103391559, -95.6912230656614 31.375049598366, -95.6912917402457
31.3751106437058, -95.6915207673842 31.3753700270359, -95.6921311746893
31.3764190582273, -95.6921997615146 31.3766307944603, -95.6922605660104
31.376819614, -95.6922074435411 31.3771896339396, -95.6920395424868
31.3776893783957, -95.6919480564314 31.3778190687874, -95.6918181183133
31.3778591210353, -95.6909867197067 31.378089928763, -95.6901322526777
31.3782195943964, -95.6897813495014 31.3783492894632, -95.6895826760829
31.3784694602039, -95.6890411660104 31.3789195907672, -95.6889419202383
31.3790607327516, -95.688888504554 31.3792095058057, -95.688903633918
31.3793697188277, -95.6889879272344 31.3795891067452, -95.6892622494443
31.3798503999959, -95.6896286209933 31.3801098040136, -95.6909179986559
31.3804702851521, -95.6913682113858 31.3806705366563, -95.6918562878975
31.3812007775657, -95.6923675259834 31.3818302248832, -95.6923829648278
31.3820800831619, -95.6922530557687 31.3822593746516, -95.6912078315904
31.3832893485519, -95.691116143407 31.383449539496, -95.6908491872705
31.3843307620298, -95.6908187242701 31.3851604462489, -95.6908798082816
31.3853607319155, -95.6910093256493 31.385540013758, -95.6921005045299
31.3863792537246, -95.6927797226232 31.3864994307091, -95.6930770906902
31.3866004950767, -95.6933897455686 31.3867797781638, -95.6940080219939
31.3874492771603, -95.6940687979881 31.3878402779839, -95.6940305858593
31.3880691572684, -95.6938323605202 31.388599381503, -95.6930314985445
31.3894405263628, -95.6927797048596 31.3898601377574, -95.6926726517411
31.3901100078046, -95.6926191578948 31.3904704889724, -95.6926267975082
31.3906803092129, -95.6926575003032 31.3909301637904, -95.6927412522599
31.3911705120658, -95.6930237488136 31.3916397023744, -95.6932221973583
31.391840000213, -95.6935502401924 31.3919906632577, -95.6940308903163
31.3920803188065, -95.694587644796 31.3921394407355, -95.6959076595305
31.3920898306355, -95.6973113231837 31.3921604054172, -95.698280163297
31.3922805537797, -95.6990889922873 31.3925094738556, -95.6994093441996
31.3926792156454, -95.69966129757 31.3928603977382, -95.7000501621064
31.3932704855662, -95.7005693028703 31.3945102699118, -95.7006530088561
31.3947696617377, -95.7007216882677 31.3952693939504, -95.7007600871825
31.396289832581, -95.7008667395627 31.3971004600821, -95.7008131206111
31.397850029699, -95.7008666386187 31.398540495459, -95.7012635131305
31.3995304056451, -95.7015302670895 31.4008006988761, -95.7015533226601
31.4012794660041, -95.7014768565784 31.4022998787683, -95.7014313028876
31.402540227437, -95.7012178250128 31.4030704656968, -95.700942839172
31.4035491726764, -95.7007370492697 31.403779997619, -95.7004928732412
31.4040508153224, -95.6993482840926 31.4050807918476, -95.6990203059748
31.4053306518843, -95.6982115089609 31.4058609092809, -95.6980590847687
31.4060401821196, -95.6979372009735 31.4062805057159, -95.6979066579304
31.4064998589369, -95.6980970351328 31.4068508275546, -95.6984634571362
31.4072608953449, -95.699180433244 31.4077701424282, -95.6995773317169
31.4079799451948, -95.700752101956 31.4087905712118, -95.7016984346241
31.4093094078029, -95.7022475517535 31.4096603547828, -95.7037583124686
31.4104595333257, -95.7050628285546 31.4110698702105, -95.7055205888815
31.4115390923525, -95.7059171724055 31.4120197414151, -95.7064665086541
31.4128493997038, -95.7068479522695 31.4137401678742, -95.7072295199991
31.4144000943935, -95.7078630353451 31.4153309022533, -95.7094419627351
31.4179191376192, -95.7097320492046 31.4184894556454, -95.710540779863
31.4197101465384, -95.7107926913402 31.4202194168498, -95.7109909831339
31.4207592065456, -95.7112502138053 31.4221191511891, -95.7113725560321
31.4234504555155, -95.711471665893 31.4263095706465, -95.711570872535
31.4272594673819, -95.7116013621441 31.4279899581242, -95.7115404160944
31.4284706358243, -95.7109224224635 31.4305896903368, -95.7107162677428
31.4315395226016, -95.7105864071123 31.4331493316545, -95.7105864187206
31.433570856714, -95.7106782766934 31.434619924544, -95.7107923848685
31.435270307483, -95.7109679494713 31.4358596667457, -95.7116317768028
31.4375991928721, -95.7122499532109 31.4386501553607, -95.7127609080473
31.4400692032379, -95.7128218170991 31.4403190687636, -95.7128600135115
31.4407405792314, -95.7127684428634 31.4418296936476, -95.7127229660248
31.442209238685, -95.7126387665167 31.4425392211824, -95.7125395203276
31.4428291410089, -95.7122419714728 31.4435100703416, -95.7118223680626
31.4442500873222, -95.7111130724044 31.4461402713804, -95.7109527732464
31.4467105704028, -95.7108610131841 31.4472408063793, -95.7107618370334
31.4481792314696, -95.7106171892406 31.4515705338807, -95.7106705596279
31.4516601462563, -95.7107162611066 31.452049254416, -95.7107011128257
31.4528198393171, -95.7107923690273 31.45346070363, -95.711021228754
31.4540805857137, -95.7111891543165 31.4543895865732, -95.7117765840534
31.4552802891593, -95.7123412285198 31.455869662113, -95.7134168745402
31.4568595777455, -95.7137908586291 31.4572505757491, -95.7147292809308
31.458139405464, -95.7159422890851 31.4596691024247, -95.7165222042735
31.4602508541358, -95.7176591171893 31.4610805390006, -95.7180635138907
31.4612903517143, -95.7193299941724 31.4618091819518, -95.7200013747679
31.4619903761729, -95.7207336016217 31.4621505937013, -95.7215879539831
31.4622593061059, -95.7227784861031 31.462249745991, -95.7235335176338
31.4622096857503, -95.7241287680823 31.4621391208292, -95.7253113914012
31.4619503084641, -95.726638671262 31.4616298487275, -95.7275008859419
31.4613895618357, -95.7293929397253 31.461040514449, -95.7310562217765
31.4606399498616, -95.7324065232912 31.4603691102789, -95.7331618355317
31.4601192307793, -95.7340012219068 31.4596290681309, -95.7343900771263
31.4593505883227, -95.7346189405079 31.4592494978012, -95.7358625860585
31.4589901018226, -95.7368927725407 31.4586696820083, -95.7374116574326
31.4585895734915, -95.7377625848561 31.4585704865521, -95.7380525490017
31.4586105202406, -95.7386320190955 31.4587802889887, -95.7391127804714
31.4589996451484, -95.7397078544269 31.4593391511693, -95.7403108307761
31.459770222127, -95.7405089839977 31.4598407614553, -95.7407531015793
31.4598903828611, -95.7413328169334 31.4599399647285, -95.7415769575078
31.4599094351275, -95.7418213707289 31.4598197883264, -95.7419815312691
31.4597091582001, -95.7423478422728 31.4593601417821, -95.7437361156126
31.4582691179805, -95.7442399997413 31.457580580243, -95.7445372198735
31.4573898286385, -95.7448426672776 31.4572391663066, -95.7450028648258
31.4571895474931, -95.7452317676552 31.4572200783266, -95.7458879558078
31.4574794971278, -95.7462693716173 31.4577007306809, -95.7464599718234
31.4579200695093, -95.7464982669204 31.4580593250456, -95.7465820369628
31.4584808248067, -95.7466203516626 31.4592399566384, -95.7465514212789
31.4605293447444, -95.7464065758018 31.4617290342876, -95.7464523470803
31.4633693758602, -95.7464293876768 31.4637603558034, -95.7463530368603
31.4643802794554, -95.7462614157329 31.4648494809864, -95.7460021351716
31.4657096804235, -95.7453231456821 31.4662704466662, -95.7450483638022
31.4664001573311, -95.744743498705 31.4665107651416, -95.7435914551759
31.4667606239882, -95.7429275093915 31.4669895195879, -95.7416916082723
31.4675102454223, -95.7415770654407 31.4675808095345, -95.7413102312319
31.4678096760827, -95.7410585083292 31.4682102411392, -95.7405701843522
31.4693508352611, -95.7403181189544 31.4698295640002, -95.7400892586107
31.4701690558926, -95.7397538505565 31.4708099565439, -95.7393799918933
31.4713592633392, -95.738861028655 31.4719791480339, -95.7386473909367
31.4721603436148, -95.7376938609893 31.4727897635095, -95.7365111016798
31.4733505198853, -95.7348939206857 31.4739703996911, -95.7344208651451
31.4741191703678, -95.7336120402184 31.474279411313, -95.7332382363771
31.4742698831559, -95.7328566405928 31.4742107523257, -95.7325364146969
31.474119202762, -95.7319717614393 31.4738693223073, -95.7314375061626
31.4735698610136, -95.7309036534635 31.4731998287158, -95.7306594688545
31.4730892166348, -95.7299269875701 31.4724292698808, -95.7290117199231
31.4717407211135, -95.7285001780396 31.4712696006771, -95.7279966580744
31.4707107421177, -95.7270277965379 31.4699993299866, -95.72634105319
31.4696598092311, -95.7260132762115 31.4695491983358, -95.7256774615895
31.4695091161243, -95.725349531593 31.4694900621954, -95.72505186749
31.4695301099303, -95.7242735467769 31.4697094125027, -95.7238769319037
31.4698391039513, -95.7226486679594 31.4704093772428, -95.722343474412
31.4705791341424, -95.7220688248867 31.4708194590545, -95.7217406374292
31.4712200195265, -95.7216492515904 31.4713992913936, -95.7216031988989
31.4715805006645, -95.7215423262815 31.4721393575746, -95.7216414975702
31.4731197389256, -95.7219313233214 31.4741592389101, -95.7226182041273
31.4758090843883, -95.7229919034591 31.4770107276786, -95.7231369596063
31.4773998281409, -95.7239303342592 31.4788398720038, -95.7242203318695
31.4792594917904, -95.7244797285862 31.4796009036061, -95.7250291365461
31.4801502295906, -95.7266615368377 31.4819698089131, -95.7269821738448
31.4823703591777, -95.7272185760283 31.4827403918899, -95.7273788139908
31.4830703929093, -95.7276305208264 31.4838104051175, -95.7281111148084
31.4854297605375, -95.7283096697978 31.4864807108967, -95.7285613568822
31.4871597488728, -95.7289580967077 31.487840642885, -95.7296216947496
31.4894504492781, -95.7301407905016 31.4897403577758, -95.7304380833116
31.4897804340852, -95.7308274725741 31.4896697886272, -95.7312086334754
31.4895190942343, -95.73148350222 31.4893894136863, -95.7318422394376
31.4891395448916, -95.732429448198 31.4886398155264, -95.7326277999879
31.4883804176498, -95.733162008457 31.4875698255393, -95.7342225107108
31.4863605359094, -95.7349397443888 31.4856796223993, -95.735618423842
31.4852008909513, -95.7361983884843 31.4848594460461, -95.7363966392311
31.4847698217674, -95.7366792507049 31.4846992555703, -95.7376023946591
31.4845199554717, -95.7380601024607 31.484479903908, -95.7384872965878
31.484500882826, -95.7389220040503 31.484559995963, -95.7392729096447
31.4846496697683, -95.7398835092781 31.4848899669764, -95.74051679221
31.485250464902, -95.7410814092276 31.4857597602309, -95.7415696293307
31.4863491186266, -95.7418520001117 31.4865494032989, -95.7424393496887
31.4871692859259, -95.743042087014 31.4880790806058, -95.7431717374191
31.4883403831614, -95.7433626153191 31.4885902393581, -95.7440186731589
31.4892292072688, -95.7442016380017 31.4894409135905, -95.7443772127095
31.4897003018312, -95.7445296609059 31.48999977172, -95.7448503118969
31.4908008504312, -95.7449799868454 31.4913806905176, -95.7450025789249
31.4916801540266, -95.7449571127797 31.4918403649649, -95.7446670189733
31.4924297438935, -95.7444610973772 31.4927501795403, -95.7442475229248
31.4930000376655, -95.7440414566133 31.4931907611133, -95.7438428914397
31.4933490805227, -95.7425383703015 31.4941692292455, -95.7410963196809
31.4949894024324, -95.7400664759797 31.4957008436082, -95.7399290142892
31.4958591215682, -95.7398986127185 31.4961299713873, -95.7399292524344
31.4963493383618, -95.7402266641044 31.4966793155472, -95.7406310505382
31.4969291665741, -95.7408674456089 31.4970092925649, -95.7411195235734
31.4970893796165, -95.7421035409078 31.4972896380035, -95.7423402372215
31.4975490780356, -95.7424391700496 31.4976902119533, -95.7428512619859
31.4990101015675, -95.7430495509915 31.4994602329912, -95.7431412467307
31.4998493414436, -95.743018933286 31.500789624909, -95.7427826072053
31.5010795750753, -95.7424927058625 31.5013008172022, -95.7417906966204
31.5016098047155, -95.7412184188139 31.5020103560419, -95.7398375938148
31.5033206942719, -95.7394639296839 31.5034294005266, -95.7392805018659
31.5034751988788, -95.7025755466025 31.5125618004557, -95.6466674728187
31.526399617797, -95.6491697737069 31.5416603206286, -95.2735521252333
31.5921192418925))'
, 4267),
32039),
20000));
