[postgis-users] issue with pgsql2shp
strk at refractions.net strk at refractions.net
Mon Jun 5 10:03:13 PDT 2006
On Mon, Jun 05, 2006 at 11:53:17AM -0500, John Cole wrote:
> Strk,
>   Thanks for the reply.  On issue 1) I am using the query and getting the
> error about the geometry types (unless you are talking about using a
> sub-query).
Oh, sorry, I'm reading the error message better now (did you?).
It says that your query returns an EMPTY table.
Try your queries manually before feeding them to pgsql2shp.
>   With SnapToGrid in issue 2) will it eliminate any points that snap to the
> same point?
It should. feel free to file a bug report if it doesn't.
>   On issue 3) the Segmentize returns [multi]polygons according to the
> documentation, will it also work on lines and return those as well?
Did you try ?
--strk;
