[postgis-users] Re: new entry for spatial_ref_sys.sql - Austrian "standard" projection
Michael Haberler
mah at inode.at
Sun Jun 18 02:49:23 PDT 2006
Gabriel Ebner schrieb:
> On Sun, Jun 18, 2006 at 01:38:56AM +0200, Michael Haberler wrote:
>> In Austria most geodata companies, and the land survey use something called
>> the "Bundesmeldenetz" projection which is close to EPSG 31287 but not quite.
> Note that this isn't the Bundesmeldenetz, which is a transverse mercator
> projection with central meridians 28, 31, and 34 degrees east of Ferro in the
> MGI datum.
right.. I noticed after I sent it.. thanks..
> Small guide to Austrian EPSG codes:
> 31284 - BMN M28
> 31285 - BMN M31
> 31286 - BMN M34
> 31287 - Lambert (which is what you're probably looking
>> [...] but not quite.
> Apparently PostGIS does not get datum transformation right for these SRS.
> You'd just have to add
> +towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232
I got this projection example from a local GIS company, and it seems to
work for data from different sources so far
the only difference I can discern from EPSG 31287 is +lat_0=48 instead
of +lat_0=47.5
I'm not a projection expert.. is your parameter set equivalent to this
change in results?
-Michael
> Gabriel.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060618/370dcb4b/attachment.html>
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.9.0/368 - Release Date: 16.06.2006
