[postgis-users] Question about the postgis-1.1.0.spec file
DANTE ALEXANDRA
ALEXANDRA.DANTE at BULL.NET
Mon Mar 27 22:34:34 PST 2006
Hi Markus,
I talk about the spec file obtained from the Linux Source rpm
"postgis-1.1.0-2.src.rpm" available at the address
"http://postgis.refractions.net/rpms/SRPMS/".
Could you explain me what can I do with the sub-packages "utils" and
"jdbc2" ?
When I launch the command : rpm -i postgis-1.1.0-2.src.rpm, I get under
the directory SOURCES, 3 files : postgis-1.1.0.tar.gz,
filter-requires-perl-Pg.sh, postgis-jdbcdedectver.sh.
Could you explain me why are the "filter-requires-perl-Pg.sh" and
"postgis-jdbcdedectver.sh" are include in the source rpm ? for what are
they used ?
Thank you for your help.
Regards,
Alexandra
Markus Schaber a écrit :
>Hi, Dante,
>DANTE ALEXANDRA wrote:
>>I am a PostGIS newbie and I've got a question about the
>>"postgis-1.1.0.spec" file.
>I guess you talk about a RPM/DEB spec file?
>>In this spec file, the package "utils" and "jdbc2" are defined as
>>sub-package of PostGIS.
>>Could you explain me why please ?
>PostGIS currently can be seen as four parts:
>- The PostGIS server extension, to be installed on the server
>- The loader / dumper and other utilities, to be installed on clients
>- The jdbc driver extension, to be installed on java clients
>- The documentation, to be read by humans
>>If I compile PostGIS from the source code, from the
>>"postgis-1.1.1.tar.gz <postgis-1.1.1.tar.gz>" file, do I need to add
>>these sub-package ?
>That depends on what you need to do.
>HTH,
>Markus
