[postgis-users] PostGIS configuration on WinXP issue using psqlterminal
Obe, Regina
robe.dnd at cityofboston.gov
Thu Oct 12 23:32:18 PDT 2006
Have you tried using the PgAdmin tool that comes prepackaged with the PostGreSQL installation. I find it in general a bit easier to use than psql and limit my psql use for automated jobs, loading of sql batch files and things of that sort.
At the very list if you run into similar problems using the PgAdmin query tool part, it may give you more clues as to what is wrong with your install.
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Tahir Tamba
Sent: Thu 10/12/2006 5:40 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostGIS configuration on WinXP issue using psqlterminal
Dear all,
I'm a newby to PostGis and I'm getting some difficulties to setting up PostGis using the psql terminal. I installed Windows 8.1.4 compiled version from Postgres and Windows 1.1.3 compiled version from PostGIS.
Using the example presented by Refractions on the document titled "Introduction to PostGIS" refering on how to create a table using psl terminal I get the following error:
Welcome to psql 8.1.4, the PostgreSQL interactive terminal.
Type: \copyright for distribution terms
\h for help with SQL commands
\? for help with psql commands
\g or terminate with semicolon to execute query
\q to quit
Warning: Console code page (850) differs from Windows code page (1252)
8-bit characters may not work correctly. See psql reference
page "Notes for Windows users" for details.
postgres=# \c postgis
You are now connected to database "postgis".
postgis=# create table points ( pt geometry, name varchar );
CREATE TABLE
postgis=# insert into points values ( 'POINT(0 0)', 'Origin' );
INSERT 0 1
postgis=# insert into points values ( 'POINT(5 0)', 'X Axis' );
INSERT 0 1
postgis=# insert into points values ( 'POINT(0 5)', 'Y Axis' );
INSERT 0 1
postgis=# select name, AsText (pt), Distance (pt, 'POINT(5 5) ')
from points;
'more' n'est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
postgis=#
I have been told that the psql terminal is configured to use the pager, 'more', so I should turn it off. Running the the following command on psql : \pset pager the terminal noticed that pager is setted to Off.
Any help about this issue would be appreciated.
Regards
Tahir Tamba
MSc. Géographie
Aménagement du territoire et SIG/ Gestion et conservation des ressources naturelles
Télédétection-cartographie écologique, caractérisation des milieux humides
Tel: (514) 526-7543
Courriel: tamba.tahir at courrier.uqam.ca
Tahir Tamba
MSc. Geography
Urban planning and GIS specialist/Natural resources management and conservation
Remote-sensing-ecological mapping and wetland monitoring and Characterization
Tel: (514) 526-7543
E-mail: tamba.tahir at courrier.uqam.ca
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061013/7773fd46/attachment.bin>
