[postgis-users] [jdbc][datasource] use postgis through JDBCinSpring
Norman Barker nbarker at ittvis.com
Wed Oct 18 07:30:20 PDT 2006
Nicolas,
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Nicolas Delsaux
Sent: 18 October 2006 15:24
To: PostGIS Users Discussion
Subject: Re: [postgis-users] [jdbc][datasource] use postgis through JDBCinSpring
On 10/18/06, Norman Barker <nbarker at ittvis.com> wrote:
> Hi Nicolas,
> I wrote a tutorial on doing this with PostGIS and EJB3 annotations (within JBoss) here - http://postgis.refractions.net/support/wiki/index.php?SpatialEJB3
I've already looked at this document, and I'll go deeper in.
<ncb>thanks, feed back your comments - I would appreciate it. </ncb>
> I know it sounds as if I am reinventing GeoTools / GeoNetwork, I am not really I just need clustering, and annotations make life very easy (if a little harder to debug / follow!) and also the catalog needs to be LGPL if I am to use it.
So, do you say that geotools, although not fully complying your needs,
provides such a datasource for postgis ?
<ncb>
I am not a geotools developer (though I have used it, and GeoServer), but by your question I thought you were referring to a J2EE datasource which to me is different from 'just' a JDBC data source. Since with a J2EE data source such as postgis-ds.xml everything is configurable, and we are talking CMP persistence etc.
As I remember GeoServer (and so I guess Geotools) has connections for spatial databases (Derby, PostGis, MySQL) - I used the MySQL connector for a servlet app and it was great.
I am not knocking any other projects, I am just looking specifically at a J2EE (so the full stack), and not just the web tier, deployment.
Also annotations are more closely aligned to your question about containers / spring.
</ncb>
> Let me know if you need any help.
<ncb>again, happy to help if you let me know what you plan</ncb>
> Norman
> Sent: 18 October 2006 14:54
> Subject: [postgis-users] [jdbc][datasource] use postgis through JDBC inSpring
> Hi, is there anywhere a tutorial on PostGIS integration in JEE
> environments using containers like Spring or, even simpler,
> datasources instead of connections ?
> I suspect geotools provides a layer for connection, but will it remove
> the need for me to addDataTypes manually ?
> Nicolas Delsaux
> N'imprimez ce mail que si vous ne savez pas le lire sur l'écran : les
> électrons se recyclent bien, le papier, beaucoup moins bien.
> postgis-users mailing list
Nicolas Delsaux
