[postgis-users] PostGIS 1.1.5 Win32 Binaries for PostgreSQL 8.2 beta 1 available
Mike Leahy mgleahy at alumni.uwaterloo.ca
Sun Oct 22 12:12:35 PDT 2006
Hey Mark,
Thanks - these binaries work great.
There is one issue I found with the installer.  If I choose not to use
the option to create the postgis database automatically, it still tries
to make the template_postgis database.  If there is no PostgreSQL
service initialized and running yet, the installer fails here (but is
still essentially installed from what I can tell).
At any rate, thanks again for the making these.
Mike
Mark Cave-Ayland wrote:
> On Sat, 2006-10-21 at 17:55 -0400, Mike Leahy wrote:
>> Thanks for the help David,
>> Unfortunately, the same problem exists for me with the full binaries you
>> just posted (that the liblwgeom.dll won't load) - plus I had to move
>> libpq.dll from /lib folder to /bin.  Also, I'm pretty sure my earlier
>> conclusions drawn from using the Dependency Walker were wrong, as it
>> revealed similar dependency errors for a working installation that I
>> have, so the problem must lie in my own configuration somehow.  Perhaps
>> I'll give it another shot later, unless anyone has further suggestions...
>> Thanks again,
>> Mike
> Hi Mike/David,
> I've uploaded a test version of the Win32 installer from my PostgreSQL
> 8.2 beta 1 source tree to
> http://postgis.refractions.net/download/windows/beta/postgis-pg82beta1-setup-1.1.5-1.exe.
> Disclaimer:
> PostgreSQL 8.2 should come with PostGIS 1.1.5 as standard, so consider
> this an unsupported release which is for testing only and not production
> use.
> Please let us know if you experience any problems.
> Kind regards,
> Mark.
> postgis-users mailing list
