[UNCLASSIFIED]RE: [postgis-users] satellite data (MODIS) into Pos tgreSQL - PostGISdatabase as points or grids?
Antti.Roppola at brs.gov.au Antti.Roppola at brs.gov.au
Tue Feb 20 19:19:37 PST 2007
Interestingly, most vendors have quietly introduced separate products for
serving up imagery from outside of an RDBMS. This is after a lot of talk
about putting everything into an RDBMS, so I have been wondering if that
is an indication of some low level issue about putting raster into the database.
I recall there was some preliminary discussion about how to best incorporate
imagery and other raster data into PostGIS. This was captured on the Wiki:
http://postgis.refractions.net/support/wiki/index.php?PgRasterDesign
I haven't been keeping up with raster, so I'd be interested to see what sorts
of information you get in repsonse. :)
Cheers,
Antti
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Jan.Verbesselt at csiro.au
Sent: Wednesday, 21 February 2007 11:32 AM
To: postgis-users at postgis.refractions.net
Cc: Kimberley.Opie at ensisjv.com; Glenn.Newnham at ensisjv.com
Subject: [postgis-users] satellite data (MODIS) into PostgreSQL - PostGISdatabase as points or grids?
Hi all,
After searching the mail archives and postGIS website I didn't find the right answer to my questions.
1/Does anyone have experience on how I could import HDFEOS (MODIS) satellite data in a database system efficiently? Currently, I would transform the hdf files to ascii files via IDL an import these into the database.
2/Should the data be stored as points (X,Y,value) or can they be imported as a raster in the database such that spatial and temporal analysis is still possible (visualisation via R, openGIS progs etc.).
Or as I found in the mail archives; Should we online create a path (link to the data) to the hdf files and store this in the database?
All related info, examples, advice is mostly welcome,
Kind regards,
Jan
______________________________________________
Jan Verbesselt
Post-Doctoral Research Fellow
Ensis - the joint forces of CSIRO and Scion Private Bag 10 Clayton South VIC 3169 - Australia
Tel: ++ 61 3 9545 2265
Fax: ++ 61 3 9545 2448
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF).  The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material.  It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited.  The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited.  If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments.  If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly.  Only e-mail correspondence which includes this footer, has been authorised by DAFF
