[postgis-users] Postgis upgrade
Barend K=?ISO-8859-1?B?9g==?=bben
kobben at itc.nl
Mon Jan 29 06:09:50 PST 2007
Hi, Mark just told me a few mails ago how to do that from 8.1 to 8.2, and I
put that in a readme file for my studnets, so I guess that could help you
too. See below...
__
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
Assuming that you have installed PostGIS on a new host <host_of_new_install>
and the old PostGIS on <host_of_old_install>, then:
1.
a) Create a new PostGIS-enabled database of the same name under
PostgreSQL 8.2.
b) Delete/drop the 'geometry_columns' table
c) Keep the new PostGIS installed table spatial_ref_sys (it might have
updates coming from a PROJ4 update); Only if you customized your
spatial_ref_sys table in your old DB, delete the one in this new DB.
2.
a) Use pg_dump with the -Fc argument to create a custom format dump of your
entire old database:
pg_dump -h <host_of_old_install> -U <username> -Fc -f myDB.backup -i -C
<myDB>
b) Use pg_restore with the -l option to create a text file containing a
list of the contents of your dump file:
pg_restore -h <host_of_new_install> -U <username> -f toc.list -l myDB.backup
c) From this text file, remove everything that isn't a reference to any
of your tables, indices or the geometry_columns table.
If you did NOT have a customized spatial_ref_sys table (and therefore
deleted it in 1c), make sure to also delete all references to that.
d) Restore your dump file into the new PostgreSQL 8.2 database using
the -L option to specify a list of items to restore:
pg_restore -h <host_of_new_install> -U <username> -L toc.list -e -C -Fc -d
<myDB> myDB.backup
