[postgis-users] Re:PostGIS (& Apache/PHP) on a Windows USB stick
joanne cook
j.cook at oxfordarch.co.uk
Tue Jan 30 00:38:00 PST 2007
Hi All,
I'm very interested in the idea of postgis/postgresql on a usb stick, or at the least a standalone installation. I have done a fair bit of digging around too, and it seems as if no one can see the point in this, or that they think it's a lazy thing to ask for! What I am trying to do is provide a preconfigured version of xampp that contains a suite of gis tools, and postgresql/postgis is pretty much the last on the list to be included. You would need it to be run from a batch file or something, rather than as a service. The obvious problems are finding out the unprivileged user that it should run as, and setting the paths, since the drive letter might change. Things like python will run from a usb stick if you install them onto a hard drive then copy the directory over, and set a few enivironmental variables, so I am hoping that it will be possible to do the same with postgresql. I don't really have very much more to contribute though, but it would be nice to keep this debate running!
Cheers
Jo
Joanne Cook BSc MLitt AIFA MBCS
Information Systems Coordinator
Oxford Archaeology North
Message: 1
Date: Sun, 28 Jan 2007 13:59:09 -0700
Subject: [postgis-users] Re:PostGIS (& Apache/PHP) on a Windows USB
stick
To: postgis-users at postgis.refractions.net
Message-ID: <45BD0E9D.5030001 at thetimoneygroup.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
David:
Thanks for looking into it. I did a little more research and it seems
that there isn't a plug-and-play Postgres variation (on Windows at
least) of the XAMMP project (http://www.apachefriends.org/en/xampp.html).
That said, I think it may have a small, useful role in the constellation
of options of how to get folks to test-drive different software
combinations.
Thanks again,
Brian
This message has been scanned for viruses by BlackSpider MailControl - www.blackspider.com
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070130/8936f1fc/attachment.bin>
