[postgis-users] Distance between two points !
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jul 6 04:45:05 PDT 2007
Try distance_sphere()
Fabio Rillo wrote:
> Hi
> I’m a newbie to PostGIS and I have same problem with function
> distance(geometry, geometry). I need to know the distance between two
> points IN METERS but distance return a number that represent the
> distance into carthesian system but I don’t know how convert this number
> in meters… Or there is another war to do this!?!
> PS.
> I use geoserver to show maps and works very well…
> This is a my example query:
> select
> distance(
>           geomfromtext('POINT(14.7926950454712 41.1229515075684)', 4236),
>           geomfromtext('POINT(14.7931413650513 41.1228904724121)', 4236)
> Return 0,000450473592882729 !?!!?
> Since SRID 4236 has UNIT["degree",…] I tried to use the “transform”
> function in this way:
> select  distance(
>           transform(PointFromText('POINT(14.7926950454712
> 41.1229515075684)', 4236), 26986),
>           transform(PointFromText('POINT(14.7931413650513
> 41.1228904724121)', 4236), 26986)
> Because SRID 26986 has UNIT["metre"…]
> But I didn’t solve the problem.
> Thanks Fabio
> postgis-users mailing list
