[postgis-users] problem with subselect in hql
Mikkel Troest
mikkle at mikkle.dk
Wed May 2 14:04:47 PDT 2007
Right, I figured it out. Can't do subselcts in from claus with hql anyway.
Bruce Rindahl's answer to Flavio Perri (subject: Degrees of a linestring
segment) pointed me in the right direction:
my working result, based on that, is:
select spatial.Length2d_spheroid( spatial.Makeline( pstart.geometry,
pend.geometry ) , 'SPHEROID[\"WGS_1984\", 6378137, 298.257223563]' )
from RPosition pstart, RPosition as pend where pstart = :pstart and pend
= :pend
in other words:
select functionA(functionB(alias1, alias2), additionalArguments) from
myTable alias1, myTable as alias2 where alias1 = ? AND alias2 = ?
Sorry for the inconveinience!
:O) Mikkle
Mikkel Troest wrote:
> Hi,
> I have a newbie question, which I hope someone out there can help me
> with:
> I have a spatial table, positions:
> _____________________________________________________
> | position_id (bigint) | position_lonlat (geometry) |- remaining
> columns omitted...
> I can run the following sql query directly on the PostGreSQL DB:
> select length2d_spheroid(theline, 'SPHEROID[\"WGS_1984\", 6378137,
> 298.257223563]') from ( select makeline(p1.position_lonlat,
> p2.position_lonlat) as theline from positions p1, positions as p2
> where p1.position_id = 18 and p2.position_id = 19 ) theresult;
> - It may seem mad, but my application needs to be able to get a
> linestring between two arbitrary points.
> -- The query does this and returns the length according to wgs84.
> Right.
> I've added the following to Norman Barker's PostGISDialect.java:
> registerFunction( PostGISDialect.NAMESPACE + "length2d_spheroid", new
> StandardSQLFunction("length2d_spheroid", Hibernate.DOUBLE) );
> registerFunction( PostGISDialect.NAMESPACE + "makeline", new
> StandardSQLFunction("makeline", Hibernate.custom(GeometryType.class) ) );
> to be able to support the makeline and length2d_spheroid functions.
> I try to translate this sql into hql:
> Query lslen2dsph = session.createQuery("select
> spatial.Length2d_spheroid(theline, 'SPHEROID[\"WGS_1984\", 6378137,
> 298.257223563]') from (select spatial.Makeline(pstart.geometry,
> pend.geometry) as theline from RPosition pstart, RPosition as pend
> where pstart = :pstart and pend = :pend) theresult");
> lslen2dsph.setParameter("pstart", pstart);
> lslen2dsph.setParameter("pend", pend);
> //Note that pstart and pend are Geometries retrieved elsewhere...
> //also note that RPosition is my annotated class - giving the same
> table as "positions" in the sql above.
> //another note: pstart.geometry is the same as p1.position_lonlat above.
> When I run the query, I get:
> 2007-05-01 14:07:06 org.hibernate.hql.ast.ErrorCounter reportError
> SEVERE: line 1:96: unexpected token: (
> Exception in thread "main" org.hibernate.hql.ast.QuerySyntaxException:
> unexpected token: ( near line 1, column 96 [select
> spatial.Length2d_spheroid(theline, 'SPHEROID["WGS_1984", 6378137,
> dk.bestikket.gps.server.persistence.RPosition pstart,
> dk.bestikket.gps.server.persistence.RPosition as pend where pstart =
> :pstart and pend = :pend) theresult]
> Can anyone tell me what's wrong with my hql query (lslen2dsph)?
> If I do a session.createSQLQuery() I have no problems getting thing
> run. I would very much like, though, to
> keep it in hql for consistency's sake, and to avoid confusion of
> table/column names, etc.
> Admittedly, both HQL and postgis are very new stuff to me, so I may
> easily be missing some obvoius points.
> Please bear with me if that is the case!
> Thanks!
> :O) Mikkel Troest
> This mail was scanned for viruses at mail.mikkle.dk by ClamAV (tm) and
> found to be virus free.
> postgis-users mailing list
This mail was scanned for viruses at mail.mikkle.dk by ClamAV (tm) and found to be virus free.
