[postgis-users] GeomUnion problem
Brent Wood
pcreso at pcreso.com
Thu May 3 18:36:59 PDT 2007
--- Martin Davis <mbdavis at refractions.net> wrote:
> Another idea - are you using the latest version of PostGIS/GEOS? The
> recent release added some GEOS enhancements which were designed to
> address this issue.
Thanks Martin,
The version I'm running is:
ben200601=# select postgis_geos_version();
2.2.3-CAPI-1.1.1
I believe this is pretty much the current release, apart from the RC's of V3.
Sigh, I need this to work within a week or so somehow, I was hoping to use this
project as a showcase of FOSS GIS, but murphy strikes :-)
Is GEOS v3RC going to be reliable enough for a mission critical production job
with several million polygons to be manipulated?
What is entailed in upgrading GEOS?
Do I need to rebuild & reinstall PostGIS?
Will the current DB/data still be accessible?
Or is there some way of tweaking the underlying polygons to be combined to
address the problem?
Appreciated,
Brent
> Brent Wood wrote:
> > Hi,
> > I'm not sure what the problem is here, hopefully someone can help.
> > I have some polygons cropped to cell boundaries. (select intersection...)
> > I want to generate the geomunion of these for each cell, which seems
> > straightforward, but GEOS is throwing an error...
> > select astext(geomunion(track_cell_geom)) from effort_cells3 where
> cell_id =
> > 73721;
> > NOTICE: TopologyException: no outgoing dirEdge found
> > (168.077,-40.1961,-40.1961)
> > ERROR: GEOS union() threw an error!
> > Can anyone say what this means & what I need to do to work around it?
> > Thanks,
> > Brent Wood
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
