[postgis-users] GeomUnion problem
Paul Ramsey
pramsey at refractions.net
Thu May 3 21:51:37 PDT 2007
On 3-May-07, at 6:36 PM, Brent Wood wrote:
> Is GEOS v3RC going to be reliable enough for a mission critical
> production job
> with several million polygons to be manipulated?
Probably.
> What is entailed in upgrading GEOS?
./configure ; make ; make install
> Do I need to rebuild & reinstall PostGIS?
No, you can drop the new GEOS in behind. Re-connect to the database
and the new library will be loaded.
> Will the current DB/data still be accessible?
Yes.
> Or is there some way of tweaking the underlying polygons to be
> combined to
> address the problem?
Martin gave that recipe: buffer(geomunion(buffer(a,0.1),buffer(b,
0.1)),-0.1)
P
> Appreciated,
> Brent
>> Brent Wood wrote:
>>> Hi,
>>> I'm not sure what the problem is here, hopefully someone can help.
>>> I have some polygons cropped to cell boundaries. (select
>>> intersection...)
>>> I want to generate the geomunion of these for each cell, which seems
>>> straightforward, but GEOS is throwing an error...
>>> select astext(geomunion(track_cell_geom)) from effort_cells3
>>> where
>> cell_id =
>>> 73721;
>>> NOTICE: TopologyException: no outgoing dirEdge found
>>> (168.077,-40.1961,-40.1961)
>>> ERROR: GEOS union() threw an error!
>>> Can anyone say what this means & what I need to do to work around
>>> it?
>>> Thanks,
>>> Brent Wood
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
