[postgis-users] PostGIS 2.0 Wishlist
Brent Wood
pcreso at pcreso.com
Wed May 9 09:43:10 PDT 2007
--- John Zastrow <jcz at northredoubt.com> wrote:
> My wish is for better support for RPM/deb installation. Particularly on
> the "commercial-grade" OS's (e.g., RHEL/CentOS, Suse).
> I know maintaining packages is time consuming, but this whole process is
> painful.
> http://postgis.refractions.net/support/wiki/index.php?PostgisRpmInstallation
> Short of that, how about a guided install script that (1) checks for
> Postgres sources on localhost, (2) fetches the latest postgis sources
> (2b) including latest stable dependencies (e.g., Proj4 and GEOS), (3)
> walks the user through the make process, (4) sets up Postgis users in
> Postgres then (5) guides the user through setting up their first Postgis
> database.
Perhaps this could be an OSGEO initiative? So RR aren't faced with maintaining
PostGIS dependency packages, or other packages (UMN Mapserver, GRASS & QGIS
spring to mind).
As an umbrella organisation for a FOSS GIS suite of interoperable applications,
it may be a more appropriate place to address this?
I'll volunteer to help with OpenSuse 64 & 32 bit RPM's (if someone can help get
me going- never having built any RPM's before), or at least provide a box with
OpenSuse running which someone can ssh to when they need one to build the
packages.
I thought the DebianGIS guys had got Debian reasonably well sorted in this
arena?
Brent Wood
