[postgis-users] Well done with GEOS & QGIS!!!
Martin Davis mbdavis at refractions.net
Thu May 10 08:45:28 PDT 2007
Thanks, Brent (for pieces which apply to me....  8^)
And if you use JUMP you can use it to perform the isValid test as well
(it's built on essentially the same codebase as GEOS)  8^)
Martin
Brent Wood wrote:
> Instead of asking for help or features, just for a change I figured I'd pass on
> some thanks for something working perfectly (touch wood, fingers crossed....
> I just ran difference() & got a GEOS error:
> NOTICE:  TopologyException: found non-noded intersection between 173.56
> -35.3436, 173.558 -35.3364 and 173.56 -35.3412, 173.557 -35.3388 173.559
> -35.3407
> ERROR:  GEOS difference() threw an error!
> It sort of made sense, & suggested there was a topology error in my polygon.
> I ran isvalid() & got a false on the very polygon I was using in difference,
> along with the message:
> NOTICE:  Self-intersection at or near point 173.559 -35.3407
> Wow!!! All I needed to know!
> Opened it up in QGIS, zoomed in & there it was, make it editable, drag some
> vertices around to fix the error, save it, re-run the SQL & it worked
> perfectly.
> Fantastic to see this level of useability, interoperability  & topology support
> coming out of these tools.
> Kudos to all you developers out there!!!
> Cheers,
>   Brent Wood
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
