[postgis-devel] Re: [postgis-users] installation problem
vamsee movva vamseejump at gmail.com
Thu May 10 12:33:02 PDT 2007
Hi mark
Finally i succeeded in installing Postgis .
The problem is with the Postgresql version. I Used 8.2.1 for this
installation.
Thanks again for your time.
On 5/10/07, Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk> wrote:
> On Thu, 2007-05-10 at 12:33 -0400, vamsee movva wrote:
> > Here is the error
> > BEGIN
> > psql:lwpostgis.sql:54: NOTICE:  type "histogram2d" is not yet defined
> > DETAIL:  Creating a shell type definition.
> > psql:lwpostgis.sql:54: ERROR:  could not load library
> > "/home/user/lib/liblwgeom.so.1.2": libgeos_c.so.1: cannot open shared
> > object file: No such file or directory
> [Note: please reply to the list, not to me directly]
> Okay - this means that PostgreSQL can't find libgeos_c.so - chances are
> since you are not root, you need to set LD_LIBRARY_PATH to point to your
> GEOS libdir before launching PostgreSQL. If you search the archives, you
> should find more info on this.
> Kind regards,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070510/f05589e6/attachment.html>
