[postgis-users] distance between two POINTM
Michael Fuhr
mike at fuhr.org
Tue May 15 03:01:40 PDT 2007
On Sun, May 13, 2007 at 11:53:20PM -0600, Michael Welter wrote:
> You're doing some great research, Michael. How did you get the CDOT data?
http://www.dot.state.co.us/app_DTD_DataAccess/GeoData/index.cfm?fuseaction=GeoDataMain&MenuType=GeoData
I used "Highways" under "Statewide Data Set." The SRID is 26913
(NAD83 / UTM zone 13N).
> But here's my original question: What is the proper method to calculate
> distance on the earth's surface?
> The distance returned from problem #1 (~2500m elevation) should be
> greater that from problem #2 (sea level). However, it appears that the
> Z value is ignored altogether.
Matthew and Paul have followed up to this; I don't know enough to
add much else.
The second of the following examples uses a spheroid with a semi-major
axis 2500m greater than the first. I don't know if this is a proper
test but it shows a difference of less than 2m.
select distance_spheroid(GeomFromEWKT('SRID=4269;POINT(-105.32395 39.50163)'),
GeomFromEWKT('SRID=4269;POINT(-105.30166 39.53806)'),
'SPHEROID["GRS 1980",6378137,298.257222101]');
distance_spheroid
4475.81916645913
(1 row)
'SPHEROID["GRS 1980",6380637,298.257222101]');
distance_spheroid
4477.57352637899
(1 row)
Michael Fuhr
