[postgis-users] Postgis 2.0 wishlist
Willy-Bas Loos
willybas at gmail.com
Tue May 15 15:57:13 PDT 2007
fair enough, sounds like that should be no problem. I should also look up
how to make a system schema in postgresql so that postgis system objects do
not end up in my backups (or if this only a feature of pg_dump?), then how
to make the new postgis schema a default search path in postgresql (so that
i can still omit the schema name or search_path when calling the function).
Still it seems to me that some of the people that make add-ons should talk
to postgresql people to integrate their functions and other objects in a
more comfortable manner.
Then again, maybe it´s just the way it is.
WBL
On 5/15/07, David William Bitner <david.bitner at gmail.com> wrote:
> Install postgis into whatever schema you want and set the default search
> path in your postgresql configuration to use your postgis schema in the
> default search path. PostGIS is an add-on to PostgreSQL, as such there is
> no out-of-the-box schema other than public for it to use.
> On 5/15/07, Willy-Bas Loos <willybas at gmail.com> wrote:
> > >This is doable now, the main problem for newbies seems to be setting
> > >the search_path every single time so they have access to them.
> > That doesn´t seem logical to me: it´s also a problem for the same
> > newbies to restore their PostGIS databases.
> > It should be a default search_path, just like pg_catalog and public.
> > I dont need to set the search_path to use "select int2('25'::text)"
> > either.
> > Or would that conflict with PostgreSQL policies?
> > WBL
> > On 5/15/07, Paul Ramsey < pramsey at refractions.net> wrote:
> > > On 15-May-07, at 4:33 AM, Willy-Bas Loos wrote:
> > > > If you're changing alle the function names, maybe it's time to make
> > > > system objects of them, stored in a seperate system schema (along
> > > > with the types, operators, etc)?
> > > > Other than that it would be nice to add descriptions to the
> > > > functions and operators in SQL, e.g. to indicate what the input for
> > > > each function should be when the number of arguments varies for
> > > > functions with equal names.
> > > How does one recover those descriptions at the commandline? Does \d
> > > functionname work?
> > > P
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070516/c3143888/attachment.html>
