[postgis-users] Postgis 2.0 wishlist
Dave Potts dave.potts at pinan.co.uk
Wed May 16 00:54:30 PDT 2007
Willy-Bas Loos wrote:
> My wish for Postgis 2.0:
> If you're changing alle the function names, maybe it's time to make
> system objects of them, stored in a seperate system schema (along with
> the types, operators, etc)?
> Backing up /Restoring data is a pain when these (possibly outdated)
> objects (with hardcodes library paths) are included.
A nice idea, I agree that having to change the system paths is a pain,
but if making all these function system object is to hard, perhaps you
change the value of expression
CREATE FUNCTION area(geometry) RETURNS double precision
    AS '$libdir/liblwgeom.1.1.so', 'LWGEOM_area_polygon'
    LANGUAGE c IMMUTABLE STRICT;
to something like
    AS '$syslib, 'LWGEOM_area_polygon'
Then  only one value would have to be changed, instead of every expression.
Dave.
> Other than that it would be nice to add descriptions to the functions
> and operators in SQL, e.g. to indicate what the input for each
> function should be when the number of arguments varies for functions
> with equal names.
> Willy-Bas Loos
> postgis-users mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070516/fef8d10c/attachment.vcf>
