[postgis-users] count points of a geometry
Nicolas Ribot
nicky666 at gmail.com
Wed May 16 09:12:23 PDT 2007
> i am looking for good way to count all points as a sum of all the points which are in all rows of a "the_geom"-column. geometrytype can be of the type polygon, polyline, multipolygon or multiline.
> i am thinking of something like
> select sum (NumPoints("the_geom")) FROM table WHERE true;
> The Documentation of PostGIS says that NumPoints(geometry) only retrieves the number of points of the first linestring within a geometry, so that would not be sufficient for my case.
> ["NumPoints(geometry) ... Find and return the number of points in the first linestring in the geometry. Return NULL if there is no linestring in the geometry."]
> Has anybody an idea how i can get the result?
npoints for any geometry:
select sum(npoints(the_geom)) from table where ...;
Nicolas
