[postgis-users] count points of a geometry
Stefan Zweig
stefanzweig1881 at web.de
Wed May 16 08:45:28 PDT 2007
hi list,
i am looking for good way to count all points as a sum of all the points which are in all rows of a "the_geom"-column. geometrytype can be of the type polygon, polyline, multipolygon or multiline.
i am thinking of something like
select sum (NumPoints("the_geom")) FROM table WHERE true;
The Documentation of PostGIS says that NumPoints(geometry) only retrieves the number of points of the first linestring within a geometry, so that would not be sufficient for my case.
["NumPoints(geometry) ... Find and return the number of points in the first linestring in the geometry. Return NULL if there is no linestring in the geometry."]
Has anybody an idea how i can get the result?
Thanks in advance,
stefan
_______________________________________________________________
SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
