[postgis-users] Scale without translate?
Mark Leslie mark at refractions.net
Thu May 17 15:09:34 PDT 2007
The precise answer is "probably".  The Centroid is defined as immutable,
so postgresql knows that the same answer will be obtained for the same
arguments and knows that it can cache the results.  When/how/if it
chooses to caches I couldn't say.
Mark
Rob Agar wrote:
> Bruce Rindahl wrote:
>> SELECT translate(
>> scale(
>> translate(the_geom,-x(centroid(the_geom)),-y(centroid(the_geom)))
>> ,myScale)
>> ,x(centroid(the_geom)),y(centroid(the_geom)))
> on a side point, is the postgresql optimizer smart enough not to call
> centroid() four times in this case?
> Rob
> postgis-users mailing list
