[postgis-users] How to Repair Invalid Geometries???
Orlando Giovanny Solarte Delgado
orsolarte at gmail.com
Thu May 17 17:22:43 PDT 2007
Hi list.
I am developing geodatabase with PostGIS 1.2. I am tryin load shapefile
using shp2psql method from postgis. However, when I load shapefile
using sql. It say: "NOTICE: Ring Self-intersection", "violates check
constraint "geometry_valid_check".
Before to load shapefile, I test using chek_geomatry tool from ArcTools from
ArcGIS 9.2, it say: "Valid geometries", but postgis say "violates check
So. How I can repair may shapefile before load postgis??. There is some tool
different Check and repair Geometrias from ArcGIS?
Thanks.
Atentamente,
Ingeniero en Electrónica y Telecomunicaciones. Universidad del Cauca.
Especialista en SIG.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070517/f14f5979/attachment.html>
