[postgis-users] Instalation problem on Ubuntu Dapper
TECHER David
davidtecher at yahoo.fr
Fri May 18 09:17:13 PDT 2007
Hi Tyler
AFAIC I've got the idea that you've got installed geos using something
like "apt-get "
or "synaptic"..So the geos version should be something like <= 2.1.X. If
it is the case, so remove it!
As Marc told you in
http://postgis.refractions.net/pipermail/postgis-users/2007-May/015538.html
install geos for geos >= 2.2.X
I've got a Ubuntu Dapper at home and got no problem :)
You can use my doc "building instructions for Dapper or Edgy" available at
http://www.davidgis.fr/documentation/win32/html/ch03.html (french)
Even if this link above is written in French, you can use a tool like
google to translate it ;)
Hope this help.
--david;
Tyler Durden a écrit :
> Hi,
> Any evolutions in this problem:
> With me:
> $ psql -d testgis -f lwpostgis.sql
> BEGIN
> psql:lwpostgis.sql:43: NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> psql:lwpostgis.sql:43: ERROR: could not load library
> "/usr/lib/liblwgeom.so.1.2": /usr/lib/liblwgeom.so.1.2: undefined
> symbol: has_arc
> psql:lwpostgis.sql:48: ERROR: current transaction is aborted,
> commands ignored until end of transaction block
> postgis-users mailing list
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
