[postgis-users] Instalation problem on Ubuntu Dapper
Tyler Durden tylersticky at gmail.com
Fri May 18 09:28:11 PDT 2007
Yes,
dpkg -l|grep geos
ii  libgeos-dev                            2.1.4-2
 Geometry engine for GIS - Development files
ii  libgeos-doc                            2.1.4-2
 Documentation for the GEOS GIS geometry engi
ii  libgeos2c2a                            2.1.4-2
 Geometry engine for Geographic Information S
There is a patch in the SVN version for this problem?
On 5/18/07, TECHER David <davidtecher at yahoo.fr> wrote:
> Hi Tyler
> AFAIC I've got the idea that you've got installed geos using something
> like "apt-get "
> or "synaptic"..So the geos version should be something like <= 2.1.X. If
> it is the case, so remove it!
> As Marc told you in
> http://postgis.refractions.net/pipermail/postgis-users/2007-May/015538.html
> install geos for geos >= 2.2.X
> I've got a Ubuntu Dapper at home and got no problem :)
> You can use my doc  "building instructions for Dapper or Edgy" available at
> http://www.davidgis.fr/documentation/win32/html/ch03.html (french)
> Even if this link above is written in French, you can use a tool like
> google to translate it ;)
> Hope this help.
> --david;
> Tyler Durden a écrit :
> > Hi,
> > Any evolutions in this problem:
> > With me:
> > $ psql -d testgis -f lwpostgis.sql
> > BEGIN
> > psql:lwpostgis.sql:43: NOTICE:  type "histogram2d" is not yet defined
> > DETAIL:  Creating a shell type definition.
> > psql:lwpostgis.sql:43: ERROR:  could not load library
> > "/usr/lib/liblwgeom.so.1.2": /usr/lib/liblwgeom.so.1.2: undefined
> > symbol: has_arc
> > psql:lwpostgis.sql:48: ERROR:  current transaction is aborted,
> > commands ignored until end of transaction block
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> ___________________________________________________________________________
> Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
> http://fr.mail.yahoo.com
