[postgis-users] no entry in column the_geom geometry
Barend K=?ISO-8859-1?B?9g==?=bben kobben at itc.nl
Thu Nov 1 08:29:16 PDT 2007
Do you mean the row looks empty in Pgadmin viewer...? I noticed that too,
that sometimes its doesn't show the Hex numbers, even if content is there. I
thinks it's just a PGAdmin bug, if you do a select AsText(the_geom) all rows
will have an entry...
On 01-11-2007 15:00, "Andreas Laggner" <andreas.laggner at fal.de> wrote:
> Hi,
> what does it mean if a row has no entry in the_geom? Is there no
> geometry at all? None of rows are invalid or empty, all of them are
> closed and simple. But how is this possible without points in the column
> geometry??
> cheers      Andreas
