[postgis-users] no entry in column the_geom geometry
Andreas Laggner
andreas.laggner at fal.de
Fri Nov 2 06:23:38 PDT 2007
Hi Barend,
yes, that´s it. Thank you Barend.
Barend Köbben schrieb:
> Do you mean the row looks empty in Pgadmin viewer...? I noticed that too,
> that sometimes its doesn't show the Hex numbers, even if content is there. I
> thinks it's just a PGAdmin bug, if you do a select AsText(the_geom) all rows
> will have an entry...
> On 01-11-2007 15:00, "Andreas Laggner" <andreas.laggner at fal.de> wrote:
>> Hi,
>> what does it mean if a row has no entry in the_geom? Is there no
>> geometry at all? None of rows are invalid or empty, all of them are
>> closed and simple. But how is this possible without points in the column
>> geometry??
>> cheers Andreas
> postgis-users mailing list
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
