[postgis-users] Shortest Distance from Every Point
Obe, Regina
robe.dnd at cityofboston.gov
Mon Nov 5 07:03:08 PST 2007
Matt,
The expand function creates a bbox that expands out mmd units. So the
EXPAND && basically limits your search to only those cities that fall
within the expand box and since && is an indexable operator, the search
is indexable. The only issue with the EXPAND is that you have to guess
at an expand box that will cover all your cities (e.g. guarantee that no
near result would fall outside your EXPAND guess) and yet limit the size
of your expand box to something that doesn't trap too many fish so to
speak. the more fish you trap, the more checks your distance function
has to do.
One way to guess at an expand is to do the following query (start fairly
small) and keep on increasing the size of your expand until you get no
results. The exception query I think runs fairly fast since it doesn't
do the costly distance check.
SELECT
c1.city_name
FROM
city c1
LEFT JOIN
city c2
ON (
c1.city_name <> c2.city_name AND EXPAND(c1.the_geom, 10000) &&
c2.the_geom
WHERE c2.city_name IS NULL
You know I completely forgot about using DISTINCT ON to do more than one
neighbor search for a set of records at a time. I guess I don't use
that much. So I second Paul's comment "very nice query".
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Matthew Pulis
Sent: Sunday, November 04, 2007 7:21 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Shortest Distance from Every Point
Can you please explain further why u used the EXPAND? Didn't much get
what is its use? And is mmd a thing which has to do with PostGis ?
On 11/4/07, Paul Ramsey <pramsey at refractions.net> wrote:
Well, you have to build the cartesian product of every city
combination and then measure every distance in that virtual
table, so
it's not going to scale well at all as the input table gets
bigger.
However, if you know the "maximum minimum distance" (?mmd?) you
can
add a spatial constraint that should at least keep the
calculations
in the O(n*log(n)) range... (you'll need a spatial index on the
table
for best effect as the table gets larger)
SELECT DISTINCT ON (c1)
c1.city_name AS "c1",
c2.city_name AS "c2",
distance(c1.the_geom, c2.the_geom),
makeline(c1.the_geom, c2.the_geom)
FROM
city c1
JOIN
city c2
ON (
c1.the_geom && ST_Expand(c2.the_geom, ?mmd?)
ORDER BY c1, distance ASC
Paul
PS - Nice query, BTW.
On 4-Nov-07, at 9:15 AM, Yancho wrote:
> Just wanted to say that I managed to write this Query :
> distance( c1.the_geom, c2.the_geom),
> FROM
> city c1
> JOIN
> city c2
> ON (
> It works perfectly, however how much do you think it can scale
? On
> 16 rows
> it didnt take long, however or 28,000 rows? Will it use the
O(n^2)
> scalability?
> Thanks
> Yancho wrote:
>> Hi,
>> I am trying to make a query so it parses through all the 16
cities
>> i have
>> in
>> a table called city, and for each city, picks the nearest
city,
>> and gives
>> me
>> the distance between both cities.
>> This is the query I made :
>> select
>> c.city_name, astext(c.the_geom), distance(c.the_geom,
d.the_geom) AS
>> Distance, d.city_name, astext(d.the_geom)
>> from city c, city d
>> where
>> c.city_name = (
>> select c.city_name order by c.city_name ASC
>> and
>> d.city_name = (
>> select d.city_name order by d.city_name DESC
>> group by c.city_name
>> order by Distance DESC
>> LIMIT 1;
>> But I am getting this error : ERROR: column "c.the_geom" must
>> appear in
>> the
>> GROUP BY clause or be used in an aggregate function
>> I am seeing no reason why I should add c.the_geom, anyone can
>> enlighten me
>> more on why I should group by the_geom and after all if it
does make
>> sense?
>> Thanks
>> Matthew Pulis
>> www.solutions-lab.net // www.mepa-clan.info
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> View this message in context: http://www.nabble.com/Shortest-
> Distance-from-Every-Point-tf4743229.html#a13575499
> Sent from the PostGIS - User mailing list archive at
Nabble.com.
Matthew Pulis
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071105/c1ac13a2/attachment.html>
