[postgis-users] Shortest Distance from Every Point
Paul Ramsey
pramsey at refractions.net
Mon Nov 5 08:02:44 PST 2007
The "maximum minimum distance" has nothing to do with PostGIS, it's
just an idea: is there a distance you expect all your minimum
distances to be smaller than? If so, you can winnow out pairings of
cities that will *not* yield a minimum distance. This is what the
ST_Expand does, it turns a point into a box, with a distance of ?mmd?
from each side to the center. And the && tests containment in that
box, using the spatial index operator.
P
On 4-Nov-07, at 4:21 PM, Matthew Pulis wrote:
> Can you please explain further why u used the EXPAND? Didn't much
> get what is its use? And is mmd a thing which has to do with PostGis ?
> On 11/4/07, Paul Ramsey <pramsey at refractions.net> wrote:
> Well, you have to build the cartesian product of every city
> combination and then measure every distance in that virtual table, so
> it's not going to scale well at all as the input table gets bigger.
> However, if you know the "maximum minimum distance" (?mmd?) you can
> add a spatial constraint that should at least keep the calculations
> in the O(n*log(n)) range... (you'll need a spatial index on the table
> for best effect as the table gets larger)
> SELECT DISTINCT ON (c1)
> c1.city_name AS "c1",
> c2.city_name AS "c2",
> distance(c1.the_geom, c2.the_geom),
> makeline(c1.the_geom, c2.the_geom)
> FROM
> city c1
> JOIN
> city c2
> ON (
> c1.city_name <> c2.city_name AND
> c1.the_geom && ST_Expand(c2.the_geom, ?mmd?)
> ORDER BY c1, distance ASC
> Paul
> PS - Nice query, BTW.
> On 4-Nov-07, at 9:15 AM, Yancho wrote:
> > Just wanted to say that I managed to write this Query :
> > distance( c1.the_geom, c2.the_geom),
> > FROM
> > city c1
> > JOIN
> > city c2
> > ON (
> > It works perfectly, however how much do you think it can scale ? On
> > 16 rows
> > it didnt take long, however or 28,000 rows? Will it use the O(n^2)
> > scalability?
> > Thanks
> > Yancho wrote:
> >> Hi,
> >> I am trying to make a query so it parses through all the 16 cities
> >> i have
> >> in
> >> a table called city, and for each city, picks the nearest city,
> >> and gives
> >> me
> >> the distance between both cities.
> >> This is the query I made :
> >> select
> >> c.city_name, astext(c.the_geom), distance(c.the_geom,
> d.the_geom) AS
> >> Distance, d.city_name, astext(d.the_geom)
> >> from city c, city d
> >> where
> >> c.city_name = (
> >> select c.city_name order by c.city_name ASC
> >> and
> >> d.city_name = (
> >> select d.city_name order by d.city_name DESC
> >> group by c.city_name
> >> order by Distance DESC
> >> LIMIT 1;
> >> But I am getting this error : ERROR: column "c.the_geom" must
> >> appear in
> >> the
> >> GROUP BY clause or be used in an aggregate function
> >> I am seeing no reason why I should add c.the_geom, anyone can
> >> enlighten me
> >> more on why I should group by the_geom and after all if it does
> make
> >> sense?
> >> Thanks
> >> Matthew Pulis
> >> www.solutions-lab.net // www.mepa-clan.info
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> > View this message in context: http://www.nabble.com/Shortest-
> > Distance-from-Every-Point-tf4743229.html#a13575499
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> Matthew Pulis
