[postgis-users] GEOS union() error
Paul Ramsey pramsey at refractions.net
Tue Nov 6 14:54:47 PST 2007
Lee, what are you going to do with this beast once you have created it?
P
On 6-Nov-07, at 10:41 AM, Lee Keel wrote:
> Hello list.
> I am trying to get a multipolygon from a union of buffered
> linestrings.  See attached (bad_drawing.jpg) to see what I am
> trying to achieve.  I have some linestrings, I want to buffer each
> line by 400 feet, then combine all of those buffers to create one
> multipolygon.  My thought was to do something like:
> select geomunion(buffer(the_geom, 400)) as the_geom from main
> However, when I do this, then I get the following error:
> NOTICE:  TopologyException: side location conflict (901411,1.03413e
> +006,1.03413e+006)
> ERROR: GEOS union() threw an error!
> SQL state: XX000
> Now my guess is that the geomunion is throwing the error because
> the buffers overlap and of course that would be an invalid
> polygon.  So, could someone purpose a different approach to doing
> this?  Or tell me what I am doing wrong.
> <<bad_drawing.jpg>>
> Thanks in advance,
> Lee
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom
> they are addressed. If you have received this email in error please
> notify the sender. This message contains confidential information
> and is intended only for the individual named. If you are not the
> named addressee you should not disseminate, distribute or copy this
> e-mail.
> <bad_drawing.jpg>
> postgis-users mailing list
