[postgis-users] GEOS union() error
Martin Davis mbdavis at refractions.net
Tue Nov 6 11:02:08 PST 2007
You could try doing the union and then the buffer - that should be more
robust.  Something like:
select buffer(geomunion(the_geom), 400) as the_geom from main
(although I may not have quite the right syntax)
Lee Keel wrote:
> Hello list.
> I am trying to get a multipolygon from a union of buffered
> linestrings.  See attached (bad_drawing.jpg) to see what I am trying
> to achieve.  I have some linestrings, I want to buffer each line by
> 400 feet, then combine all of those buffers to create one
> multipolygon.  My thought was to do something like:
> select geomunion(buffer(the_geom, 400)) as the_geom from main
> However, when I do this, then I get the following error:
> NOTICE:  TopologyException: side location conflict
> (901411,1.03413e+006,1.03413e+006)
> ERROR: GEOS union() threw an error!
> SQL state: XX000
> Now my guess is that the geomunion is throwing the error because the
> buffers overlap and of course that would be an invalid polygon.  So,
> could someone purpose a different approach to doing this?  Or tell me
> what I am doing wrong.
> <<bad_drawing.jpg>>
> Thanks in advance,
> Lee
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the sender. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
