[postgis-users] GEOS union() error
Obe, Regina
robe.dnd at cityofboston.gov
Wed Nov 7 06:21:44 PST 2007
Lee,
Did you try the collect buffer?
I'm not sure why we have that explicit in the documentation - could be
left over from another time? Should we remove that from the
documentation.
I've done it and it works fine except when I had some invalid geometries
I think it created some strange results but never errored out.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Lee
Keel
Sent: Wednesday, November 07, 2007 9:14 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] GEOS union() error
> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Tuesday, November 06, 2007 4:55 PM
> Subject: Re: [postgis-users] GEOS union() error
> Lee, what are you going to do with this beast once you have created
it?
> P
> On 6-Nov-07, at 10:41 AM, Lee Keel wrote:
Paul,
My client needs this information to generate a shape file for "call
before
you dig" information. They are a gas company and they have to output
this
information all the time, the problem for them is that it is becoming a
full
time job to take a shape file, open it in Arcmap, do the buffering,
reproject the data and then save. I told them that this could all be
done
in one query in the spatial database that we were using. But obviously,
I
have run into some snags.
Also, to combine chains... I did not use collect on the geometries
column
and pass that to buffer because it is very explicit in the online help
not
to pass GeometryCollection as argument to buffer.
Thanks for the responses. I look forward to any more helpful ideas.
Lee
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. If you have received this email in error please notify the
sender. This message contains confidential information and is intended
only for the individual named. If you are not the named addressee you
should not disseminate, distribute or copy this e-mail.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
