[postgis-users] UML Profile using PostGIS geometry types andSQL-MMtopology functions
Chris Hermansen chris.hermansen at timberline.ca
Fri Nov 9 10:59:40 PST 2007
With respect to persistence, there are many interesting Java mechanisms
around.  Another one to consider in this context, perhaps, is JDO.
Fonseca Hespanha de Oliveira, Joao da wrote:
> Norman:
> Thanks for all the usefull advices concerning possible implementations
> to follow in my tool development.
> The UML Profile I intend to develop is just a piece of the whole
> process, but an important one. I believe a good profile for spatial
> features is required to get UML to (spatial) database transformations,
> and currently EA has none.
> Also, the current schema transformation templates do not take into
> account the processing of OCL constraints. Even the XMI generated from
> the UML tool does not have it in the UML2 namespace, just in its own
> extended namespace (in the EA case, at least).
> There is also the possibility to specify queries (most will be
> validation ones) from the model itself.
> I agree the full potential of such a tool could only be unleashed if
> there will be an object model generated in between. I am currently
> considering using the Eclipse EMF for that purpose, namely because it
> offers UML and also OCL parsing in an Open Source environment.
> Hibernate came into consideration just recently (I am a newbie
> concerning Java technologies; was used to the MS platform :-) ), just
> got a copy of the "Java Persistence with Hibernate". From a first
> look, it seams it has indeed a lot of features, in fact it could
> supply much of the functionality I have in mind.
> Returning to the UML Profile for PostGIS geometry types, I am not
> being able to get a full description of the methods which apply to
> each geometry type, at least in the same way they are expressed on the
> Simple Features Access or the SQL/MM standards. Is there any document
> on these matters?
> Consideration of PostGIS specific geometry types, constraints and
> methods would make this a "UML PostGIS Profile", and not anymore a
> generic SQL/MM Profile, but this serves well my immediate research
> objectives.
> Joao
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *Norman Barker
> *Sent:* donderdag 8 november 2007 21:19
> *To:* PostGIS Users Discussion
> *Subject:* RE: [postgis-users] UML Profile using PostGIS geometry
> Hi,
> I am not sure that UML to database is going to achieve that much in
> terms of mapping, but certainly UML to object (so ejb3 or geodjango)
>  and hence database might be interesting.  To this end hibernate tools
> is useful (and generates schematics) and just changing the free marker
> templates allows geometry mappings.
> Most of the work in this area has been in UML to xml schema mapping,
> and to this end the models (including EA Architect) from
> http://www.isotc211.org/ might be of use.
> If I were doing this work, then the tool I would use would be the new
> eclipse UML tools, just because these are publicly available to
> everyone, and the XMI they output would be useful in a lot of projects.
> ERD tools such as dbdesigner for mysql already support spatial
> functions, hence why I am struggling to see the benefit of your
> approach – can you explain some more?
> Thanks,
> Norman
> *Fonseca Hespanha de Oliveira, Joao da
> *Sent:* Thursday, November 08, 2007 11:12 AM
> *To:* postgis-users at postgis.refractions.net
> *Subject:* [postgis-users] UML Profile using PostGIS geometry types
> and SQL-MMtopology functions
> Hello all!
> As part of my current PhD research, I am trying to specify a new UML
> Profile to apply to UML Class diagrams representing spatial features,
> that is, using geometry types.
> I am using PostgreSQL's PostGIS extension as reference for the actual
> geometry types, but I think it could be applied to any spatial
> database system which complies to the Simple Features Access for SQL
> specification.
> Currently, also geometry types from SQL/MM ISO/IEC standard are also
> being supported by such databases, and at least some will be added to
> the Profile.
> I would like to receive any suggestions this forum members might
> have, I am currently using Enterprise Architect (EA) as UML Modeling
> Tool and I plan to present (attach) PDF files with the class diagrams
> and the final Profile. Maybe the profile could be added to the EA add
> ons later on, otherwise it could be transposed to other UML Tools.
> If somebody has a suggestion on any other way to interact, with or
> without EA software, ideas are also most welcome.
> The final aim of this research component is to define a CASE tool
> which can use a UML model with the mentioned profile to generate a
> PostGIS schema through an automatic generated SQL script (a process
> generally known as Model-to-Text transformation).
> Looking forward to hear from you,
> Joao Paulo Hespanha
> PhD Student, OTB Research Institute,
> TUDelft
> The Netherlands
> postgis-users mailing list
Regards,
Chris Hermansen · mailto:clh at timberline.ca
tel:+1.604.714.2878 · fax:+1.604.733.0631
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
C'est ma façon de parler.
