[postgis-users] UML Profile using PostGIS geometry types andSQL-MMtopology functions
karel karel at cadrie.com
Fri Nov 9 12:07:08 PST 2007
I've some experience with EMF using Hibernate in the context of
spatial data.
We used EMF + teneo + OWL to generate a database + java binding from
an OWL file. We wrote a tool that generated an Ecore model from the
OWL file. This Ecore model than was used to generate the  Java code
(EMF), Hibernate mapping file (Teneo). The spatial data types were
handled by an extension to Hibernate. This extension is now an
independent open source project. You can find it here: http://
www.hibernatespatial.org/.  There is a comparable project for JPOX
persistence. See: http://www.jpox.org/docs/1_1/spatial.html. JPOX is
another ORM solution.
Regards,
Karel Maesen
On 09 Nov 2007, at 15:25, Fonseca Hespanha de Oliveira, Joao da wrote:
> Norman:
> Thanks for all the usefull advices concerning possible
> implementations to follow in my tool development.
> The UML Profile I intend to develop is just a piece of the whole
> process, but an important one. I believe a good profile for spatial
> features is required to get UML to (spatial) database
> transformations, and currently EA has none.
> Also, the current schema transformation templates do not take into
> account the processing of OCL constraints. Even the XMI generated
> from the UML tool does not have it in the UML2 namespace, just in
> its own extended namespace (in the EA case, at least).
> There is also the possibility to specify queries (most will be
> validation ones) from the model itself.
> I agree the full potential of such a tool could only be unleashed
> if there will be an object model generated in between. I am
> currently considering using the Eclipse EMF for that purpose,
> namely because it offers UML and also OCL parsing in an Open Source
> environment.
> Hibernate came into consideration just recently (I am a newbie
> concerning Java technologies; was used to the MS platform :-) ),
> just got a copy of the "Java Persistence with Hibernate". From a
> first look, it seams it has indeed a lot of features, in fact it
> could supply much of the functionality I have in mind.
> Returning to the UML Profile for PostGIS geometry types, I am not
> being able to get a full description of the methods which apply to
> each geometry type, at least in the same way they are expressed on
> the Simple Features Access or the SQL/MM standards. Is there any
> document on these matters?
> Consideration of PostGIS specific geometry types, constraints and
> methods would make this a "UML PostGIS Profile", and not anymore a
> generic SQL/MM Profile, but this serves well my immediate research
> objectives.
> Joao
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of Norman Barker
> Sent: donderdag 8 november 2007 21:19
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] UML Profile using PostGIS geometry
> Hi,
> I am not sure that UML to database is going to achieve that much in
> terms of mapping, but certainly UML to object (so ejb3 or
> geodjango)  and hence database might be interesting.  To this end
> hibernate tools is useful (and generates schematics) and just
> changing the free marker templates allows geometry mappings.
> Most of the work in this area has been in UML to xml schema
> mapping, and to this end the models (including EA Architect) from
> http://www.isotc211.org/ might be of use.
> If I were doing this work, then the tool I would use would be the
> new eclipse UML tools, just because these are publicly available to
> everyone, and the XMI they output would be useful in a lot of
> projects.
> ERD tools such as dbdesigner for mysql already support spatial
> functions, hence why I am struggling to see the benefit of your
> approach – can you explain some more?
> Thanks,
> Norman
> users-bounces at postgis.refractions.net] On Behalf Of Fonseca
> Sent: Thursday, November 08, 2007 11:12 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] UML Profile using PostGIS geometry types
> and SQL-MMtopology functions
> Hello all!
> As part of my current PhD research, I am trying to specify a new
> UML Profile to apply to UML Class diagrams representing spatial
> features, that is, using geometry types.
> I am using PostgreSQL's PostGIS extension as reference for the
> actual geometry types, but I think it could be applied to any
> spatial database system which complies to the Simple Features
> Access for SQL specification.
> Currently, also geometry types from SQL/MM ISO/IEC standard are
> also being supported by such databases, and at least some will be
> added to the Profile.
> I would like to receive any suggestions this forum members might
> have, I am currently using Enterprise Architect (EA) as UML
> Modeling Tool and I plan to present (attach) PDF files with the
> class diagrams and the final Profile. Maybe the profile could be
> added to the EA add ons later on, otherwise it could be transposed
> to other UML Tools.
> If somebody has a suggestion on any other way to interact, with or
> without EA software, ideas are also most welcome.
> The final aim of this research component is to define a CASE tool
> which can use a UML model with the mentioned profile to generate a
> PostGIS schema through an automatic generated SQL script (a process
> generally known as Model-to-Text transformation).
> Looking forward to hear from you,
> Joao Paulo Hespanha
> PhD Student, OTB Research Institute,
> TUDelft
> The Netherlands
> postgis-users mailing list
