[postgis-users] geomunion revisited....
Lee Keel lee.keel at uai.com
Mon Nov 12 12:29:43 PST 2007
Well the good news is that I finally got a configuration that wasn't crying
about memory nor getting the other error....
However, I am back to a much more general question.  Have there been any
improvements to the geomunion() algorithm in versions after 1.2.1?  I have
gotten my buffered polygons for all my linestrings and that part of the
query returns 32,278 rows in about 22 seconds.  But the geomunion of these
rows has been running for over 5 hours.  My problem is that a person can do
this in ArcMap in about 20 minutes.
So the query that takes 22 seconds is:
select simplify(buffer(simplify(the_geom, 5), 400), 150) as the_geom from
table1
union
table2
by adding geomunion() to the resulting geometry, it is still running:
select geomunion(the_geom) as the_geom from (
table1
union
table2) foo
Yes, I know that I must be insane to asking for a single multipolygon like
this.  And I am sure it is outside the normal realm of geomunion(), but it
would sure be nice if it would work. :)
Suggestions welcome.
Thanks in advance,
Lee Keel
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071112/11b23909/attachment.html>
