[postgis-users] geomunion revisited....
Josh Livni josh at umbrellaconsulting.com
Mon Nov 12 21:12:33 PST 2007
I think running buffer(bunch_of_geoms,0) rather than
geomunion(bunch_of_geoms) might be faster.
That said, still seems it takes a bit long.  If it were me I'd try
playing around by first creating a table with your results, eg:
'''create table simple_buffers as (
select simplify(buffer(simplify(the_geom, 5), 400), 150) as the_geom
from table1
union
from table2); '''
then you could create a GiST index on the_geom of your new table, run
vacuum analyze on it, and then try the geomunion and buffer to test.
With 32k+ rows, depending on how much they overlap, that might help a
little, or at least help potentially isolate the issue if it does take
as long.
Also I assume you've modified your postgres config away from the
defaults to take advantage of more memory on your machine, etc.
  -Josh
Lee Keel wrote:
> Well the good news is that I finally got a configuration that wasn't
> crying about memory nor getting the other error....
> However, I am back to a much more general question.  Have there been
> any improvements to the geomunion() algorithm in versions after
> 1.2.1?  I have gotten my buffered polygons for all my linestrings and
> that part of the query returns 32,278 rows in about 22 seconds.  But
> the geomunion of these rows has been running for over 5 hours.  My
> problem is that a person can do this in ArcMap in about 20 minutes.
> So the query that takes 22 seconds is:
> from table1
> union
> from table2
> by adding geomunion() to the resulting geometry, it is still running:
> select geomunion(the_geom) as the_geom from (
> from table1
> union
> from table2) foo
> Yes, I know that I must be insane to asking for a single multipolygon
> like this.  And I am sure it is outside the normal realm of
> geomunion(), but it would sure be nice if it would work. :)
> Suggestions welcome.
> Thanks in advance,
> Lee Keel
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the sender. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> postgis-users mailing list
