[postgis-users] US zip code bounding boxes/ZCTA sizes
George Pavlov
gpavlov at mynewplace.com
Mon Nov 12 23:53:04 PST 2007
This is not strictly a PostGIS question, but I thought some kind soul
here can help me since at least some folks on this list are likely to
have this kind of data handy: I need to find the smallest minimum
bounding box circle that could fit any US ZIP code (or a ZCTA to be
precise). So basically can someone with ZCTA polygon data run something
along these lines for me and tell me the result:
select max(diagonal_length)
from (
select
your_distance_fn (
min(lat), min(long),
max(lat), max(long)
) as diagonal_length
from your_zip_code_table
group by zip_code
) x
Even nicer would be if you could send me the output of the inner select
so I can do some more analysis. Something like this maybe:
select
zip_code,
min(lat),
min(long),
max(lat),
max(long)
group by zip_code
Thanks in advance!
George
